Chevy Silverado - Continued XII
                    This topic is a continuation of Topic 1891....
Chevy Silverado - Continued XI. Please continue
these discussions here. Thanks!
Front Porch Philosopher
Kinda like the energizer bunny.
Im glad to be a part of this.
Guess what Tim it rained yesterday 2 hrs after i washed my truck (told you 100% chance)and it only rained for 10 min enough for it to get dirty AAAAAAAAAAAAHHHH im so mad but hey i still have my streak going .
Ryan
- Tim
But to lease for 2-3 years....then finance it for 3-5....better off buying it
- Tim
I thought about leasing....but need extra miles..
I drive 22K a year.
lease would have been $550
I pay almost $600 on a zero down 5 year loan...
I will sell it after two years total...pay off balance...and walk away with 6-8K....deduct that from the payments...and it cost me around $300 a month for a 2500 LT
Good luck
- Tim
Better put some fresh batteries in your calculator!!
What would we do without Tim, and all his wind!!
Put 10K down on a lease?...
If you were to buy it...and the whole lease/buy took 4 years...that doesn't sound too bad...
why take that route instead of just buy with a 4 year loan?
- Tim
- Tim
If you were sure you would but it at the end....I guess that's cool...
I just don't think anyone should put a penny down on any lease....but if you were to buy it...I guess it's OK.
Have you looked into an Up-front lease?....you may be almost there as to what you need for the one time payment?
- Tim
My $.25
I wouldn't put anything down on a lease...period.
Take the 10K and finance it....unless the payments would be too much?
- Tim
My dad just got a fifth-wheel camper and needed to upgrade his truck. He's got a '94 2500 ext cab 2wd (pre-vortec 350), but it's a light-duty 3/4 ton. He tried pulling it once and nearly overheated the engine. So, he put in a heavy duty radiator and trans cooler, which has solved the temp problems. He also installed an air ride system for the rear axle, which completely solved the suspension problems. The drawback is a very rough ride when not pulling the trailer. Just FYI for anyone considering air ride suspension.
White6, my dad's also a propane dealer, and has converted just about everything we own to run on propane, at one time or another. It' been our experience (as yours) that it is cheaper and that you have to find a place to mount the tank. Other benefits are that propane burns alot cleaner and improved engine life, because you've got more fuel on board you have less frequent stops to fill up. Gas mileage is about the same, and you lose just a tad of horsepower compared to gas. But still a worthwhile alternative to gas.
OK, you all can go ahead and stop laughing now...LOL!
Thanks for great zerk pics. Same fittings as on my 00 Tahoe. I'm going to use the Mobil 1 synthetic grease, but I don't know when I should first lube em' or how often I should do it. Any tips?
I perfom a chassis lube every second oil change which is approximately 6000 miles between each lube.
I worked for a leasing company for 3 years. Most of the time a lease will cost you more than a loan, some of the time a lease will cost the same as a loan, once in a blue moon a lease will cost less than a loan. If it does cost less the leasing company made a mistake and over estimated what the value of the truck (car) will be at the end of the lease.
I'll be away for a few weeks so I won't be able to respond until I return.
Greg
Swobig, i think the bra would look just fine.
especially when you consider the added protection
that you get from them. i like, Bluebeast, am
getting sick of removing the bug guard for
cleaning. please let me know where you saw the
bra and how much.
thanx,
red
reference post #12...you were replying to wtking, not werking. i wasn't giving you lip about your preferred financing methods...
rob,
i hit the zerks with 3-5 squirts each, each time i change the oil and filter. i'm already under there and greasy anyways. if you take the brushguard off before you get started you can pretty much hit all the zerks while the oil's draining.
kyle
If everyone was just man enough to sign their real name here....
- Tim
Ryan
http://www.xpel.com/lite/paint/chevrolet.html
zerks, no zerks yet. Dealer has my truck but with some many things to keep them busy, the tech hasn't gotten around to it yet...
If I did it over, would still buy the trailering harness from GM, but would buy the brake controller harness from Tekonsha....
Oh ya, bought the heavier duty Reese receiver hitch for around $160. Higher dead tounge weight rating (800lbs)than the $100 Reece base model, as I sometimes haul motorcycles on a Hitch-it sideways mount carrier......
Thanks for the info!
I don't know why anyone would put shocks designed for a 1500 pickup on a 2500???
Maybe Rancko RSX or Monroe Reflex shocks (both do the same sort of damping as the IAS shocks) have shocks designed for 3/4 ton pickups???
rcoos
(mind you, i'm NOT a mechanic)
1. Are there other lube points to take care of
besides the 11 zerks on the front end? Like the
driveshaft U-joints?
not that i've found
2. Are the front ball-joints completely sealed except for the zerk access?
i do not know
3. Can I do any harm to these ball-joints by inadvertantly overlubing, or does it just create a mess to clean up?
not sure about doing harm. i DO know it makes a mess
4. When you are lubing the zerks, how can you tell when enough is enough?
two schools of thought on this one. one, watch/feel the bushing as you add grease (hard to do unless you're real good with a grease-gun). assuming it's real soft when you start adding, when it firms up (just firm, not hard) stop adding.
second way to do it is...add 3-5 squirts to each fitting each time you change the oil/filter. or every 5k miles or so. this was told to me by a mechanic at a chevy dealership. i follow this advice.
i've done lubes on tanks (in the army) and it's so much easier. you just keep adding until grease squirts out the release valve. then you know it's full. duh. with these, you kinda hafta guess. next time i take it in, i'm going to ask, because my #5P doesn't seem to be holding it real well. even when i add just a little, the grease seems to leak out. gonna take it in to see if it needs a new bushing/seal. i'll let you know, but don't hold your breath. it'll be another 3k miles yet...
kyle
I think U-Haul installs good hitches and will wire up your trailer plug. You want a class three hitch.
Gene
If you want my name, look at my profile!!
I'd think a "Super Genius", windbag, LURD, like you ought to be able to figure that one out.
-Todd
Mission accomplished!
- Tim
Don't really think the auto penalizes at all, if anything, it helps. Quicker shifts, less shifting.
To 60 mph, I'd say same truck with 4wd. Much better 60 foot performance.
Reese hitch I got for $94 was rated for 750lbs tongue weight and 7500lbs trailer weight(more if you use the weight distribution system forget the numbers thought). I've seen three different hitches made by Reese that fit these trucks, and they all have different weight ratings. I'm more of a sport truck guy myself, so the primary purpose of putting it on there was to pull the occasional boat to the lake etc.
The trans cooler is standard on the gm trucks. It is built into the radiator, but its there. So unless you are doing major towing "alot", you should see no need for the optional add-on cooler that comes with the towing package gm sells with the factory installed hitch. If you are going to pull alot, you want the extra cooler. It'll save you a toasted tranny down the road.
As for the trailer wiring, its already there for non-electric brake applications. Taped to the frame above the spare tire. Doesn't have an end on it thought. Your manual tells you how to hook up a harness plug to it. This is for those of us that didn't opt for the factory hitch.
Anyone have a price on the gm electric brake parts? (controller and wiring) I've read some postings about it, but haven't seen any prices.
Any help would be appreciated!
gmc sierra
Kirk
