Visitor Agreement.
Department of Transportation.
https://x.com/ODOT_Statewide
It may be a couple articles down the list. Shows picture of interstate with oncoming traffic heavy in of Columbus south on I71 and northbound traffic light. Watch about 1/3 of the way into the video as red van stops in middle lane. THEN LEAVES AFTER CAUSING A LOT OF DAMAGE.
The process involves refilling the IGU with insulating gas, typically argon or krypton, and repairing or replacing the seals. This may seem like a quick fix for fogged-up windows or reduced insulation, but it’s not a permanent solution.
Short-term savings
One clear advantage of regassing and resealing is cost. It’s usually cheaper than replacing the entire IGU, and for homeowners on a budget, it can seem like a reasonable option. Additionally, it may have environmental appeal, as it avoids the waste associated with discarding the whole unit.
The reality of durability
However, the longevity of regassed and resealed IGUs is limited. While new IGUs are built in controlled factory environments, regassing and resealing is done in the field, where it’s impossible to replicate the original sealing conditions. As a result, most resealed IGUs only last 3 to 5 years before the seals fail again. In contrast, a new factory-sealed IGU can last 15 to 20 years or more.
****It sounds like a good fix if you are going to sell your home in 3 to 5 years........how many buyers ask when your windows were replaced.
https://www.stuff.co.nz/humour/360675374/car-stops-highway-causes-pile-then-drives
I was going to a doctor's appointment (don't get your hopes up moderators, it's nothing-life threatening) and was in the center turn lane to cross opposing traffic to enter the medical center. When I turn in I notice a rusty F-150 stopped just past the entrance (to my left). As I pull in to the entrance I notice that the idiot F-150 driver has her backup lights on because she missed the entrance. The dimwit is heading straight for me- even though I blew the horn. I floor it and she just misses me. My wife later watched the driver get out of the truck and said she acted spaced-out. I was driving the Jeep- which is why I said I almost was charged with assault. If I had been driving the C43 or Club Sport I would have been charged with murder.
@ab348 would probably refer to this as a “worthless Canadian warranty”.
That’s true. When the window seal is broken, the argon gas is lost. As a result, instantly the ambient air enters the space once occupied by the argon gas. This ambient air has moisture and when the temperature conditions are right the moisture in the air condenses on the inside surfaces of the glass panes and this is what you see. Eventually it will even look like fog.
https://hamilton.windowrepaircleaning.ca/window-repair/
Maybe you should get the company to fill the replacement units with krypton gas. That apparently has sound deadening properties that argon lacks.
https://media0.giphy.com/media/v1.Y2lkPTc5MGI3NjExYmc2czFpejM0cWFyeWVwNTgyeHVueDFnb2pybWpldGUxbzdpeXJleCZlcD12MV9pbnRlcm5hbF9naWZfYnlfaWQmY3Q9Zw/13PVtc14fuW3y8/giphy.gif
@driver100
I think the red van needs to charged as well as the silver passenger van that hit the rear end of the stopped vehicles.
Is one that sticks to the windshield and hangs from the mirror that will work?
I need the phone up front to watch Waze/Google maps when driving . The last trip I tried to use my GPS and I am sure it actually was more confusing than a help.
For mounts, if you have vents high enough, you can try a vent clip mount. I would not want something hanging from the mirror (plus it seems like it would block vision). How about a stick on for the dash if you don't like it on the window?
Edit: Found a picture of the Malibu dash. With the vents right up at the top, should be perfect for a vent clip mount. Phone will be at the right height, and not block the radio screen.
I like the vent clip mounts, if they fit your vent.
Does this help?
Benefits of Argon Gas in Windows
Are you tired of windows fogging up or developing a cloudy appearance on cold days? This is a common problem caused by moisture getting trapped between window panes. Over time, the seals on traditional windows deteriorate, allowing air and moisture to seep inside. Condensation clouds the glass, obstructing your view.
You can avoid this problem by using argon gas, which doesn’t contain moisture. The gas helps maintain a clearer view and reduces the likelihood of condensation and frost forming between panes, especially in colder climates.
Stuff happens!
A Tesla electric vehicle fire that started just after 9 a.m., Saturday, led to the Hwy. 403 closure of all westbound traffic for several hours between Hwy. 6 and Main Street West.
As of 1:30 p.m., Ontario Provincial Police Sgt. Kerry Schmidt told the Spectator debris was still smouldering on the roadway, but the vehicle was on a tow truck. He said police hoped to have the lane open soon.
No injuries have been reported.
Schmidt said the fire was prolonged because the vehicle “kept reigniting” and this is a hazard with E-vehicles and E-bikes as well.
After looking at nearly 100 Carfax reports, in searching for a used vehicle, roughly 95% did not meet recommended maintenance requirements...at least at businesses that report to Carfax. Many were leased, many were rentals, many were people who probably just didn't give a dang. And these were mostly for sale at dealerships.
