Got a Quick, Technical Question?
194959799100114
  • jonathannjonathann Member Posts: 55
    colin_l:
    That is interesting. So the keyless entry and security systems are integrated.
    Apparently, it is never too late to learn something new.
    Thanks again.
    Try calling the service manager in another larger Kia dealership.
    Thanks, will do.
  • phizixphizix Member Posts: 2
    Hi All,
    I have a 2000 Chrysler Cirrus with two symptoms of an electrical problem. First, voltage regulation is occasionally bad, usually after driving 5-10 min, and bad enough to cause visible flickering in the headlights. Second, the car will occasionally not
    start; I turn the key and voltage is lost (i.e. the clock resets, no internal lights). 10 seconds later, the car starts just fine. The alternator and battery check out fine.
    Anyone have an idea here?
    Jim
    If the battery and alternator test good, how about the ignition switch?
    Battery cable, either one/both - loose connection at either ends, corrosion inside the insulation.
    Right on; the problem was corrosion at the negative battery terminal.
    Jim
  • drdonrsdrdonrs Member Posts: 164
    2006 Hyundai Sonata LX6 with auto tranny
    12,500 miles and 3 1/2 yrs.
    Maintenance requires replace ATF at 30,000 mi. or 24 mos. Fluid is still reddish and no odor, dealer recommends replace fluid. Yes or no? Seems like a ripoff.
  • colin_lcolin_l Member Posts: 591
    Definite ripoff.
    A question should be - do you have any factory warranty left? Maybe a 60,000/100,000 mile driveline warranty?
    If there is any warranty left, in order to protect the warranty, I would change the fluid. But I do think a 30,000 mile/24 month tranny fluid change is awfully short period.
    Unless - Is the the period from your owner's manual's service section, or is this a quoted period from your dealer? You do know they lie to you, right? Dealers wanting to do much shorter maintenance periods than called for in the manual is a well known way to move money from your pocket to theirs.
    My car has a 10 year 100,000 mi powertrain warranty. The period specified is in the owners manual. The service writer is someone who I have trusted from a former dealer, that closed. He agreed that it was very low mileage, but in order to protect my warranty, just in case, it should be done. One other thing, he indicated that fluids like ATF fluid can breakdown over a long period, which in this case is 3 1/2 years.
    Yes, Hyundai has that great warranty, but you end up paying for it by having short mileage maintenance periods. That is something they don't advertise along with the warranty. You usually don't get something for nothing. To protect your warranty on the powertrain I guess you'll have to have it done.
  • jipsterjipster Member Posts: 6,302
    I don't think the trans warranty is either or? It would be 24 months or 30,000 miles,whichever come first. Since he is a year and a half past recommended fluid change, could present a problem if any trans. issues occur.
    Solution:
    - Go buy ATF and 9 quart drain pan.
    - Remove drain plug.
    - Wait a while.
    - Install drain plug.
    - Pour in 4 quarts and look at dipstick, then add 1 quart at a time until full.
    - Put receipt in owner's manual.
    Cost: $25 or less
  • carstrykecarstryke Member Posts: 168
    Hi, i recently purchased a 2009 Chevrolet Equinox and i didn't think to get mudflaps. Are they a good idea or just a waste of money (any pro's or cons would be great)?? The Suv stays mainly on paved roads but i do drive on a gravel driveway at work 5 days a week. As for the winter time it is usually snowy on the roads here at least 6-7 months of the year. My last question is, are they easy to install yourself?
  • euphoniumeuphonium Member Posts: 3,425
    The new & deep tread of your tires pick up gravel from the work driveway and when you reach highway speeds, the tires flex to enable the embedded rocks to flip into the sides of your new Chev. Thus, the flaps that mount on the trailing edge of the wheel wells would be appropriate. Avoid the White ones as they look shabby when dirty.
    They are easy to install as Directions come with them. At most, you might need to use an electric drill, screwdriver, or other simple tool.
