Mystery car pix
1145014511453145514561479
  • fintailfintail Member Posts: 58,874
    Easier and later, a few cars at Hawthorne and 37th in Portland, late 80s, zooms fine:
  • kyfdxkyfdx Moderator Posts: 272,501
    Accord Hatchback might be an '84, with that rear wiper, and slightly less rounded rear hatch corners.
    I had one the same color ('82)
  • stickguystickguy Member Posts: 54,312
    RWD Corolla lift back. I liked those in SR5 trim. In front of a sad looking red tempo. Subaru GL behind that.
    edited February 2025
    Behind the Corolla is an 84-85 Topaz - I am leaning towards 85 at it appears to lack the small bumper guards often seen on 84s. In front of the motorcycle (Honda?) looks like an 85-88 Maxima.
    that does look like a square body maxima. And how could you tell that was a Topaz, and not a Tempo?
  • texasestexases Member Posts: 11,207
    Topaz has those tall tail lights
    Yep, from that angle Topaz has different taillights and Tempo has a window in the C-pillar where Topaz does not.
    Rochester PA, 1985, zooms fine - this is the material and kind of scene i remember from childhood:
    white later model barge Toronado. white rabbit behind a Citation hatchback.
  • laurasdadalaurasdada Member Posts: 5,302
    One pill made it smaller...
  • tmarttmart Member Posts: 2,427
    Bunches of FoMoCos. Hope this works.
  • explorerx4explorerx4 Member Posts: 21,117
    Matching 56 Oldsmobiles in the bottom 2 rows on the right.
  • andys120andys120 Member Posts: 23,689
    '59 Merc next to a '59 Ford in the bottom row. Not a single import, no Beetles, Dauphines MGs or Minxes.
    8 rows up center right I see a 58 Ford Sunliner - the non-retractable convertible. Lark wagon at lower R, image must be 1959 in Dearborn or similar as nothing looks newer.
    On the right, a little more than halfway up, a 56 Mercury.
    From the mall pic, the exotic is the MB W116, likely a 450SEL. I also see Nissan 200SX in both notchback and hatchback form. In the lot full of Fords I also spot the oldie of the group at upper left, appears to be maybe a late 30s Mopar.
    A scrapyard in Shrewsbury, almost 50 years ago (March 1975) zooms fine, several to be picked out by the observant:
    white bedford van?
    I see a big white Volvo, probably on one of the scrapped vehicles, by the lighter brick building.
    Also a couple of cars closer than the building on the right, a white coupe I can't identify.
  • roadburnerroadburner Member Posts: 18,610
    Fiat 500
  • bhill2bhill2 Member Posts: 2,639
    Lower right, a Triumph Herald with a seriously crunched front end.
    I see the Volvo P1800 next to a 105E Anglia in the back rightmost area near a shed type garage, I don't see another.
    White van in the middle, with a sliding window, is a Bedford, yes.
    It might be an illusion, between the wrecked Herald and Fiat looks like the rear of a Spitfire with a motorcycle grafted on to the front. Lots of ADO16 cars in the mix too.
    Gibsons BC, 1978 - image has some weird qualities/artifacts when zoomed in, but should be several to ID:
    If the C/K blazer is still in as good condition it will be worth quite a bit!
  • autonarrautonarr Member Posts: 9
    While researching the story of the Manta cars (not Opel, the U.S. based fibreglass kit cars from CA) I stumbled upon these two photos below. They are shown on the GERMAN Wikipedia site and claim to be of a Manta Montage.
    I doubt that this is true. The car depicted resembles one of many VW beetle based kit cars of that time. I can identify the rear lights as belonging to a (GERMAN Opel) Manta A from 1970ff.
    Yet I do not know which company made this fibreglass car? Google search reveals false answers, as wrong as the Wikipedia article about Manta cars itself.. I do admit that A LOT of kit cars back then looked alike, resembled the popular race cars of that time.
    Anyone?
    Hint: not a production model
    Definitely has a GM look to it
    I'm guessing a Camaro concept before it got the name Camaro.
    it looks like a blend of a Chevelle and a Corvair, made in Australia.
    But LHD
    Pretty close. A US based concept using the Corvair chassis but using a front mounted six cylinder engine and rear placed transmission from the Tempest.
    Bringing up the rear in Taylor MI, 1971, should be some goodies to pick out here, zooms fine:
    '67 Valiant next to the '69 Chevy
    A late Studebaker 7 cars in from the right?
    I’ll claim the Country Squire.
    might be a white Ambassador next to the country squire.
    May I repeat my request to identify this odd fiberglass kit car from the early 1970s?
    I do NOT believe that it is a "Manta Cars Montage" as claimed, as the U.S. Manta did not use German "Opel Manta A" tail lights.
    Nobody knows the answer, really?
  • gsemikegsemike Member Posts: 2,464
    A lot of Fords
  • sdasda Member Posts: 7,737
    Black Studebaker next to 68 and 69 Fords.
    London roughly 1980, zooms fine:
    Citroen (CX?) in front of a MB SL.
    Sigh. That Mercedes sedan is the same color as ours was.
    @fintail
    In Shrewsbury - which is actually a very pretty little town generally - it isn't always this grotty - there is a replica of my dad's old Vauxhall FC 101 Victor Estate - ours was the same two tone green colour too.
    It isn't ours though- he bought it in 1965 and it was still running locally in 1984 which was quite good for a Vauxhall in Wales... (all that road salt)
    @fintail
    In London that white car in the foreground is the Vanden Plas version of the Austin Allegro which was known as the Vanden Plas 1500.
    You know, you could always get another one! B)
    Yep, and in front of the Renault estate driving away appears to be another CX. Sleek futuristic cars for the era. Looks like a Datsun Cherry in front of the Vanden Plas.
    magnette said:
    @fintail
    That scrapyard is like another display of period Matchbox cars (Matchbox had a Victor estate like that)
    For those not having login issues, here we are at Disneyland, can't be before the spring of 64 anyway, zooms fine and a lot to see:
    I’m surprised how old those cars are, compared to the ‘65 Mustang.
