Visitor Agreement.
California requires at least two VIN numbers to register an out of state vehicle. I have the one on the driver's door. The one on the firewall is illegible. The engine is a swap out, so no VIN there. The one on the right frame rail behind the bumper has been welded over with a bracket. There is no VIN at the bottom of the windshield.
Please help! Is there a VIN on the tranny, transfer case, or differentials? Or somewhere else on the chassis? Where?
Any help is appreciated.
William
Have you owned this vehicle a long time?
You may need to get a bond on this puppy or else California will tell you to take a hike.
a regular auto. trans? Are the things rebuilt, overhauled, or just replaced when they breakdown? Cost to rebuild as opposed to a reg. auto trans?
What does it mean to have it "bonded?" How do I do that?
Why don't you call California CHP and ask them? They often do these inspections and they know the rules. You can call anonymously on their information line.
Bonding means you take out a bond for the value of the vehicle that guarantees the vehicle is not stolen.
I'm kind of surprised they are hassling you if you have the old title. Sometimes one hand at DMV doesn't know what the other hand is doing or saying.
or is following the manual the ok way of changing them.
I don't know specifically about BMW, but I assume they're like any other strut, basically a compressed spring over top of a strengthed shock.
The problem with doing it yourself, is even with the strut in a fully extended position (maximum length), the spring is compressed and is putting tension on the strut to extend it out to it's maximum length. If you just start unbolting things, at some point the parts and spring will break loose and send metal parts flying. You'll loose body parts you would rather have kept for a couple more years.
The strut spring tool, allows you to apply compression pressure to the already compressed spring, so you then can unbolt it from the underlying shock. You put in the new shock, align everything properly, bolt the spring back on, and then slowly undo the spring tool. You can do it safely, but take care and make sure you get all the parts put back in exactly the same rotation that they came off in. A number of vehicles have had alignment problems and had to issue TSB's, when the strut was not assembled correctly at the factory.
When I was at NTB getting tires and had the struts done, the guy had a tool bolted on the wall that held the whole strut, and with one movement of the large lever safely compressed the strut hold all the pieces in alignment, so that he could easily replace the shock. Very slick.
You may want to investigate whether a shop would change the shock out of the strut for you at some minimal price, and then you mount the strut in the vehicle if you want to do that piece.
Also, is that engine an interference type or not?
Chain usually do not have change intervals given, they are good for the life of the motor.
My cooling fans come on for no reason. The engine is cold and the the fans will come on and run the battery down. I've check the resistance on the cooling sensor. It was about 40 degrees outside and the ohms of res. was about 2500, @ about 140 degree's after running the engine for 10 to 15 minutes, it was 600 to 650 ohms. That is about right (Right)!!!! I pulled the plug to both fans and I have have 12.5 volts on the light blue wire on that harness. Is that part of the AC system. I can't find ant wire on the high side of the drier that is that color.
The cooling circuitry for most vehicles has three parts, the control circuitry that determines when to turn on, a set of relays or even an integrated circuit, and the fan motors themselves.
Your fan motors are turning, so they obviously have power and the motors aren't 'frozen' so those appear okay from your description.
The relays are to there, because of the high current draw of the fan motors. Their contacts(points) are capable of handling the higher current draw and arching that can occur when you turn motors on and off. Usually when a relay is bad, it either never turns the fan on, or the fans are always on and never turn off. It is not abnormal for a relay to go bad. I'm not exactly sure of your symptom, because you say they "come on for no reason". If 'come on for no reason' means that they are off, and then they turn on, then your relay is probably okay. If 'come on for no reason' means that the fans are always running (or always running when the ignition is in ON position), then I would suspect the relays. If your fans are sometimes off and sometimes on, then I suspect that the relays might be okay. They are switching back and forth between on and off. You don't know for sure until you meter them out. But the typical relay failure is either 'never turns on', or 'never turns off'.
For the control circuitry, in older vehicles it used to be that the thermostat controlled the relay. Then they wired in circuitry that when the A/C was turned on, it also turned on the relays to the fans no matter what the temperature. In newer cars the control circuitry is typically the engine computer, monitoring vehicle speed, a/c load, electrical voltage, engine rpm, engine temperature, ambient air temperatures, etc.
If your relays aren't your problem, then you will need to get a set of electrical schematics for your vehicle which detail out what are the 'inputs' to the computer that are being monitored to turn on the relay and fans. You could have one of the 'inputs' bad (always calling for the relay/fans to be on), or your computer itself could be bad (misinterpretting the inputs, and turning the relay/fans on when not needed).