  • pgilbertpgilbert Member Posts: 23
    1992 Toyota Previa (AT 250 000 km) Belt squeal?
    I've had a very high pitched noise that is perhaps belt noise, from the belt on the AC compressor pulley. It has been there a year and only the last month it's got a little louder.It's a similar type of noise to a very common one we've all heard - from 'power steering' when you turn the steering wheel right to the maximum full lock - but the noise stops as soon as you back the wheel off an inch. BTW, is THAT noise caused by belt stress?
    The belt in my van on the AC compressor pulley looks OK (I replaced it about 6 years and 80 000km ago) but is perhaps just slightly less tight than it should be. But another thing - when I press on the belt between the pulleys, it squeaks loudly like rubber on metal - although the adjacent belt (running the alternator and power steering pump) makes no noise at all when pressed between the pulleys... is this squeaking symptomatic of a belt that's wearing out or too loose?
  • montanaguymontanaguy Member Posts: 2
    Hi, thanks for reading. My 2001 Pontiac Montana has a parasitic drain. It will only start with a jump from another car (but does run once started). The battery is under a year old and tests good. With the positive battery cable connected only, I can measure 12.7V from the unconnected negative battery terminal to any frame bolt. I have eliminated the tail light assemblies. The alternator is good. I individually pulled every fuse and relay in the access box under the hood and the frame tested hot every time. If I disconnect the battery cable from the starter motor assembly AND the positive cable from the fuse box, the frame goes cold. Reconnecting either cable bring the frame hot again (12.7V). Do I have two shorts? Should I pull the starter and take it in for testing?
    A little more info; on the starter motor assembly, where the positive battery cable connects, are three additional smaller cables. From bottom to top on the bolt they are (a) two wires with some wrap and an eye, (b) a thin wire and an eye, and (c) a thick wire with lots of wrapping and an eye. If I take them all off the bolt and touch the battery cable eye to (a), the frame of the van goes hot. Touching (b) and (c) has no effect. Touching just the bolt on the starter has no effect. So the problem is somewhere behind those two wires on (a). They disappear into harness shielding so I can't see where they go.
    I don't have the electrical schematic for your vehicle, but in most cars there is always a number of circuits that are powered and on all of the time. For instance, in order for your electric door opener to receive a key-fob signal and unlock the doors, it has to be continually powered on and working. That key fob also automatically turns on lights. Security systems, engine computers, gps tracking systems, clocks, etc are usually all on all of the time. I personally know of a power seat switch/motor go bad draining power, and a trunk light switch defective leaving the trunk light on all of the time. You could also have a diode in the alternator bad, allowing the battery to drain.
    If you are trying to trouble shoot something draining your battery, I can't imagine trying to do that without a set of electrical schematics. Once you have the schematics, you'll see a set of circuits that get turned on when the key is started, usually through a relay. Look for all of the circuits that are powered all of the time, and start unplugging their fuses until you see the current draw stop.
    Well, I think you are doing it wrong. You are using a voltmeter. What you need is an ampmeter. And one that can handle a significant amount of current (amps). If you have a multi-meter and are using the voltmeter on it, and it also has an ampmeter, it is probably not capabile of handling the amps in an auto circuit with a short - you may burn the multi-meter up if you use it's amp measurement setting. It will probably only be capabile of handling 0.1 amp or less.
    If you can obtain an ampmeter, you should first pull one of the battery cables and put the ampmeter in series with the pulled cable. (In other words, let all the current flow thru the ampmeter. This is how ampmeters work, and means you must have one that can handle 5 or 10 amps, because this may be the size of the current drain in your car.) This should show you the amount of current the short or failed component is pulling because this is measuring the entire electric circuit of the car. You should seen a relatively large drain, more than .3 amp. Reconnect the battery cable and then you should restart pulling fuses. Connect the ampmeter in series across the contacts where the fuse is plugged. The ignition should be off, doors closed, interior lights off, etc - in other words the car should be as dead as you can get it. If there is significant current draw across any fuse, this is probably the circuit with a short. Significant, means, oh, .3 amp or more. If your battery is going from fully charged to dead in one day, you will probably find a greater amperage pull than that.
