The Future Of The Manual Transmission
15758606263205
  • irismgirismg Member Posts: 345
    Thanks, I just wanted an example that it was doable if need be, but there's something I don't understand...can you move the gearshift without depressing the clutch?
    I couldn't easily get my Tercel in first or reverse without clutching and don't recall having any luck trying to get it in second when the car wasn't in motion. In theory you can crank and start off in second gear, lugging the engine a bit. Seems like that's an old off-road technique?
    But yeah, you can match revs and upshift and downshift a manual (ok, some manuals) all day long without using the clutch. Just can't shift into first or reverse unless there's some kind of synchro going on that my Tercel didn't have.
    Starting off in second is a trick for getting going easier in low traction situations like snow, slick mud, etc.
    Most of the snow buttons you see in automatics now are just second gear start features. The only two I can think of that do more then start in second gear are the Snow/Grass/Gravel mode for terrain response in the Land Rovers and the new snow mode in the Jags.
    I'd say rent a cheap car for a week, at least until you can move around comfortably. Also depends on the type of cast and seriousness of the injury.
    A good point was raised - I doubt your insurance would cover you if you get in a crash driving a stick shift with a cast. They would basically assume you were at fault in any collision regardless.
    Far too risky. Just rent an automatic.
    Right, but ordinarily you'd clutch when you start off in second in the snow in those cases.
    I was thinking there was a situation where you'd be stopped in a Jeep (excuse me, a manual Land Rover ;) ) and wanted to get going in second without using the clutch. A bump and creep....
    Hey now they still make Manual land rovers you just can't buy them in the US.
    Yeah in some situations you would disengage the clutch interlock and start the car in second, or even first under the right conditions, to bump the car forward. It is very, very hard on the starters though but some aftermarket companies sell extra heavy duty starters that can actually pull the car forward for quite a while.
    I knew you'd be able to refresh my memory. It's been 30 years since I owned my CJ-5. :shades:
  • habitat1habitat1 Member Posts: 4,282
    if any of you who don't have an alternate car they can drive have found themselves with a cast on their foot for six weeks. If so, how do you drive your stan-trans car in that case?
    I tore my ACL last summer and after complete replacement surgery in October, was able to drive a stick in 48 hours. It was my right leg, working the gas and brake. But I don't think it would have made any difference if it was my left clutch leg. If you are only going to have your foot in a cast, I suspect there is a pretty good chance you can drive a stick once you get used to moving it using your leg rather than ankle/foot muscles.
    Tylenol #4 helps.
    The size of the cast or whether it's a walking cast may influence your decision too.
    But I still can't recommend it. I was younger and dumber when I did it (which also explains my broken left leg, lol).
    One time I went skiing with my college roommate, and he hurt his right shoulder. I had to shift for him.
    Once we got the hang of it we were pretty in synch. 1st-2nd was the tough one, had to be quick and well timed.
    I would have driven but the car was borrowed from his sister, so I didn't really have permission to drive it.
    So, if I understand you right, you can shift from gear to gear without the clutch, and without it making a horrific noise and doing damage? If that's the case, maybe the manu-matic isn't that far off-base...maybe I'm not understanding something.
    If you don't mind explaining (I'm not that mechanical at least not as far as trannies), if you can successfully shift without the clutch, then why is there a clutch?
    Thanks again for the great discussion!
    That's wild! Sounds like something from The Little Rascals..
    Well, and sometimes a broken foot just happens. Eight years ago I had to wear a Bledsoe boot for six weeks on my right foot. Believe it or not, it wasn't impossible to get to work in my current car, I just kept to the city streets is all. I only go nine miles to work.
    Still, when it comes to my next car choice, I think you have to kind of foresee those things especially if you don't have anyone else's car to depend on, you have to think about how having a standard is going to potentially affect you. Ideally, I'd like to have one of each, but that's not realistic for me!
    Thanks for your patience with me!
    If you do something wrong, the gearbox will definitely let you know, lol:
    Mr_Shiftright, "How it Works! Welcome to Auto 101" #276, 11 Mar 2007 6:08 pm
    Why is there a clutch? Well, you're getting over my head too, not to mention that there's several different flavors of clutches (wet, dry, cable operated ones, multiple pressure plates, etc.).