Thought of the defrosters and shut everything down inside the car, fans still running with key in off position. Hoping cost of fix was not PMC. Thanks
If you haven't found the solution by now, post here and I'll try and look up the final resolution.
HOWEVER, there is "pinging" and there is PINGING. A very slight, short burst of this noise under heavy load in a high gear might be pretty normal, but if you are climbing a hill and the ping just keeps on going (in other words, not a short, temporary burst) you are headed for disaster.
Cause? Various. Most common:
1. Fuel octane too low
2. Timing too advanced
3. Heavy carbonization of cylinder head or tops of pistons
4. Defective distributor/advance mechanism (depends on the car).
When a 4 Liter pings, it means the bolts holding the intake down have loosen up. This allow air to be pulled into the intake, leans out the mixture, and this causes ping.
Start in the center and criss-cross tightening up the intake manifold bolts. I think they are about 9mm or so. A 1/4 inch drive with flex connector and extensions of various lengths will also be needed. I don't know the torque needed. Just snug them up, you are going to find several that are loose.
This happened on my 94. I bet it's your problem. Otherwise, 4 Liter Rangers do not ping.
You might also scan the car for trouble codes.
Aren't these the same bulbs? Doesn't the same flasher unit operate from the turn-signal lever and from the hazard switch?
Is the flasher unit located where an ordinary mortal can remove it for replacement?
I went to Wal-Mart and got a new 10 amp mini-fuse (I still have a number of regular-size fuses and didn't realize they don't use those in new cars now)
Changed fuse, turn signals work fine. I wonder what caused that fuse to blow. There was no lightning or any other suspicious event near the time the turn signals stopped working
I will still be sticking my head under the dashboard to see where, and how accessible, the flasher unit is
Fuse blew again in turn signal mode.. Since turn signal and hazard circuits use the same flasher module and the same bulbs, I am thinking it must be a connection problem (intermittent short). There are too many wires running around inside the steering column for me to look there. Will take to dealer Wednesday.
If you have a story to share, please respond to jfallon@edmunds.com by Friday, May 15, 2009 with a few details and your city and state of residence.
Jeannine Fallon
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
2. When replacing left hand side sensor, remove foot rest and door sill moulding, then pull back carpet.
3. When replacing right hand side sensor, remove foot rest and door sill moulding, then pull back carpet. Remove fuel injection ECU.
4. On either sensor, remove sensor mounting bolts, then the sensor.
5. Reverse procedure to install, torquing sensor mounting bolts to 16 ft. lbs.
If you don't know what a short connector is, don't mess with your airbags.
secondary (high scale) -- 5k - 25k ohms
I had not noticed that my backup lamps are on same circuit as the turn signals. Apparently a backup "combination bulb and alarm" (the likes of which I have installed on my cars for many years) was drawing too much amperage and blowing the fuse. They charged me an unconscionable $83 to diagnose and change the bulb back to a standard type.
Then they told me that transmission fluid was leaking at the half-shaft connection. What little oil/grease I saw there was not red and was not dripping. They insisted it was a serious matter they could correct for about $400 (or only $360 if they did the work right then), otherwise I might suddenly lose all my transmission fluid and totally wreck my transmission. I declined that service. And I'll not be returning to that dealer again.
Type & Size of Engine: (4 cylinder
Transmission Type: (Auto)
Mileage: (140k)
Problem: Was altenator really bad?
On 5/1, my car wouldn't start. Someone came to jump it, but it started w/out jumpers out of the blue. Took it to Sears. They tested the battery and said it was fine. The battery, a Die Hard gold is less than 6 months old.
Sears then told me the alternator was bad and replaced it. Four days later, my car wouldn't start again. I had it jumped and took it to another mechanic. They load tested the battery and voltage dropped to 4 volts causing no start condition.
They replaced the battery. I have the old battery, but not the old alternator.
Sears maintains that their tests, done by computer, are accurate. What is the likelikehood that the battery test at Sears was bad and that the alternator test was rendered inaccurate by the battery test.
How should I proceed w/Sears?
A bad battery doesn't really effect the results of the alternator testing, if that is what your question is.
It's all pretty simple.
can i put the stock size on? how much variation in the profile and section width can i have? there is some 155 80 13's on ebay that i'd like to get, but not if they won't fit! i'm not concerned with speedo readings, etc.
thanks, jerry