    But if you find the fuse, all you have done is narrow it down to that circuit. You will still have to find the component that is actually causing the drain, or the area of wiring that is shorted to ground. This is where having an electrical diagram of the car is almost always necessary.
    And, here is my standard input to battery drains - Does the car have ANY non-stock alarm, remote start, after market stereo, towing package, or any electrical add-on. In MOST cases, if any one of these is on the car, this will, in MANY, MANY cases, be the cause of the drain!!!!
    You MIGHT be able to use your voltmeter to narrow down the circuit. When you pull a fuse, with the car 'dead', put the voltmeter across the fuse contacts. If you read any voltage at all, it means that circuit is pulling some current. You don't know how much, but it does mean some current is being pulled. The problem - several circuits (fuses) can correctly pull some power where the car is shut down. The radio will pull current to run the clock that is in most radios. The various computer boxes may pull power because some are always active 'looking' for something to happen, such as the remote lock fob being pushed to open the doors. In a modern car, who knows exactly which circuits are 'active' and pulling current when the car is shut down. The only thing - these circuits should not be pulling much current, or the battery would run down. That why I said to look for 1/3 amp or more if you can get an ampmeter.
    Also, your battery must have a pretty good charge in it. If you are testing with a dead battery, your amp/volt meter will not have enough current from a dead battery to detect a pull.
    Parasitic drains are not easy to diagnoise. You might have to take to a shop. If you do, specifically ask if they have anyone that understands electrical systems. Not every 'mechanic' knows enough to find a short or failed component.
  • imidazol97imidazol97 Member Posts: 27,838
    Here's a good article about drains and parasitic drains. Your amp load between the terminal and the cable should be under 35 milliamperes (0.035 amp).
    http://flashoffroad.com/electrical/Batteries/BatteryDrain.html
    good writeup .......thanks for posting.
    Thanks for commenting. I actually tried to find some posts where people had been trouble shooting drains in GM cars which I've read, but I couldn't find any in other discussions.
    The one thing I wonder about is the starter. A neighbor had troubles that weren't there sometimes and occurred occasionally after 10 hours or so. A shade tree mechanic on the other side said it might be starter; they replaced the starter and the problem was gone.
    It could be so many different things it's not funny. It only takes is one diode to go bad, one relay point to stick, one switch to stick closed, one of the computers to go bad, etc.
    That article just saves a lot of writing and explaining....so thanks!
  • jhayes9835jhayes9835 Member Posts: 20
    I have a 1996 Infinity I30. I was experiencing starting problems and stalling at stop lights. I would have to push on the accelator to get it to start. At stop lights I would have to keep one foot on the brake and one on the accelator to keep it from stalling. I bought some crc maf sensor cleaner and cleaned the maf sensor. The car is running fine now. I am sure That I will eventually have to replace the maf. If the check engine light never came on, will I still have to reprogram the ECM? Can I reprogram that myself? Thank you for your help.
  • alternatoralternator Member Posts: 629
    Here's something that has worked for me, and it's very inexpensive to try :
    Use "valve grinding compound" ( not "belt conditioner" ) to stop belts from squeaking
  • marsha7marsha7 Member Posts: 3,703
    Forgive me for asking...wouldn't valve grinding compound be too abrasive and simply eat up and wear out a belt surface???
  • grampa2grampa2 Member Posts: 5
    3/4 ton chev silverado,2006, auto,4X4, extended cab, V8 , 180,000 km
    Problem-loss of power, dash wardnng-"engine power reduced"- problem???
    I don't have the time to go look it up, but an error like that can be displayed when the computer has detected some out of norm conditions. Go have the error codes read from your computer.
    I had a similar problem a couple of years ago with a Ford I had. That problem was a bad sensor on the gas pedal. It's drive by wire and the potentiometer was out of tolerance. When I read it up on the Ford, it indicated that they put the vehicle into reduced power mode so you're able to limp home. I have no idea without researching whether Chev does the same.
    But getting the computer read should get you zero'd right in on the problem area.
