1303730383040304230433158
    I was behind a black corvette convertible with license plate 9TMARE (nightmare)
  • jmonroe1jmonroe1 Member Posts: 9,829
    I don’t get it. o:)
  • snakeweaselsnakeweasel Member Posts: 19,657
    mjfloyd1 said:
    It’s really not much different as running out of gas without making a plan to refuel. There are apps with gas stations and there are apps with charging stations but you have to be aware and watch your fuel / charge level and range left.
    Oh so you just get someone with an electric can and bring you some electrons, got it.
    edited September 2023
    I’d say it’s a LOT different owning an EV than an ICE car. Even if I was dopey enough to not notice how much gas I have in my tank and the gas light comes on, most ICE cars can go at least 30 miles if driven responsibly before you run out pf gas. That’s more than likely enough to get to a gas station.
    Yep gas stations are not that far apart.
    If I went to the store and the only spot was next to the cart corral, I would just turn around and go home. I would not park near one of those under any circumstances!
    My car is 13 years old with 125K miles on it, at this point I don't sweat those things.
    venture said:
    If you are talking the advantage of a convection oven compared to a regular oven it is about 25% faster.
    Or, for smaller dishes an air fryer can cook food faster than a regular oven.
    You can use your air fryer to cook recipes that have instructions for cooking in the oven. Because the heat in the air fryer is more intense than a standard oven, reduce the suggested temperature by 25ºF to 50ºF and cut the time by roughly 20%.
    What's the hurry?
    The rule in our home is all meals should be prepared in under 15 minutes, 20 for something special.
    There's nothing wrong with fast, air fryers can enhance the taste of many foods....sealing in flavors.
    Meals prepared in under 15 minutes? We would starve if he held to that.
    Nope. They both tell you the miles before empty and you plan accordingly. It’s pretty simple unless you are a simpleton
  • driver100driver100 Member Posts: 32,723
    with your luck they will deny the claim because you messed around with it! Especially if more damage was caused.
    when I have a car under warranty, I am not doing anything other than consumables maintenance (like wiper blades). Let them mess with it so my hands stay (figuratively) clean.
    I’d take my chances and claim if they didn’t want the owner changing fuses then they shouldn’t put fuse info in the manual. Fuses are a consumable protective device. I don’t scare that easily.
    Maserati Levante 2023 Fuses and Fuse Box User Manual
    Auto User Guide
    https://www.autouserguide.com › maserati › maserati-l...
    Jun 21, 2023 — Considering the complexity of this operation, we recommend having the fuses replaced by an Authorized Maserati Dealer.
    That link told me nothing about changing a fuse in a Maserati or any other car for that matter.
    Did anyone else get any fuse changing info from that link?
    Your not supposed to get a link on how to do it...they tell you to take it to your dealer. There are lots of fuses involved and it should probably be left to the experts.
    You’re😂
    Good, but even that would be illegal in Ontario Canada. You can't have your phone in your car when driving, which includes stopped for a red light.
    So you have to leave your phone at home?
    There, their, they’re…. It will be alright 😂
    Auto User Guide
    Maserati definitely has a handle on the aptitude (or lack thereof) of the people who buy their cars.
    I checked my 2020 C Class manual and it simply shows how to access all 3 fuse boxes.
    Perhaps you should look into wearing a Maserati.
    I have no idea what that proves. So you can change a fuse on any car......great, I am very happy for you. I am sure a few people around here will be impressed. Like I said, I haven't had a fuse blow in over 50 years, that is a really valuable skill to have. I am glad you'll be prepared if a fuse goes.
    Yep gas stations are not that far about.
    I guess you can say that place is not one of my “more than likely” situations. However, an EV for sure better not go there or maybe any place close to that area.
    Then there are the Maserati owners who need to visit the dealer to get a fuse changed...
    If you can afford one you don’t sully your hands with that kind of stuff.
    Exactly. The guy with the Maserati got a sales job with Levi's when they went big....and had a Corvette by the time he was 23 years old. Then he got involved with 3 partners and created a national chain of men's clothing stores that is still in business about 50 years later.
    His time can be spent doing better things than changing a fuse.
    Changing a fuse takes 10 minutes at the most. So your friend wasted a LOT more time than that taking his car in for a fuse change and that’s a fact. So, in the end is your friend really all that smart with how he manages his time?
