that better be it for snow for the year. and having a garage where you can't fit the cars and the blower really stinks. Especially when it lives way at the bottom of the back yard, and you don't plan ahead to leave a car out to make room, and bring it up when you can easily.
Wholly cow!
Do the V8s have any recalls?
No, just the 3.3 L V6 twin turbos in G80’s and G90’s.
The part I don't like to hear is:
OIL LEAKING ONTO THE EXHAUST MANIFOLD. OIL LEAKING ONTO THE EXHAUST MANIFOLD CAN INCREASE THE RISK OF AN ENGINE COMPARTMENT FIRE.
REMEDY NOT YET AVAILABLE
:Recall Incomplete
They had an interesting story about how it will be impossible for manufacturers to meet EV standards on time, and that EVs aren't selling very well. Even the head of Hertz quit as he gambled on buying EVs as rentals but it was a bust. Also, it seems that EVs probably cause more pollution than gassers over time......
EVs don't work very well in Canada because electricity is expensive, and the cold weather drains the batteries. It has been a real problem with buses and particularly school buses.
The readers comments are really amusing, and I LOLed at this one;
Nothing is more funny than watching my neighbor during a 12 hour power outage charge his 2 EVS with a gas operated portable generator. I still laugh my a-- off.
*(Disclaimer)I am just passing on what I read.......not making any judgements.
Unfortunately I fly back home on Thursday, going from 80 to mid 40sF
I heard Tom back down in Philly just floated away, with about 3 inches of rain out of the storm. Most areas down there don't tend to be able to handle that volume of rain. Snow, once you shovel or blow it, is just piles to the side that don't bother anyone. Instead of flooding roads and houses!
Being deported has to suck but I know you had a warmer Winter than most of us in here.
Come Thursday I’m not sure who will have the last laugh.
If you lived in the Johnstown PA area you wouldn’t say that. They got hit with at least 3 major floods over the last hundred plus years.
That phev Hammer will get a look from me, too.
But, as I mentioned earlier, by picking it up, I get away from work tomorrow for a bit and I'll have a leisurely lunch while getting a free tank of zap.
I’m beat… this was don’t call the guy weekend.
Projects completed (had help from my cousin with his union Steamfitter truck of tools and supplies for 1-3)
Shore house -
1 - Installed new pull down faucet, garbage disposal and new drain piping
2 - reinstalled slop sink in laundry room. Deferred project from new floor install (new tile was higher than old)
3 - Hot water washer hose was leaking ever so slightly and was fuzed to the valve. I sprayed it for weeks with penetrating oil to no avail. We eventually got it to spin and it was actually part of the valve and not the hose. Hot water was spewing everywhere … luckily the shut off valve on the water heater was right there. Had to cut an access panel and put in a new valve with a short piece of copper. My cousin had a Propress gun and Viega fittings on the truck. Made it much easier.
Home -
4 - fix soap dispenser in kitchen (was loose)
5 - change outlet behind couch to a recessed outlet since the lamp plug kept getting messed up.
6 - installed third camera over garage. Of course I didn’t have a long enough drill bit so a Home Depot run was needed.
I wanted to wash the cars.. but I’m done lol
Pics or it didn’t happen, right?
Backsplash is getting done tomorrow! Can’t wait to be done.
@jmonroe
I know you won’t approve of the wimpy garbage disposal but we don’t use it that much.
Ok but where is this recessed outlet you speak of?
A friend was VP of a fairly large mechanical contracting company and, when Sharkbite fittings came out, they had to estimate jobs using both Sharkbites and soldering. Many times the savings in labor outweighed the cost of Sharkbites, even when relatively new.
I’ll have to check out such outlets. Could use them in a couple of places. Thing is, I usually find I can barely squeeze an outlet into the box with all the wire that goes along with it. This must be doubly tough, no?
Goes in tomorrow
I had two 14’s in there with a ton of extra wire and I got it to fit without much hassle. Had to really make sure everything was folded in big loops so that it took as little depth as possible.
I would not recommend if you have 12 wire in the box.
Yeah soldered fitting are becoming a thing of past slowly but surely. With most new homes becoming all Pex and the ProPress tools coming down in price there is no reason for a pro not to have it.
Shark bite snap in fittings (have to be careful as Sharkbite manufacturers much more than that) work well but I wouldn’t have them in my home unless it was a temp repair.
I don’t allow them on any of my jobs for work. There is a clause in the SOW prohibiting the use of them.