    From TSB Bulletin No.: 07-06-04-019A
    Date: November 06, 2008
    Condition
    Some customers may comment on an intermittent MIL/SES light Illuminated with a message center or an indicator that displays Reduced Engine Power. DTC P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation may be set. The voltage difference between APP sensor 1 and APP sensor 2 exceeds a predetermined value for more than a brief period. Refer to DTC P2138 in SI for further diagnostics.
    Cause
    On some vehicles, the IP to body harness connector, which carries the APP signal to the ECM/PCM, is located in the left hand kick panel area or inside the IP. Water intrusion into these areas could cause an electrical short in the APP circuits setting a P2138 code.
    Correction
    Note: Make sure that no add-on/aftermarket equipment is electrically connected to the APP signals or to the other ECM/PCM five volt reference or return lines. These can generate false P2138 and/or other ETC System DTCs. If there are other engine DTCs besides P2138, such as MAP sensor faults (i.e. P0107, P0108), resolve these first before attempting to diagnose P2138 DTCs.
    Important: Refer to DTC P2138 in SI to confirm that the ETC pedal is operating correctly.
    Locate the IP to body harness connector, which may be located in and around the left hand kick panel area or inside the IP. Check to see if there is a water leak into the area and repair as necessary. Use a water hose to determine the source of a water leak and effectiveness of repair. Some examples of potential water leaks are: A-pillar seals, sunroof drain lines (if so equipped) and windshield/cowl sealing. Finally, repair or replace the IP to body harness connector, making sure no corrosion or debris is left on or between the terminals.
    thank you very much!
    thank you very mcuh!
    I doubt if valve grinding compound is any more abrasive than ever-present road grime. In any case, I never have had to replace a belt inside of 50,000 miles. And I should have said that you only need to put a dab or two on the belt, the compound will spread by itself along the full length of the belt.
  • ls78ls78 Member Posts: 2
    I was rear-ended on the left-hand side of my 2001 Honda Accord. Now the car pulls right. The car has been repaired but now pulls right. Any ideas why?
    did they align the vehicle with a 4 wheel alignment? Need a quality alignment, where they make sure all of the wheels are in the correct location.
    An off center hit on the vehicle, may have pushed in the left rear wheel toward the front. If the repair shop didn't pull the left rear back to the correct position before fixing the sheetmetal, you may have a hard time getting it into alignment now.
    Take it back to the repair shop.
    Not sure. I will check. Thanks for the info. Will definitely be taking it back.
  • shooter7shooter7 Member Posts: 5
    i have a saturn 2000 v6 300 with transaxel. wont go forward or reverse. Im getting a code for the B solenoid stuck open and park neutral sw 1780.
    also 502 speed sensor. do i have to replace the b solenoid? can i do it from under the battery box? what do you thnk? thanks.....
  • michaeleruddmichaelerudd Member Posts: 1
    Hey Maverick or anyone else out there who has an answer to this...I have the same exact issue on my 2004 Kia I bought from someone else...he had this FCC ID: QY7ADM625 key theft system installed on it...my car won't start unless I click this button...the local Kia dealer had never seen nor heard of it...the battery on my thing died so therefore my car wouldn't start!!
    Total pain in the butt...I want to figure out who this company is and how to get a hold of them and how to deactivate this system from my car...all I know about the company is this ID number and the name identity...I googled it all night and all I came up with is your post about this and the thing for sale on E-Bay...this thing sucks anyone with help I would greatly appreciate it.
    I have an "Identity" anti-theft system installed on my 2000 Toyota Tundra. The previous owner installed it. I have brought it to two different Alarm/Car Radio shops and they both claimed I do not have an anti theft system installed. They looked in the ignition area, behind the radio and couldnt find anything. This system utilizes a keyfob. I push a button when it wont start and what do you know, it starts. It does this intermittently. The FCC ID is: QY7ADM625 I have looked on the internet and cannot find the company who made this particular device. Any help disabling this system would be greatly appreciated. I dont have to worry about my truck being stolen in North Dakota.
