Visitor Agreement.
Too funny you mention this. I just told the wife the other night we need to open a HELOC on the primary. I want to be in a position to buy a second home at the shore to rent if the values drop.
I’m pretty sure a good black tape job can make the light disappear.
A black magic marker works just as well.
The ! makes me think the system Auto S/S system is disabled.
It could be because you don't drive it much and so it disabled the system to not stress the battery.
That plus our primary is 75% LTV total, FYI, so that has a lot to do with it, I'm sure. But I got quotes from several other banks and CUs and nobody was anywhere close.
Is your Pax still under the original warranty? Maybe the emissions warranty?
I believe most S/S systems have a counter and at some # disables it.
My HP laptop is probably 6 to 8 years old. I got a message on it that Windows 8.1 won't be supported after Jan 2023. It said you can update to...I think it said Windows 10 or 11 if you follow instructions.
I checked with HP and they said my laptop is too old to work with Windows 10 or 11.
So, do I just keep going until it doesn't work any more?
Do I start looking for a new computer?
Do I hope enough people complain and they change their mind?
Do I need updates?
but that is getting fairly old (though the HP laptop I am typing on right now is not that much newer!) so wouldn't hurt to get a new one. and depending on what you use it for might not even need a full windows machine. a lot of people are perfectly happy with something like a Chromebook.
https://www.walmart.com/ip/Gateway-14-1-Ultra-Slim-Notebook-FHD-Intel-Core-i5-1135G7-Quad-Core-Iris-Xe-Graphics-512GB-SSD-16GB-RAM-Tuned-THX-Fingerprint-Scanner-1MP-Webcam-HDMI/982087215?irgwc=1&sourceid=imp_zu:2W7weJxyNWuMQCrWxK39dUkDX1p2-uXAo2U0&veh=aff&wmlspartner=imp_10915&clickid=zu:2W7weJxyNWuMQCrWxK39dUkDX1p2-uXAo2U0&sharedid=&affiliates_ad_id=565706&campaign_id=9383
Bear in mind this is very cheaply constructed, and not upgradeable, but it works quite well. And for $279 it's hard to go wrong.
As to your old notebook, if it's running Windows 8.1 the odds are very good that it can successfully run Windows 10. Not 100% in your favor, but better than 90%.
@henryn that is an almost unbelievable deal at $279. 16 gigs of ram and a 512 SSD should keep it feeling zippy for a long time to come.
That is a deal. The 15.6 version is only $299 if you want a bigger screen. I’d get one if I needed it.
Oh, I know. I didn’t mean to imply what the school gives out can be compared in any way to a real laptop. Lol.
Pavilion g7-1260us
Envy DV-6
Two of my HP laptops were Win 8 when new. One may have been Win 7?
I just looked up on the tools and found the bios in one is from 2012. So the 2 of the laptops
are that old.
Neither laptop had trouble updating with Win10. They've operated fast than with
8.0 and the updating is almost transparent.
I'd suggest keeping the laptop because it probably has a CD DVD reader that you may use while
theHw you like that.
I upgraded mine by replacing and adding memory cards to get maximum memory
in dual channel mode. I have 3 laptops and migrated parts to optimize my business
laptop. More memory means less use of temp memory writing to and from the hard drive.
I replaced mechanical hard drives with SSD drives on 2 of the laptops. Much quicker on startup
and noticeable speed increase in some operations. But not much in normal folk's operations.
It is much easier to upgrade the memory and hard drive on older notebooks. Newer ones are a real pain to gain access to the components. Some, like the Gateway I talked about up above, the memory is surface mounted and can not be replace or upgraded. Fortunately, it comes with 16 gigs so you will likely never need to upgrade the memory, and it is already using an SSD drive.
If you have to pay someone to upgrade your old computer, you're probably better off just buying a new one. If you can do the work yourself, then more power to you.
This morning I cruise over to the Interstate Batteries store, which is only about 1.5 miles from my house. They are very short handed, myself and 2 others had to hang around for about 10 minutes before anyone came to the front desk to help us. They are not doing installs, but they do have both batteries I need, and the manager kindly agrees to load test both of my batteries.
