Thanks in advance.
-Brian
Sounds like bad tires to me, too, especially since the shimmy and vibration are speed-specific.
If your tires didn't shake with the old ones, you probably don't have a bent rim.
Were they saying ALL the rims are bent!!! Usually people get one from hitting a curb or something.
My wife walked home, and drove her truck back. We jump started the Mustang, but it died after a few seconds. So, with some help, I pushed it home and there it sits.
I think it's the alternator, which is pretty easy to fix. What do you think?
I have a 1998 crown victoria. The other day, the engine just stalled on me while I was driving. The battery light was lit up. however, it started right away.
The same thing happened again yesterday. I am not sure what is wrong. can you help me out and let me know what could be wrong and how to fix it. Thanks, I appreciate your advice.
I guess it could be some kind of computer issue, I remember years ago I had an Escort that kind of did the same thing. It was some kind of ignition module as I recall.
Any other ideas? Thanks!
So that tells me the alternator is not charging the battery. I read somewhere that the alternator has a fuse link to protect it. Could it be that this burned out, or is the alternator really bad, even though it tested good?
Now, my car is due for servicing (45K miles) and will not want to pay a hefty sum of maintenance to those maintenance shops waiting to 'rip' their customers off. In fact, I am also considering a tire rotation/wheel alignment in addition to the usual oil change.
Can anyone please advise me what are the possible causes to the sound and how much will I be expecting to spend on the maintenance/repair?
What if the highest octane gas does not solve the problem? I've been using the mid range octane gas for months but never have such problem.
Thanks for your patience and prompt response. I just want to gather more advice before I go to the mechanic. Majority of mechanics are happy to tell you that the pinging sound is serious. Hence, it helps to have some preparatory advice before I bring my car to the workshop.
Could you offer some advice as to what parts I am looking to replace when I bring the car to the mechanic? Any idea on the range of cost this will incur?
Heavy pinging that doesn't go away will most certainly harm your engine, and can punch a hole clean through your pistons.
My 2001 nissan sentra GXE started having big time performance issues- like not being able accelerate very quickly and making funny popcorn popping like noises in the muffler region of my car. The check engine soon light was on as well so I brought it to my local mechanics who have done a great job for all of my cars.
They inspected the engine light and multiple codes came on. They cleared the codes, took it on a road test and only the 02 sensor & engine lean codes came back. My car had a engine misfire from Cylinder #1 and they replaced the 02 sensor, 4 spark plugs, and cylinder #1 coil and they cleared the codes. They took it on a test drive and the codes did not return. When I went to pick up my car after work as soon as I turned the car on the check engine light came on. I left it for the mechanics to keep working on. They told me that the error was still indicating a bad 02 sensor even thought they had just replaced it. They put another one in- cleared it- drove it and the light came back on- they put in a 3rd new one- drove it for 5 miles and it did not come back on. So I pick it up again and drive home and 6 miles down the road the light comes back on. I brought it back to them this morning.
Anyone else have or have heard of this problem where 02 sensors that are new keep causing the check engine light to come back on?
All of the performance issues are gone since they worked on it the first time- its just that stupid check engine light that keeps coming on, and I need it to stay off because you can't pass emmisions inspection in AZ with it on.
-Daniel
Not sure what you mean by "excessive exhaust" as this could be BLACK like unburned fuel or BLUE like burning oil----those two colors mean two very different problems.
So you'll need to do a cylinder leakdown test to see if you have excessive engine wear and piston ring blow-by, and if not, then a fuel/air analysis/computer scan to see if you are misfiring on one or more cylinders. If you are spewing out unburned fuel, you are going to wreck your catalytic converter pretty darn quick.
I had my two front 15,000 mileage Kumho tires done- both rims passed radial (up and down) runouts were .005 and .008.
the road force with the tires was 17 pounds on one tire - rated as a pass
and on the 2nd tire was 26 pounds, rated "marginal" for the tire but the tire/wheel assembly was a "pass" .
1. are these numbers good or bad?
2. what do you pay for a road force hunter 9700 machine balance? Nissan dealer in So Carolina want $40 per tire (!!) Infiniti dealer wants $35 per tire
The Hunter machine gave "good" and "bad" indications, which you explained in your post. I think you can trust the machine to be objective.
If your rims were measured with the tires still on them, then you didn't get a complete picture of the state of the wheels - just an indication. The best way to measure wheels is with the tires off and then measure exactly where the beads seat.
There is a "quirk" in the Hunter machine where it judges wheels to the same criteria as the tires and the assembly. This means that a horrible wheel will "pass". However, what's important is the assembly value. Just keep the wheel peculiarity in mind when trying to judge the wheels by themselves.
Hope this helps.
I know that 20K later, the wheels and tires are still balanced. This supports my premise that round and balanced tires stay balanced a lot longer (if rotated properly at 6-8 thousand miles).
AJ
On a Chrysler Stratus V6 2.5l model 1995, that we have chage the gearbox, we have electrical probems wen we put he engiene on.
The screen-wipper, the electrical door locking, and all the dashboard don't work.
At time on the dashboard is write "NO BUS"
The engine an the new gearbox work well.
We ave controlled the fuse, wiring, and relay and we don't find problems.
Is someone have an idea.
We serch an electrical diagram of this car. If you can send copy of it it will be great.
Thanks in adavnce, and sorry for my poor english. We are outside US.
Best regards.
Marc
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1e/dc/62/09- 00823d801edc62.jsp
thanks,
-Eddie
So until you find out what is draining your battery, you'd better recharge your battery on a charger.
When I drain and refill my '98 Nissan Frontier with the spec'd amount of oil (3 3/4 quarts), the dipstick always indicates a rather significant overfill. Of course, I change the filter also. Should I go by the dipstick or by the specs? (I've never had this problem with my other vehicles in 30 years of ownership.)
I had a similar problem only one time when I first got the car (9/04) and I put the back window down and it would not go up. My mechanic fixed it (or so he said) but I am wondering if this is related to my above problem with the locks? In other words, my electrical system? I can't imagine why something would not work one day (for 3 weeks) and then suddenly work again, can you?
Any suggestions? I'm about worn out with questions regarding this vehicle. It's only got 29,000 miles on it to date, and I never expected so many problems.
Thanks once again
Candie
I tend to trust the dipstick reading but sometimes you can be fooled, say if the oil pan has been dented. You may wish to check this; otherwise, I'd check the oil level after you've changed the oil and driven for a few miles.
Over-filling isn't great as it might blow out engine seals.
You may want to use the "Browse by Vehicle" feature to the left of this page and see if you can comment on this problem in various Cavalier forums. Try one forum at a time, though, don't try multiple postings.
MrShiftright
anyone know what the problem is?
My 2003 Honda CRV has a "no service battery". The test indicator window turned red
saying "distilled water". The test window comes up, but a mechanic we spoke to said not to put water there. Where do we add the water? :confuse:
The fluid change will cost me about $140 and fuel injector cleaning another 150. Do I need to do this at this stage?
