Visitor Agreement.
Best Regards,
Shipo
I have checked out "toptiergas" and "amsoil". Amsoil looks like great stuff, but what about gas? Is Chevron the way to go? Any test data on actual MPG studies and deposit teardown investigations? Why do I get my best mileage from Hess? Maybe I need to add "Techron" to Hess gas??? I need more info!
I have a new care and want to give it the best I can. I just need some real data.
Phil ~
The "red flags" for me were a) higly inflated claims of results, b) VERY strange science and c) the MLM scheme.
The only way to test this stuff would be something like this I think:
1. Find two identical cars
2. Run them both with no additives on the same daily routes for 1,000 miles and record their average fuel mileage or each vehicle's "baseline".
3. Then put the additive in Vehicle A but not Vehicle B. Do NOT tell the drivers which engine has it and which doesn't. Drive each for 1,000 miles and record the average fuel mileage as compared to when they didn't have the additive.
4. Now SWITCH the additive to the other vehicle, again, telling neither driver what was done, and record average fuel mileages again.
If there was a10% jump in fuel mileage when the additive was added, and a 10% drop when it was drained out or not used, and also in spite of the variance between the two vehicles "normal" fuel mileage, each one increased/decreased 10% from their normal baselines, AND the driver's were "blind"---then I'd TEND to be a believer**
I say 'tend" because then I'd want a test with longer mileages.
So what I'm saying is that if you bought this stuff, drove 1,500 miles and told me you got 10% better mileage, that would definitely not make me a believer. That's not scientific enough.
Amazing, isn't it?
It's just my opinion. I may be wrong.
diesel ) I have used this & seen cars that drop emissions ( co & hc ) and up the
mileage 3 mpg . I am still testing this additive . Caution it will remove paint .
Again, any additive that could deliver 30% mileage increase would be the salvation of all mankind,the solution to the world's energy crisis, and an immediate sell-out in every store in the nation.
Unless of course it doesn't work.
The more effective your engine is at vaporising the fuel, the more efficient it will be. That is why every vehicle will have different results and a different best mixture ratio. Depending on how efficient your engine design and what condition it is in. The more efficient your engine is, the less improvement acetone will give you.
Acetone is available from most hardware stores, about 2 cents worth will treat a gallon of gas. In a pinch you can buy small quantities at a drugstore. Add between 2-3 oz per 10 gallons of gas about 2oz for diesel. Establish your baseline MPG over the last 1500-2000 miles of pure gasoline. Start at 2oz per 10 gal for the next set of 1500-2000 miles. Increase it in increments of about a quarter oz for each set upto a max of about 3oz/10gal. More is not better, improvements in MPG will sharply drop off after the max. Compare the results to find the sweet spot for your particular vehicle.
Store in small, well sealed amounts in your trunk, measure it away from the vehicle to avoid dripping on your paint. Be careful around man made fabrics, you don't want to dribble it down your polyester pants. Maybe wear gloves to prevent skin contact. But don't panic if you do get a little on you, women have been using it for the last 50 years or so as nail polish remover.
I am currently in my 2.5oz/10gal test set with a 22% improvement in MPG over my baseline. I am driving a '95 Pontiac Grand Prix with an EPA rating of 19/29 MPG, I'm getting 30.55 MPG mixed city/highway about 30/70.
Also stay away from gasahol, the alcohol will cancel acetones benefits. I had to restart a test set because I got a partial tankfull up in Michigan. Badstuff, even without aetone it gives you lower MPG than regular gasoline.
Why don't more people know about this, well, if you were an oil company executive would you want to reduce your annual sales by 20%? So as the fuel expert your NOT going to say it works. If your are a car manufacturer, would you want engines to run cleaner and last longer between new car purchases?
These "unbiased experts" have said that this very diluted acetone will damage seals and o-rings. However, even after soaking in pure acetone for a year, there is no measurable damage to these parts. If it can standup to gas it can handle acetone.
Give it a try.
how about putting two ounces of new orleans floodwater in the tank? there are enough petrochemicals in there that it Just Might Work.....
Are you saying your tank, pump, injectors, fuel pressure regulators have all been checked and there IS no damage?
The Oil industry doesn't want to lose 20% of their sales.
The Auto industry wants to sell new cars and parts, not tell you how to make them last longer.
The Government taxes you by the gallon not the mile, they stand to lose as well.
There are always people who are willing to try new things. Yes there will be failures, but that is no reason not to keep trying. The people who succeed the most are usually the ones who have failed the most in the past until they found what worked for them. Not the people who stay back in the nice safe herd and never try anything. Not the people who never take a gamble. Not the people who wait for some authority to say it is OK for the herd to move. The grass is always greener for those in front of the herd, before everyone else has trampled all over it.
But that's OK for me. Now that I have found something, I am more than willing to have an economic advantage over my competitors in the herd. I was willing to risk practically nothing by testing this in a 10 year old car with over 187 thousand miles on it. Now I can leverage what I've been willing to learn, by that tiny risk, to save even more money with the small fleet of vehicles I run in my business. A business I have been able to build up because I was willing to try something and not just stay in my nice safe computer job. The computer job I had because I was willing to take the risk back in the seventies that there would be a demand for these skills. I could have played it safe and worked for my dad's little business and I would be getting by on about 30K a year just like my brother did. But I choose to take careful risks and try things out.
And I thank-you for staying back in the nice safe herd and encouraging others to stay there with you. You are helping those of us willing to take a chance to get ahead in life. And by the time the herd catches up to where we are now we would have moved ahead even further to even greener pastures.