    Since he never had to change a fuse I have no idea what he would have done, but I'd rather the dealer do it on a $140000 car...he might find out why the fuse went in the first place.
    So what is the story again about your oil change.......I think you don't remember what happened.
    Why should I waste my time telling you again? You won’t remember it anyhow.
    BTW, how’s your sticking door doing? I didn’t see anything about that.
    Yes, I forgot to get back to you. I tightened all the screws on the hinge and the screws that go into the door, and I bought and used 2 inch screws. The gap is still at the top, but I think it isn't as great. I might not know more until it gets cold out....that is when it sticks. I can't get rid of the gap completely.
    If it sticks, then I think I have to get a lower sill for along the bottom.
    I am hoping the gap has narrowed, and that will be enough to prevent it getting stuck.
    Thanks again, and you do have a good memory for some things.
    What's the hurry?
    That explains why he’s so anemic looking in that horizontally striped shirt he was wearing a while back.
    Our poster buddy has a friend who fits that description.
    Auto User Guide
    You’re not supposed to get a link on how to do it...they tell you to take it to your dealer. There are lots of fuses involved and it should probably be left to the experts.
    I’ve heard that before and when it comes to finding a blown fuse I am the expert. Anyone with eyes can see if a fuse is blown and if you can’t believe your eyes, a multimeter works too.
    Just how long does it take to change a fuse? A minute?
    Hint: don’t go there.
    I think that's the longest distance in North America, I do remember seeing something around 70 miles to the next service in Wyoming. Along US 30 here in IL there is a segment where it's a little over 40 miles between stations. However if you don't mind a 5 or 6 mile detour there is a small town with one or two stations a bit south of the road.
    It seems that changing a fuse in a Maserati isn't rocket science...you don't need to be a brain surgeon:
    How do I replace a blown fuse in my Maserati Levante 2023?
    To fix a blown fuse, find the relevant fuse in the fuse box, remove the damaged fuse with a fuse remover or pair of needle-nose pliers, and replace it with a fresh fuse of the same rating.
    Big deal, even I can do that!
    Really? Do you have either of those high tech tools?
  • MichaellMichaell Moderator Posts: 268,792
    On I-70 in Utah, there is a 100+ mile stretch with no services.
    That’s not a total surprise but if I had to guess I would have said Wyoming or Montana.
  • oldfarmer50oldfarmer50 Member Posts: 24,630
    Or you go to rural VT.😫
    It isn't me who thinks he's a genius because he can change a fuse in a Maserati!
    And yes, we have basic household tools.
    .....and here's a real life story;
    I lady here had to take her kid to a hockey game that was 100 miles out of town....and then return that same evening. She was in a bit of a panic because her new Tesla has a range of just over 200 miles, on a good day. She was told there would be charging stations at the arena....not sure why arenas have charging stations.
    Fortunately, they had charging stations and they were working and she could plug in her car. But, she goes to other tournaments with her kids hockey and she said she wouldn't buy another EV.
    I am just reporting what my friend told me.
    They see me scrollin’…
    Good, if you have nothing of value to add then just keep going.........
  • stickguystickguy Member Posts: 54,325
    I’m an emergency you don’t actually need a supercharger or charge America station. In an emergency, Just an electric outlet. And last I checked even Vermont (usually) has electricity.
  • ventureventure Member Posts: 3,211
    Skunk?
  • kyfdxkyfdx Moderator Posts: 272,621
    Digging? Or, mounds?
    If digging, yes, it looks like a skunk
    Here's a breakdown of the charging methods and approximately how long each take to fully charge a Tesla from a low battery: Level 1 AC (120V outlet at home): 20-40 hours. AC Level 2 (Third party chargers/Tesla chargers/Tesla home charger): 8-12 hours.
  • graphicguygraphicguy Member Posts: 14,242
    OWNER’S MANUALS…..I don’t think I’ve cracked one open in 15 years. Even when the sales man wants to go over features/functions of my new ride, I dismiss him. Part if it is because I pride myself in knowing tech. The other part, I’ve had so many Honda products I have a really good feel about their tech and engineering.
    FUSES (and flat tires)….Last I can recall ever changing a car fuse or had a flat tire was on my early ‘80s Trans Am. Tire blew one week before the fuse (for the lights).