  • ivynivyn Member Posts: 1
    I have a 1998 DS, the oil light came on last winter, when it happened the car shuttered a little and never did it again (it was also 20 below wind chills. I checked the oil and it was were it was when I had the oil changed 4-5 qts. The night this happened I let the car sit for about 1-2 hours check all the fluids, nothing was low and started again..no light at first, then after 25 miles the light came on again. Since then I've had it put on a hand held computer coder and it came up nothing.. no codes at all. This kept going on (after 25 miles the oil light came on) so I had to leave it close to home, in the mean time someone else used it almost daily M-F only driving 6 miles a day. After about 3-4 months of this the light just stayed on. I was told it might just be the dummy light, and I'm thinking it might be the pump. Any suggestions?????? I want to find out and either get it fixed or get rid of it.
    Ivy
  • chuckfromlichuckfromli Member Posts: 249
    I think there is a forum called "Got a Quck Question for a Service Tech" , or something like that.
    One thought, back in 1977 I bought a '66 Plymouth Valiant with the slant six from a friend of my parents. It was a real rust bucket, but it was my first car and cost $75!
    When the engine was warm and the air temperature hot, the oil light would come on occasionally at idle. The guy I bought it from said he had the pump output or pressure checked, and it was OK. I later heard that when the oil is hot and thins the pressure may be lower. If you live in a cold climate and are using 5W-20 oil, maybe ths is a problem as the engine warms?
    So, I guess you need to find out if the pump is working correctly, and if the sending unit is working correctly. In either case, I wouldn't go far and I'd star building up my credit rating and savings account, if possible!
    I don't think a 1998 car is going to store many codes at all, and whatever it might store is probably just related to sensors, as opposed to mechanical problems.
    Yes could be the sensor---quite frankly, if the oil light was on and you were still driving down the highway like that, andif the oil pump WERE bad, the engine would have seized.
    The light goes on (usually) when oil pressure is about 5 lb PSI or less. That's not much oil pressure.
    The only sure way to know would be to screw in an analog gauge that actually reads in numbers.
    If that gauge shows 5 psi or less, then you would have to drop the pan and check the oil pump for wear, the oil pump screen for clogging, the oil pump pickup tube for damage or being loose (creating suction of air) or.....bad engine bearings.
    Keep in mind that an oil pump does not CREATE oil pressure---the bearings do that. The pump merely sets the flow.
    Oil light on really means STOP NOW, as soon as it is safe to do so, and call a tow truck....or take a roll of the dice and drive home....very risky.
    Some automakers used to alarm the oil pressure light---I wish they'd all do that.
  • silverado9000silverado9000 Member Posts: 1
    Hi experts,
    My truck is a 1997 Silverado 4X4 ext cab, 125 000km. Recently, I got a noise coming out from the front wheel train. Because I knew the right front wheel bearing was due to replaced (because the anti-lock system was not working anymore), I brought it to the garage and the wheel bearing was replaced. I also decided to have all the wheel bearings replaced.
    So, 4 new wheel bearings and the noise is still there, more noticeable while steering to the left. When I steer the wheel to the right side, the noise goes off. I can feel the vibration the noise makes (sounds like: "whoam-whoam-whoam") in the truck floor. The garage checked for a defective motor support but no luck. The universal join has also been replaced a few months ago. Edit: still having the noise with new tires.
    Any clue? :cry:
    Ball joints, shocks, control arms. Not necessarily in that order.
    Sounds like you have a bad CV joint, on your front 1/2 shafts.
    When an auto product is describing dimension, ( or any product, really) like say a roof cargo pod, and they say for example 30 X 20 X 10, is that *always* L X W X H ??
    That is assumed unless otherwise specified.
  • mistere2mistere2 Member Posts: 1
    1990 toyota 2wd 1 ton dually dump bed
    v6 3.0 liter,Manual trans,130,000miles
    Taillights have a short,checked the harness on frame,wires ok,bulbs ok,bulb sockets ok,disconnected harness under passenger seat,short appeared to be in the dash somewhere.A friend suggested replacing the taillight control relay,that didn`t do it eighter.Could it be in the steering column?(head light switch on turn signal arm)
    Could be in the stalk switch yes. Not unheard of, but hard to say without further diagnostics. (tedious work---sometimes guessing IS easier!)