    Someone else can do better explaining than me - I just think of a clutch as a gizmo that lets you engage the various gears without grinding them. Usually. :shades:
    That is more of the job of the synchros on a modern transmission.
    Our 1959 series II Rover has a non syncro first and second gear so you have to double clutch to match revs when shifting from first to second or third to second.
    Ah, double clutching. Something else that slipped my mind.
    Keep going. Do you really need a clutch with today's 5 and 6 speed manuals?
  • bristol2bristol2 Member Posts: 736
    I always wondered what that meant, it was a little before my time, can you explain the actual series of actions?
    Also, is that the same as double de-clutching?
    If not, what on earth is that?
    Clutchless shifting is about the only fancy manual transmission technique I have never tried.
    I can double clutch up and down through the gears, heel and toe down shift, throttle blip matching revs downshifts to stop without using the brakes but I have never wanted to try clutchless or power shifting.
    I watched my mom do it one time in a car but I never tried it. She had the clutch go out in her VW bug many, many years ago and then had to shift without the clutch through Atlanta to get home.
    You still need a clutch because you can only powershift in a very narrow RPM range and it is very hard on the gears.
  • andys120andys120 Member Posts: 23,675
    I learned to power shift in my '65 VW Bug, which wasn't to hard because the flat 4 operated in a narrow rpm range (redline was probably no more than 4500rpm).
    The knowledge came in handy one day when I was commuting to Manhattan with my brother and the clutch cable in his Capri 1600 let go. I told him to let me drive and managed to limp the car to the dealer on the West Side sans clutch.
    Yes, IF you do it exactly right. Let off the gas, pull the shifter out of gear and push it toward the next gear with a light steady pressure to balance against the resistance you'll feel. When your rpms drop enough to match your speed and the gear you've chosen, the resistance against the shifter will lighten and it will slide into gear. This can take a second or three depending on the particulars, and it will wear out the transmission eventually (mostly the synchros). The clutch lets you do it a lot faster, and takes the wear off the tranny itself.
    Some vehicles are pretty easy to do this with (most Hondas, for example), while others are just about impossible. It just depends on how the internal parts of the transmission are set up.
  • toyolla2toyolla2 Member Posts: 158
    I drive a 5MT Echo and with all this talk of the demise of the manual transmission I was surprised to read this.
    Honda research and development staff in Japan are working to increase fuel efficiency on the Fit subcompact and Civic compact for the 2008 model year, executive vice-president Jim Miller said.
    The auto industry is furious with the ecoAuto program contained in the March federal budget because manufacturers say it is unfair to some models; forces consumers to choose between safety and the environment, and will have a negligible impact on emissions.
    Honda, one of the country’s greenest automakers, was so upset with the program it took the unusual step of offering $1,000 on the purchase or lease of a 2007 Fit or a 2006-07 Civic with a manual transmission.
    The program gives an advantage to the Toyota Yaris, which offers fuel consumption of 6.2 and 6.3 L/100km.
    Hmm.. the Echo is around 170lbs lighter than both the Yaris and the Fit and I have to say that weighing 923kg with that 1NZ-FE engine pushing out 105lbs-ft makes this a fun car to drive and can give even better fuel economy 5.8L/ 100km if my memory serves me. But not the way I drive. :)
    The Civic models starting from MY 2006 are nice sleds. My test drive being with the 5MT of course. It's definitely on my short list in a few years. However I couldn't help thinking that it would have been an equally nice car fitted with the 1.3L from the Civic Hybrid. The non hybrid version of this engine is available in Europe. Instead we get the 1.8L 140HP version. I realize that having the 1.8L Toyota Corolla in its class needs the Civic to cover that engine size as well, it could be Honda can't offer a 1.3L variant because someone might discover that up in the snow belt areas the Honda IMA hasn't been doing very much to help this engine fuel-wise.
    So it may be the EcoAuto program that could push us back to manual transmissions. That's if we want to avoid the eco-tax that comes due when we couple these larger engines with automatic transmissions.
    T2
    The Eco Auto program referred to is offered in Japan, not the States. It basically gives incentives to buyers of high-mileage cars, and the Fit manual missed their criteria by a point or two, something like that. Therefore, the Fit DOESN'T get the cash incentive to consumers, while the Yaris DOES, and that ticked off Honda (and so it should, the Fit at 33/38 EPA is unacceptably low for such a light, small-engined car, IMO - they should be ticked at themselves).