    MASERATI….If memory serves, I found a great deal on a slightly used one owner Quattroporte and I let you guys talk me out of buying it. Probably the best advice I ever got from all of you!
    When I was looking up fuses and Maserati's I was surprised at the problems drivers were having with their cars, especially Ghibli's. A lot wouldn't start because of blown fuses. I guess they tell you to take them to the dealer for some models because then they can maybe solve the problem that causes the fuse to go.
    I am glad you didn't by the Maserati.
    missing the point. you don't need a full charge. same as running out of gas on the highway. The truck does not bring enough to fill your tank, just enough to get you to a station. So in a Tesla, if you died 10 miles from a charger, you only need about 20 miles of electrons to get there (with a cushion)
    there are also apps (or were in the early days) that list personal chargers you can use. Not 100% sure how it worked (if it was the community helping each other out in the early days, or a way to make money renting your charger). But even if you are not near a formal charging station, very likely you are near a charger better than plugging into a 120 outlet!
  • roadburnerroadburner Member Posts: 18,614
    You can’t fix stupid.
    Conversely, here is a friend’s EV experience:
    “The supercharger network. There's superchargers galore. The car 'finds' one for you, when it senses the destination is further than what you have left in the 'tank'. When I first got the car, I also kept a list of plugshare sites, but never had to use any.”
    I never said I was a genius but compared to some I’m pretty close. :p
    I’m sure you have a hammer, screwdriver, a pair of vise grips and for the tough jobs, a bigger hammer. BTW, which one did you use to fix your sticking door?
    If you’re relegated to that I suggest you pack a lunch, dinner and bring along pillows and some blankets. But if you want to rough it, sure.
    You can run out of gas in the boonies too, when the rare stations are closed on a holiday. I came within fumes of that once.
  • ab348ab348 Member Posts: 20,720
    Can we pivot this board to talking about appliances again? Geeez, guys... :/
    Yes. Digging. I put down something that is supposed to kill grubs and a myriad of other not very desirable insect-like creatures. It rained yesterday. I want to see if it has spread tomorrow morning.
  • sdasda Member Posts: 7,741
    The light bulb on the micro-wave that shines down on the stove burned out again. I think it burns out 3-4 times a year. I tried one of the micro-wave LED bulbs but it doesn't dim. Perhaps the newer ones do? Anyhow it is a pain to replace. There is a very small phillips screw to secures the glass cover that is tedious to fasten without dropping it.
  • tjc78tjc78 Member Posts: 17,509
    Most LED bulbs say if they are dimmable or not. I’d wager those specialty ones are not in most cases. You would think by now they are.
    venture said:
    Skunk?
    I had a skunk in the house once. It’s a looong story but it ended well. I tell just a little bit here:
    Came home from helping a friend move into his first home one Saturday at about 8 PM. Had to put the kids to bed. As I’m coming out of the bathroom I hear ticking. I look down and there it is, a skunk walking into Son #1’s bedroom. His room was the only room in the house that still had the uncovered hardwood floor. He continues to go under his bed and camps in the corner. I had just put wallpaper in his room and the travis rod was still under his bed. When I reached for the travis rod to coakes him out the plastics piece’s rattled and he started to move. I kept rattling the rod and eventually he came out from under the bed and causally and I mean causally walked down the hall then dashed out the propped open front door. What a relief.
    Believe me, this is the short version.
    I had that problem. The original incandescent bulbs lasted forever but eventually failed after many years. I decided to replace them with LED ones from Amazon because those were much cheaper. Mine has a regular and a dimmed mode. The LEDs would work in either, but would flicker when in dimbulb mode. Undimmed, they were quite bright. I found some dimming film called Lightdims that I had bought for another application and that solved the problem once applied to the inside of the lens.
  • imidazol97imidazol97 Member Posts: 27,787
    X2
    I replaced my Whirlpool microwave bulb with one I found on the internet by cross-indexing the
    plug type and size of the original incandescent
    . It works on both regular and dim.
    IIRC it has about the same brightness as the original.
    Maybe I was just lucky.
    I found this article about Oldsmobile's place in development of features in US autos.
    https://www.autoevolution.com/news/20-ways-oldsmobile-revolutionized-the-car-industry-221159.html
    Yes, it is a Whirlpool.
