Visitor Agreement.
good thing it got too late to do the other car today or I might not be able to get out of bed in the morning!
the Acura gets done tomorrow afternoon if there isn't any rain around.
but, at least they will be all set for winter with fresh wax applied. and doing the clay bar first makes it very nice and smooth.
Buy brake fluid test strips, then you actually know when it needs changed.
C’mon man, stop complaining. Detailing a car on a nice Fall day keeps you young. You can’t shop the whole day away. You gotta remember your priorities.
What do you use for the “slippery component” with your clay bar?
I need to buy a vacuum bleed kit to be able to do it myself. I used to have my wife come out and push on the brake peddle while I opened the bleed screw.
I know you are supposed to change brake fluid and if I was keeping something long term I’d absolutely do it.
Having said that. My 04 Grand Marquis that my Grandfather bought with 10K miles one year old and I took over in 2012 was still on the original brake fluid at nearly 13 years old and 110K miles when I sold it. That brake system had never been opened up other than to swap the front pads. Rears were original.
hey, it is better than the snow that everyone promised me!
but I am happy that both cars are all shiny and smooth, and have some protection on the finish for the inevitable salt onslaught. need to find the closest drive through washes that have undercarriage washes. the painted parts, I will do them myself.
When we moved to SC I could no longer use one of my sons to help with the brake bleeding process after I put pads or drum brakes on the rear of our ‘80 Park Ave. So I had to recruit Mrs. j for help. But before I did that I told her if she didn’t hold the brake peddle down until I told her to release it, she’d let air enter the system and since she was the principal driver of that car she’d be the one to blame if she couldn’t stop and ran into something.
OK, I’m now under the car and I cracked open the bleed screw. So I yell out to her to put her foot on the brake peddle and get ready for me to tell her when to push on the brake peddle. I backed out the bleed screw a couple turns then yelled out to her to push the brake peddle all the way to the floor and hold it there until I told her to release it. Once I saw the fluid pushed out of the line I closed the bleed screw then yelled out to her to release the peddle and let it return to its normal position. She yells back, “did you say I can take my foot off the peddle now”? I yell back, “yes take your foot off the peddle now”. She yells back, “are you sure it’s OK for me to take my foot off the brake now. I yell back, “yeah dammit, NOW. I’d like to finish this brake job today”.
Sometimes you gotta find a way to get a wife to pay attention and putting the fear of the brake gods in them should work.
To this day she still likes to tell folks how she helped me do a brake job years ago.
Ricardo:
Recaro:
I had a 6-point in my back yard last week and he was quite brazen. Just laid down and stayed there until he was ready to leave. I rapped on the window to see what he’d do and he just stayed there. I even opened the back door and all he did was lay his head down between his front hooves.
Eating and relaxing in my hood must be pretty good for this guy. From the looks of him I’d guess he was at least 130 pounds with nerves of steel.
There’s always that 1%.
Man, you better not try wizzing anywhere on that lot. I’m a land baron compared to you.
I liked the car is a red color, that is a $1700 option, and to get flat gray it is $3400 extra. I saw a Mitsu in a gleaming metallically candy apple red color that looked really nice, it probably doesn't cost extra to get that on the Mitsu. And does that flat gray actually cost more to produce.....at least it probably doesn't need waxing!
QUESTION
I just moved to Waterloo about four weeks ago. Some people that I knew recommended a garage to me so I took their word that they were honest and fair. My car had about 85 thousand miles and the garage recommended that I renew my transmission oil when I went in for a tire changeover. I agreed to this and about two weeks after the transmission was serviced, it started to vibrate and erratically shift on take off and my car’s engine light came on but went off after a couple of days. I went back to the garage and they checked the oil and took the car for a testdrive but found nothing wrong. I went with him for the test drive and I have to admit that it did not shudder when the mechanic was road testing the car. On the way home, after about four stops however, it started to shudder and shift erratically again on take off. I then went to another garage and they told me that the garage might not have put the transmission filter on correctly. I declined to have them remove the pan. I again went back to the first garage who changed the transmission oil and questioned them as to what they might have done wrong. They scoffed me off and told me that they did not do anything wrong and that my transmission problems were internal and had nothing to do with the changing of the transmission oil. I left the garage with the feeling that the garage was looking for a job and that I looked like an easy mark. I stopped by a transmission shop and they told me that I would need to replace the transmission or have mine rebuilt. I would appreciate your opinion.