    One disincentive to getting a manual that is amply demonstrated by both the new Yaris and the Civic is that with the new emissions controls, many cars' accelerators tend to "hang" when you let off them at high revs, which makes engaging the next gear very lumpy and annoying. This "hanging" is on purpose so that the throttle doesn't snap shut and cause a spike in NOx emissions. It's getting worse with every passing generation of car models, and of course an automatic driver would never notice it at all...
  • boaz47boaz47 Member Posts: 2,747
    I am glad you took the time to point out the differences between off shore programs and ours. And of course the Hybrid engine that was mentioned isn't offered with a manual in this country is it? I have often suspected that a combination of Environmentalists and government regulators would be harder on the remaining 8 or 9 percent of the manual manufactured cars than the market trends. As you know in our home state manuals don't tend to get as good a green rating because of the very thing you just mentioned. When the clutch is depressed in a California car there is a slight throttle lag that isn't even noticed in a automatic because it is programed into the on board computers. But when tested by CARB it suggests that all of us that drive manuals over shift. We will simply have to wait and see what the new regulations will do but I am sure the US will not adopt any European standards because of their higher permissible particulant standards. The US shows little fear of O2 but plenty of strict restrictions against NOx and Particulents. Still if we are headed into a hybrid revolution manuals aren't likely to prosper very well. Not that I am in favor of hybrids at all.
    (or what was once a MT advantage)
    you have a dead battery and no one around to give you a jump. remember putting the vehicle in neutral, pushing it at a moderate speed (and i have done this solo with the door open...gosh being young and stupid was fun! :blush: , and turning it over by putting in the clutch, putting it in gear and letting the clutch out fast? :shades:
    should bring back a memory or two for the other MT fans here.
    i wonder if you can still do that with these modern cars... the last one i did this on was a mid-80s Jetta GLI.
    All of my fuel injected cars with a Manual Transmission (all 9 of them) since 1979 have cautioned against the good-old-fashioned push start.
    Best Regards,
    Shipo
    The Accord both got a few push starts when its starter and ignition key went, and of course, for dead batteries along with the Galant and the Civic. The Civic didn't have a lights on chime so Miss LilEngineerBoy ran the battery dead a number of times with that. A couple of people and a little shove got it on its way.
    The push start still works on modern cars. It is not supposed to be great for the emissions equipment, but it is a huge advantage to be able to start the car if the battery dies.
    i agree, a more valuable feature IMHO than RFT technology.
    Double clutching, heel and toe downshift, de-clutching, matching revs, and what in the world is a "blip"?!
    I think I have more of an idea now of why people prefer automatics! I'm starting to think that after 20 years out of it, driving a manual is out of my league entirely with all this new vocabulary! At least I know that clutchless driving is doable. Maybe I need to study the basics, like how DO you brake without downshifting? Braking is always a good place to start.
    Did we have the discussion about resting your hand on the shifter and resting your left foot on the clutch yet? I never rode the clutch that way, but resting your hand on the shifter would be an easy habit to fall into.
    better there, than on the cellphone. :shades:
    A "blip" is when you tag the gas pedal during a shift to bump the rpms up to match the gear you're shifting down into. It's a time-saver (and takes some wear off the clutch and synchros) when you want to shift really quickly. That stuff is fun to do when you're driving at the track (or pretending to drive at the track ;) ), but it's not really necessary most of the time.
    Use the brake pedal. :P As long as the tach doesn't drop too close to or below the idle rpm, nothing bad will happen. If I have brake more than that (60 down to 25 mph), I shift into neutral, slow down however much I'm slowing, then put the car back in gear. This is technically illegal in some places, and not the best idea on long downslopes.
    i'm confused. why would you shift into neutral to slow down?