So stay there in the nice safe herd, eating your nice safe fodder. But every once in a while you may happen to look up, maybe to shoo away the flies that follow the herd, and see me off in the distance standing in a fresh stand of tall lush green grass. And if you look real close you may even see me waving at you, but of course your so far away you can't tell that I'm really just thumbing my nose. :P
Folks can believe what they want, and even fool themselves by allegedly performing self tests, but unless there are a number a truly scientific studies proving out the efficacy of this or any other fuel additive, most folks will wisely ignore such claims. Of course, the flip side of all of this are the numerous studies that have shown little if any benefit of acetone being added to fuel. Check where you will, http://www.sae.org, http://naca.larc.nasa.gov or any other site that publishes scientific studies and you will be hard pressed to find any concrete evidence indicating that acetone will improve fuel economy, in fact with a little digging; you will find information quite to the contrary.
Best Regards,
Shipo
Go to this website and match up the compatibility of "Buna N" (nitrile), which is used in a lot of fuel systems seals and o-rings, and "acetone". You have to choose one from each table to get the compatilbilities.
http://www.coleparmer.com/techinfo/chemcomp.asp
Just checking around various sources, the general consensus from people with credentials in chemical engineering seem to suggest that putting acetone in your engine is borderline suicidal.
Also I saw this funny post on another forum:
"I added this to my gas after installing a Turbonator in my intake, my mileage has gone up SO MUCH that I am SELLING GAS BACK TO THE COMPANIES."
"Selling gas back to the companies." I love it!
Best Regards,
Shipo
If it IS a major component, acetone is going to kill your car for sure, for sure.
That I have a 10 year old car with 187K miles on it, way past it's life expectancy, that is worth maybe a thousand bucks.
That since I starting testing with acetone, it runs smoother, has better acceleration. The carbon buildup on the plugs have gone away. The exhaust smells cleaner. That if anything I am driving a little faster than I was before. And I'm still getting a consistantly measurable 22% improvement in milage.
I'm not going to pay thousands of bucks every 20K miles or so to have everything checked on a cheap old car. With the miles I put on a car every year, with $3 gas prices, I am saving half the value of my car every year. And in the old beater pickups I run in my construction business I save over there value in gas savings every year. Vehicles that should have died by now, but instead are all running better now than when I first bought them. And I've gained a level of confidence by success in my older vehicles that I am willing to try it out in the newer ones as well.
The Auto industry isn't going to spend millions on research so that they can sell fewer new cars. The Fuel industry isn't going to spend millions to cut their sales by 20%. The government isn't interested in reducing their gas tax income.
Besides, all these parts are metal and plastic, right... Well guess what, acetone is stored in it's undiluted form in metal cans and plastic bottles. The EPA wouldn't allow it to be sold that way, if it wouldn't be safe on the shelf for years and years! When was the last time you heard "Cleanup on aisle 10, another acetone can just fell apart"?
Yes there are altruistic people out there who have checked this stuff. There is a guy out there who has been doing this for over 40 years. He isn't trying to make a fast buck. Those of use who have tried this out and found out that it works aren't going to make money off of you.
You know what... Just forget it, don't try it. Stay there in the nice safe herd and never try anything. That way I will make money off of you, becuase I have an economic advantage. I pay 22% less for gas than you do. That's my snake oil, "Complacency", and the really neat thing is the more I give away for free the more money I make. :P
What did you all think of the link I posted, or have any of you done any further scientific research on acetone in automotive fuel systems?
Or shall we move on to something else?
Best Regards,
Shipo
Best Regards,
Shipo
You would probably find that the largest percentage would recommend Lucas products.
Errr, "recommend one" what? Recommend one brand of Snake Oil? Geez, that's easy, I can probably recommend twenty. The real question is what would I recommend using them on? Answer: "Beats the hell out of me, certainly not any car I'll ever own." ;-)
Best Regards,
Shipo
I would have saved far more than the cost of a few minor parts.
But never mind me, I'll just take my savings and go home, again & again & again....
Funny thing just about everything that doesn't like acetone, doesn't like gasoline either. :P
I keep thinking of Carl Sagan's wise words: "Extraordinary claims require extraordinary evidence".
those are my black helicopters, yup, sure enough ya betcha by golly, then. buy me a cookie
That was NASTY stuff!
Think I'll stay in the herd chewing my cud!
I've got a MINI Cooper and have started to use acetone. Whereas before I couldn't get even 100 miles at the quarter-tank mark (OK, OK, I like to go *fast* when I drive far on the highway, and live in a city where all the lights are always RED), now it gets at least 125, once 152. Read that it increases the octane. Think that I could switch to mid-grade gasoline instead of the high (priced) test?
seriously, while you're more likely to feel less gutty performance on low-test, you could get enough pinging to burn your valves and pistons.
if BMW wanted you to put half-gas in there, they'd have told you so. someplace or another I got the idea that german engineers like to test things to see if they're right. endlessly. but I could be wrong in that....
Would you ask your service manager what might happen with a low level of acetone added to the gasoline of tens of thousands of miles?
I keep thinking there would be a chemical reaction with some of the hydrocarbons in the gasoline and some of the additives to cause a change.
He shared his views on this earlier and I feel the same way!
Every time gas prices spike, these "miracle stories" abound.
**trying to keep my mouth shut***
maybe it's because the shelf is already full and it's spilled into the aisles.
notice that V-Power is only billed in their premium gas line. where the extra detergent is probably needed to keep customers from screaming when the slower-burning premium fuel used in regular engines builds up carbon on the valves.
or I may just be cynical. usually the only "mechanic in a can" that works jumps when you bang hard on the door of the can and tell him/her/it to get their, uh, case back into the shop, the sports page will be the same at lunch.