@qbrozen
Leviton 689-W 15 Amp 1-Gang... https://www.amazon.com/dp/B0012DKBL2?ref=ppx_pop_mob_ap_share
I almost always sweat fittings in my house. There was a time I used a Sharkbite when it was especially tiresome trying to solder it. I check it occasionally. It's still good after, I forget how many years, but it's been a long time.
you list made my recaulk 2 baths and the kitchen, and wood fill. sand and paint some damaged trim pieces look tame. But I did not have a pro with a truck full of tools to help out!
Hey, I have a topic.
Wife has made mention that the older son gets a bit neglected due to all the sports the younger one plays. Many weekends for a couple of years at the baseball field, etc.
Older one has been pushing more and more about cars and racing talk. So I started searching for some kind of driving-related vacation. The racing programs I have found thus far are stupid expensive (we’re talking 5 figures for the 2 of us for 3 days). A long time ago, I had stumbled across this place that was offering a vacation in Europe where you convoyed in BMWs for like 5 or 6 days to various hotels and driving spots. It wasn’t terribly expensive. I have not been able to find it again. All similar ones are called “luxury tours” or some such nonsense and are, again, stupid pricey, and amount to someone handing you keys and a programmed nav.
Maybe we should just build and race a Lemons car. I dunno.
Thoughts? Experiences?
I’ve done the Xtreme Xperience a few times. Supercar you get to drive on a track. Don’t know if there is an age limit, but ridealongs are available. They go all over the country, so I’m sure there is something close. Only a few hundred dollars for 3 laps. Can get a photo and video with telemetry info.
And PEX tubing is going to replace copper tubing altogether, at least for homes. I remember when plumbers laughed at PEX and looked down at it. Said it was for home owners who didn’t know how to sweat copper. Now plumbers have no problems using it and they’re not bashful about saying so. Same goes for using stainless steel flexible gas lines vs. black pipe. Times are changing.
I’ve seen some pretty high end new homes around me that are done using only PEX and flexible gas lines. Which leads me to ask, @stickguy, is your new home plumbed with PEX and flexible gas lines. Just curious.
(1) I like the awareness and sentiment. Good on you both for recognizing it.
(2) if you’re going to spend 5 figures, why not buy a car on the west coast and do a cross country road trip? Maybe something you fix up or customize once you get back?
(3) Why not split off and take turns with the younger one on weekends while the older gets some time? Like the car project idea. Maybe fix up the Dodge?
My house is six years old and is all Pex and flex gas lines
#2....great idea!
Having recently seen it open and roughed in I can confirm it is blue and red tubes running all over. When I see it again this week I will check on the gas lines. That I don’t recall.
3. He claims to want to do the work but walks away very quickly. Like working on his Opel this weekend: after an hour or so, he claims he is hungry. Went to get some food and never returned.
On a more realistic note, my son and I have attended numerous events at the BMW Performance Center in SC, and I highly recommend it.
Ouch! I’m having a mild heart attack over our 15K Turks and Caicos vacation (for 5 people!).
How about taking your son to a go kart track to see if he actually likes racing?
I went to one in CT a few times with some guys that were BMW Club instructors at LRP.
After they lapped me, I thought I'd just follow their line to how to improve my times.
Coundn't even keep up with them trying that.
https://www.superchargede.com/welcome/
but that place looks cool. Will have to check that out.
If we did not have friends who reside in the Orlando area to stay with, we would have been one and done as far as visits go.
————————————————-I have a question for you since your house has PEX. Did your plumbers use the stainless steel Cinch Clamp Rings or the black anodized Copper Compression Rings? We have used only the compression rings and have never had a problem with those. However, the plumber we’ve used to do the heavy work to break up the concrete basement floors when we’ve installed bathrooms down there, said he likes the stainless rings because they’re a little cheaper and a lot easier to cinch than using the compression rings.
I have to admit using the compression tool does take some work but maybe it’s a good way to get in a little. exercise.
2013 LX 570 2016 LS 460
1. Threw out my back sleeping, tweaked my neck sneezing, so I'm probably just one strong fart away from complete paralysis.
2. Dear paranoid people who check behind the shower curtains for murderers. If you find one what's your plan?
3. Anyone who says their wedding was the best day of their life, has clearly never had two candy bars drop down at once from a vending machine.
4. Just once, I want a user name and password prompt to say, "close enough".
5. Weight loss goal: To be able to clip my toenails and breathe at the same time.
