Mystery car pix
1133613371339134113421477
  • texasestexases Member Posts: 11,187
    And to keep it car-related:
  • andys120andys120 Member Posts: 23,685
    The Beaufighter has always been a favorite of mine, it just looked fast. It served as a fighter, night interceptor, torpedo bomber and photo recon plan. IIRC a few went to the USAAF as reverse lend-lease.
    When I was a kid I lived under the approaches to La Guardia airport and quickly learned to tell airliners apart. Constellations were the prettiest but those Stratocruisers were really big!
  • Lostwrench3Lostwrench3 Member Posts: 839
    edited July 2022
    Parked, a1950 Mercury and another 1950 Mercury.
    Crossing, a 1949 Boeing 377.
  • fintailfintail Member Posts: 58,786
    Last car posted is a Bristol 412.
  • ab348ab348 Member Posts: 20,628
    Since search is broken, I can't tell if this was posted before or not. But it's a good pic so I'm going to put it up here. Omaha, NE, 1969 or 1970.
  • explorerx4explorerx4 Member Posts: 21,042
    Black Studebaker Lark next to the white Impala coupe near lower right.
    We can't let the red 1960 Ford wagon go unmentioned, it's in front row between a '62 Chevy and a 1964 Buick Electra(?)
    Red and white 60 Ford in the same color combo as my dad's car. 59 Galaxie sedan at lower right, maybe a goldbeige 68 Ford full sized sedan (possibly a lower line Custom by its lack of chrome) to the left of it. Kind of above the Lark maybe a 59 Edsel sedan. First gen Corvair sedan and two tone 58-60 Ford pickup at upper middle.
    Newest vehicle I see is the '69 Plymouth Fury III 4-door HT in green (what else?). There is a gold-green metallic Ford 2-dr HT of some sort, maybe a Torino, going out of frame on the right that may be the same model year or even newer.
  • sdasda Member Posts: 7,712
    62 Olds Cutlass
    W111 fintail at back right.
    LR Disco in front of the Olds.
    62 Olds Cutlass
    It's a 1962 Olds F85 Cutlass. For some reason those first generation GM compacts quickly shed their original model names and substituted sub-model names with the sole exception of the Corvair. The Tempest became the LeMans, the Special became the Skylark and the F85 became the Cutlass (best selling model in the 80s).
    The car shown has the faux convertible roof line adopted by many GM models in the 1960s. It was often vinyl covered but sometimes executed in metal the same color as the rest of the car.
    Mom’s 63 Dynamic 88 coupe had the convertible look roofline and Holiday script on the sail panel. I was thinking they did the same with the 62 Cutlass but remembered Olds called the 4 dr hardtops Holiday as well.
    Gotta point out the '60 Rambler to the left of the Ford pickup.
    Fairport, NY (should zoom well):
    My car parked at right (also seen at the Studebaker HQ, etc).
    Is that a lark wagon next to it? Classic land rover would be worth big bucks now.
    Looks like a white E type convertible in the showroom.
  • tmarttmart Member Posts: 2,421
    At right, a 61 Thunderbird with black walled tires?
    Strike 1!
    edited July 2022
    64 Mercury Monterey
    64 Mercury Monterey
    Base hit!
    The Land Rover looks like a Series 2. I don't see a Jag in the showroon but what appears to be a British Ford Cortina wagon.
    edited July 2022
    I think I see the E-type as a reflection in the window at left, maybe from a car parked on the street out of frame.
    I wonder if the Cortina was a USDM car or private import. There's another Cortina parked in the lot behind the fintail.
    I never saw a Cortina Estate, the only ones I encountered were 2 door Lotus-Cortinas.
    edited July 2022
    Suddenly it's 1960!
    55 Thunderbird, two 57 Fords, three 60 Fords.
    We've seen that one before. I posted it 2 years ago.
    It's an oldie but goody!
  • xwesxxwesx Member Posts: 17,942
    andys120 said:
    Suddenly it's 1960!
    Yeah, tell that to the fuel pumps! :D
    60 Ford Ranch Wagon with another 60 Ford Wagon peeking around the corner to the left. Behind the Ranch Wagon, a Volvo PV444/544.
    Let's have some 1960 housing prices while we're at it.
    Between the ‘57 Ford sedan and the Tbird (which I think is also a ‘57) is a ‘55 or ‘56 Plymouth.
    That Cortina Estate has the second style of grille so it is from the 1964 face lift which was when they introduced the greatly improved ventilation system
    If you look very carefully the "c" pillar has a grille at the top (as did the deans) whereas the original versions launched in 1962
    This was also when the car changed from being a Consul Cortina to just a Cortina..
    Here that was a very popular estate car and they sold loads. Hardly any now survive...
    edited July 2022
    Talking of ventilation yesterday we had the hottest day's temperature in UK history
    Not hot by, say Arizona standards but about a third of England topped 40 degrees (Centigrade).
    I think in your Fahrenheit scale that's about 104.
    No fun given limited installation of Air-conditioning in housing over here.
    (For limited read nil)
    The Thunderbird is definitely NOT a 57. A 57 has the parking lights in the bumper, not in the body, plus it has fins. Also, the continental kit was standard on the 56, but could be deleted. It was an option on the 55 and 57. So, since no conti kit, I’ll stick with it being a 55.
    I don' see a vent in the front fender of the 'Bird, so I think it's a 55, too.
  • kyfdxkyfdx Moderator Posts: 271,114
    104 F is hot, anywhere...
    We were in Dublin, last Monday (9 days ago), and it hit 84 F, and everyone thought that was hot for Dublin.
    I think Ireland was also hitting records too - even Wales did !
    Friends of ours picked a bad time to visit relatives this week near Crawley (south of London).
    1960 again?
    Likely a bit later as I see a '64 Mercury and a Chevy wagon of that same vintage.
    Picture says Pittsburgh 1966.
    It's my grandma's 1960-ish Rambler! First car I sat in with reclining seats and electric windows.
    Electric windows in a Rambler, wow! That had to be rare.
    60 Starliner at left looking a little faded already. 6-window 4-finned 61 Caddy at lower right in the parking lot.
    A rare one in center> [expands]
    1950 "Kurtis Sports Car", a few made by Kurtis-Kraft, who sold it to 'Madman Muntz', lengthened, and sold as the Muntz Jet.
    The 41 Chevy sedan delivery in the background is pretty rare anymore too.
    What's the blue car in the foreground?
    Blue car is another Kurtis.