Surprisingly, both batteries pass the load test, which leaves me scratching my head. Back to the house, dig out my OBD2 Bluetooth connector doohickey, and read the codes.
P00FD – Battery B State of Charge Performance. In other words, the aux battery is bad.
Back online, search for any and all information about a “P00FD” code. Found a thread over on a Jeep forum where someone is talking about testing the batteries and explains that you have to completely disconnect one of the batteries in order to test the other one. Which gives me one of those “duh” moments, because of course we didn’t do that before load testing at the Interstate store.
As I was going to have to do the install myself, I spent some time shopping online. O’Reily Auto Parts has the AUX14 battery, in stock, $17 less than Interstate. And Walmart has the main battery for about $70 less. It took longer to run around and pick up the batteries than it did to install them, but they are now in place and the warning light is off and hopefully will stay off.
I didn’t have to replace the main battery, but as this was the factory original and coming up on 4 years old, I figured I might as well while I was in there.
Of course it was on a fairly nice Jeep with 5 lights mounted on
the front of the roof. White. Large wheels.
What is it about Jeeps that the owners sometimes, sometimes, have headlights
that could be used by police search and rescue teams scanning the countryside
for lost persons.
A few have them aimed upward directly into the eyes of the oncoming vehicles.
Aren't there any state laws on headlamp brightness anymore?
But it's neat the way some of the Jeep owners have modified, personalized, their
jeeps. I was behind one a few months back with twinkle lights on the face of the
high-mounted spare tire. They were various colors and twinkled in a rythmic way.
Interesting to watch while waiting for the stoplight to change.
EXJAY
(if you know Jeeps, you'll get the reference)
Thanks for the info
just spend the $279 and get a brand spanking new one, which will be much nicer, and invest your saved time in playing pickleball.
“So you are telling the court that aside from failing two drug tests, picking up a new felony arrest, and not reporting to your probation officer, you have done exceptionally well on probation?”
His reply? “Yes!”
Wow! What a game last night. Go Phils! Once again, beating all expectations. I especially love the justice of the batter who leaned into a pitch getting the last out.
Was just coming here to post this! Mom watched the kids and we went to a bar near the shore house to watch it. Tons of energy in there
* every printer, computer, we have owned is an HP........if I get a Gateway will it work flawlessly with all of our printers, in both homes?
* Also, since I don't need that much power or memory etc, maybe I can get an HP laptop for a bit more, although it won't have the same power, it will be sufficient for my basic needs?
*If something simple goes wrong with a new laptop, wouldn't it be easier to find a cure on Youtube for an HP than a Gateway? Once I had the black screen of death on the laptop. I used the desktop to find the cure, and by pressing a few keys my laptop came back on again......it seems to me some repairs are specific to a particular make, and HPs are more popular.
*I am thinking I would prefer to try and get by with this laptop while I am in Florida, and get a new laptop when I return, because I can get it set up if I need help with my trusted IT guy who is here, and not in Florida. Or, if the deals are better in Florida buy one and bring them both back. (I don't know how to transfer all of my documents, pictures and stuff from one computer to the other for example).
This morning I’m driving around in the fog doing the speed limit but being careful. As I go down the double ramp to the highway a Range Rover flies by and then drifts into my lane. I step on the gas to get away from him and he takes it as a race challenge. I finally backed off at 90 and let him be crazy on his own.
A few miles later I’m in the right lane and an Acura comes up right on my bumper but won’t pass. Later he tried to pass me on the right as his lane ended causing him to do a near PIT maneuver on me as he slammed on the brakes and swerved in behind me. Thankfully, I exited, leaving him to ride someone else’s bumper.
I did mention that this was in heavy fog, right? Do people leave their brains at home these days?
It was really obvious he leaned into. Almost a call that had to made.
Along the way I’m sure lying has gotten this guy in trouble too.
And, another thing, in Florida you see some cars but mostly trucks that shouldn't be on the road. They are in such rough shape that I really wonder if the brakes would work.
Now what do I do for the next 11 hours?