L from Waterloo
ANSWER
To start with, the changing of the transmission oil will not cause internal problems for a transmission that is in good working order. The second shop that looked at your car was not an actual transmission shop but they do work on transmissions on the side. Do you recall the first shop telling you that the transmission oil in your car was very dirty and very thick? They also asked you at the time if anyone had put an additive in your transmission and you said NO. I asked the garage to check the last oil change sticker that was on your car and found that you had changed the engine oil about 550 miles ago. I called the garage in Milton who had changed the engine oil in your car and you and I both know what was added to your car’s transmission to try and stop the erratic shifting, so I will leave the story there.
I think that you have had some unknowledgeable advice as to the problem with your transmission. I want you to go to a qualified transmission shop for them to do a proper diagnosis. I know of quality transmissions shops in and around Hamilton but I am not familiar with any actual transmission shops in Waterloo, so you will have to do your own due diligence.
Some things directly related to your car’s transmission that will cause erratic shifting are a faulty throttle position sensor or a turbine speed censor, which will also trigger a yellow check engine light to illuminate. I think that you will find that one of these sensors are faulty and had you gone to a proper transmission shop for a proper diagnosis in the first place, you would not have had any need to sent me this email.
Anyone who thinks a C Class Mercedes is really like a “mini” S Class Mercedes should be driving Toyotas, Chevy’s or Fords. I can’t think of anything about a C Class that is really like an S Class except for the name, “Mercedes”! They aren’t even built in the same country.
It’s like comparing Jupiter to Earth - they’re both planets, but…!
Still love ya driver and I am always here.
Interested in a herd of green iguanas? Always around. Enjoy seeing them falling out of trees when the temps dip below 45 degrees at night in our winters.
Good to hear from you Mike.
I thought saying the C was like an S was a bit of a stretch but, as you know I never say anything without proof to back me up. I was quoting an article which isn't real proof of anything these days, but you can check what they said;
The C-Class has always been a baby S-Class, and that's still very true of the newest version.
https://www.gearpatrol.com/cars/g39968591/2023-mercedes-benz-c-class-review/
...and they aren't the only ones, others say they have similarities too.
I think it is case of artistic license, there is a bit of truth, but let's face it, the C Class at half the price is not going to be a miniature copy of an S.
About the only critter I ever see in my yard is a 10 year old Shitzu.
Yes I've heard of green iguanas.
I think the "mini" is the styling theme, which does resemble the S-class from a distance with nothing near it for proportion. But as you say, in terms of equipment, they are not in the same ballpark (nor intended to be). The C is still a key player in its segment.
Sounds like you need this:
https://youtube.com/shorts/BR5Yzf7ztKU?feature=share
......and, they gave the 2023 a glowing review. It will probably be the last C Class gasser as MB slowly goes more EV. Also, I think they were talking mostly about the way the two cars resemble each other in looks.
Describes the C/E/S class, the 3/5/7 series from BMW, and the A4/A6/A8 sedans from Audi.
Curious that none of the American brands adopted that strategy.
There aren’t any American sedans left to do that with!!
Quote from the article:
The Comet was the second compact to come out of the Ford Motor Company in the early 1960s to help combat a flood of sales-stealing imports. Based on Ford’s Falcon, the Comet debuted partway through the 1960 model year. It had the squared-off roof of Ford’s upscale Thunderbird and Galaxie — which wouldn’t appear on other Mercurys until 1961.
https://buffalocars.com/corbscorner-061818-61comet
Off hand, I can't think of a case where the smaller and/or less expensive cars looked similar to their bigger mates, like a C Class and an S Class do...or BMWs or Audis. Maybe class doesn't matter as much in Europe...lol
Fun car, though…..
https://marqued.com/listing/9a1d3a32-0872-434e-b283-de75b6e780d4/1986-fiat-bertone-x1-9-5-speed?utm_source=facebook&utm_medium=cpc&utm_campaign=Marqued_Inventory_Jun_2022&utm_content=Marqued_Lot_47_BuyerTraffic_Inventory_Fiat_Bertone_1986&utm_term=23852213066020736&fbclid=IwAR2o8ZfBa8RpO5OcEWaUnvs8XtgeIVwPfNzrmEqYHARhvA3pJoTs9_hYbno