But the owner of this vehicle, I just came across, should get an Edmunds award. This is probably the best maintained vehicle, by a single owner, over a period of 17 years, that I've ever seen. 52 service records. Oil changes every 2k, 3k, and 4k miles...plus all other maintenance items.
https://www.carfax.com/vehiclehistory/ccl/KLXFEcjjdPSe7gI92hNS1r_BHAsyEEdU6okoVtWIVxlgfzmgo893Ktai_mT_3RYsm_6i0g7sguG8OpaIm5e9b5Fatw03rEvGaI4bY0DM
Yes, but I did write, "at least at businesses that report to Carfax."
If I'm buying someone else car, I prefer to have proof of maintenance. Rentals are always out. Leases, maybe with written records. People generally take better care of cars they own.
Oh I agree, written records are a big plus when buying a used car but in all my used car buying I never once had a seller (private or dealer) have any service records. I have always given any buyer of my cars a complete package of service receipts but that the exception rather than the rule.
It’s not real or AI. It’s made for the internet.
Moving my daughter out of her dorm. Here’s one for @roadburner
Thursday night felt inordinately tired early in the evening. Unusual for me but I went to bed bout 9:30 p.m. Developed a blinding headache. Started feeling dizzy. Shortly thereafter, I realized I couldn't move and then became very nauseous upchucking all over the bed. Freaked, because I couldn't even say " Siri" to tell my iPhone on the night table to call 911.
I remember thinking, I have a brain aneurism. This is it. This is how my lights are turned out. I don't know the amount of time that transpired, but I remember time not being something I was aware of. Finally, I was able to yell "Siri dial 911". The speaker on the phone came on and I heard a dispatcher. Don't know how I communicated, but I was able to tell them I needed help because I couldn't move. They told me my address, which I confirmed with a weak "uh huh". ...fire truck, ambulance, the whole shebang with lights and sirens penetrated the house.
My doors were locked. They asked me the code to my garage door but I couldn't communicate that to them. Not sure why. They ended up busting in the front door. I "Squeak-yelled" my location (upstairs and to the rear of the house). They tried to get me on a gurney but was dead weight as I still couldn't move. Another EMT person helped put me on a gurney, asked me questions (which I could not answer). One gave me some sort of IV (they told me what it was, but they could have well just said it was peanut butter as I don't recall). Loaded me up, and while they were doing so, I remember seeing all the lights from the firetruck and ambulance lighting up my cul-de-sac. Remember neighbors kind of hovering around.
I do remember the bumpy ride to the hospital.
Got there, again more questions that I did not have the capacity to answer. Drs (nurses) swarmed, machines were hooked up to me. Lots of whirs, buzzes and beeps ensued. I recall getting a shot in my belly (later found out it was a drug to dissolve blood clots) At some point, my son showed up. He later told me he freaked that he got a call from the hospital as he's listed as my emergency contact (something I listed a long time ago and forgot about).
Finally got my speech back. Still was wobbly all day Friday and could not stand. Saturday, they got me sitting up in a chair. Yesterday I started walking and was discharged last night.
Diagnosis? Combination of "mini stroke" and "vestibular vertigo" combined. As best I can tell, I'm walking OK, at least not wobbly. Little direction corrections I notice I have to make. Headaches are 1/10th of what they were but still there. Speech is getting better and better, to the point my son says he can't tell a difference (although internally I can tell I'm putting a huge effort in to say certain words). I think my son maybe trying to minimize my concern. Obviously my fingers work as I'm. typing this.
They (Drs) say with therapy and meds I should be "OK". Therapy starts today in home. They don't want me to drive until the therapists give me their battery of tests and clear me.
The majority of what transpired Thursday/Friday I don't remember. They said that's not unusual. Hell, I could have bought a new car and don't remember. I should probably look in the garage to make sure.
Scared the living s#!t out of me but I'm still here to tell the tale. Feeling quite fortunate as a matter of fact.
Glad everything has worked out for you, so far. And yes, that's quite the scary tale.
Best wishes GG.. hope they get you back to form quickly. Scary stuff
Very scary. Glad you were able to summon help. Definitely a downside to living alone though. Hopefully the treatments do the job.
My dad had a stroke a few years ago that scared us all, but after a few days in the hospital and meds he bounced back and no lingering effects.
I did not realize your iPhone could tell 911 an address. I thought that was something that didn’t happen but maybe that was the old days.
The wireless carriers have to transmit enhanced location info to 911. Also if you’re connected to WiFi and WiFi calling on they can find you that way as well. When you turn WiFi calling on you have to input an address.
Details are sketchy over the course of that time. Some I remember, some I remember bits and pieces, some I don't remember at all (and was relayed back to me later).
Good grief! I never heard a story like that. Glad you are around to share.