    "Did we have the discussion about resting your hand on the shifter and resting your left foot on the clutch yet? I never rode the clutch that way, but resting your hand on the shifter would be an easy habit to fall into. "
    Relating some recent discussions to this: I remeber once having to push (as in me pushing car) my moms 53' buick special with her behind the wheel. Had a lot of trouble trying to move that huge tank size machine until I went back towards front to see her right for resting on brake pedal. ( I mind have be thinking some bad words if I had been old enough at the time)
    Because if I left the car in 5th gear, the engine would stall around 25 mph.
    right, but, wouldn't you be making at least one or two downshifts prior to this?
    i think so.
    i can't remember ever ever trying to brake from 5th gear to very low speed without using the clutch and downshifting, unless of course, i was comming up on something sudden, then i would engage the clutch and brake at the same time out of reflex. Not sure if that was a good move or not, but...
    if you're at speed and your slowing using the brakes, you should just automatically sense when the engine has done it's thing with compression braking and down-shift.
    i'm not sure i'm on the same page as you w.r.t. why you fully engage the clutch... i mean, do you just want to wear the brakes out quicker? do you think you're damaging the engine by braking some, then downshifting? are you on a patch of ice and don't wish to downshift then?
    i'm confused.
    Warranty claims by people with manual-trannied cars are because of the fact that these people don't know how to properly operate a clutch and stick shift. It's just a tad too technical for most people to do, apparently.
    "Riding" the clutch is a bad habit that a lot of people fall in to. I kept my foot off the clutch like a hawk with all of my rigs with sticks. The only rig of mine that needed clutch replacement was my first car, a '65 Mustang. That car was purchased used in 1978 and probably had 125,000 miles on it when I got it. It was probably bought with significant clutch wear already on it and I, while using it normally, put so many miles on it that it just wore out.
    There is an art to driving stick that can be learned by a significant percentage of the U.S. population but it isn't being taught to them. Or they don't see the need to learn, or a combination of these things and several other things that is combining to doom the manual tranny in these United States.
    Excuse me while I go play with my paddle shifters.
    None of that is new vocabulary though it is all old vocabulary. With a modern manual transmission you don't have to do any of that fancy foot work but at least with a manual transmission you have a choice.
    I can chose to drive a manual just in a regular manner or I can use all the fancy foot work I have learned over the years to maximize not only my driving enjoyment but also fuel economy. Oh I can also minimize brake, clutch and transmission wear by down shifting properly and matching revs with a little bit of throttle blip.
    27 years, 9 vehicles, all manuals, over 1.5 million combined miles driven between the wife, myself and now my daughter. Only one clutch replacement, and that was really a broken linkage where it was easier to simply replace the whole clutch than to tear things apart to replace the linkage.
    Not a single issue or wear on any of them.
    The wife says how she feels more in control of the vehicle, especially in winter conditions.
    I know it's made my 18 year old a better driver than if she was in a car where you can just stomp on it and go :P
  • qbrozenqbrozen Member Posts: 33,800
    what kind of car we talking about??
    I can take my Accord all the way down to about 10 mph in 6th gear before it starts to shake. My 350Z I used to be able to get down to around 5 mph in 6th.
  • stickguystickguy Member Posts: 53,815
    I blip occasionally, but it doesn't seem to really make much difference. I also never quite mastered heel and toe. And no way am I trying clutchless shifting!
    Not slipping or riding the clutch IMO will have the biggest impact on longevity.
    I will also use the throw it in neutral briefly technique when I am coasting to a slow down (not stop), and then put it in the right gear when it is time to accelerate. Not on downslopes though.
    It's not rocket science, and on a modern car, in normal driving, pretty much unneccesary.
  • kyfdxkyfdx Moderator Posts: 269,219
    Clutchless shifting is easy.... Just use the throttle to match the revs of the gear you are shifting to.. You'll know when you have it right, because the shifter will slip right in..
    Blipping, heel and toe, double clutching... Those are all great if you are driving an old MG, or a commercial truck.... but, hardly worth the effort, otherwise...
    Unless you just like to show off your skills!! :)
    The clutch is only "needed" in First and reverse. Unless you are in a hurry the modern transmission with its full synchro can easily be shifted in the other gears without touching the clutch pedal. It is simply "easier" to use the clutch in a gas powered car. But anyone who says they prefer the connected feel they get from driving a manual can tell when the Engine and transmission speeds are matched. You can hear it and you can feel it. It is simply a matter of reaching the shift point, taking it out of gear and listening to when the RPS match your speed and popping it into the next gear. Gas engines are harder but there is no real extra wear to the transmission. In diesels there is almost no reason to ever use the clutch in any gear other than first or reverse. In most ten speeds even in Bob tail trucks there is a high low splitter and you go from low to high range with a simple pull on the button even if that is only changing the gear ratio. Same thing with a tractor trailer. I logged more than 300,000 miles in a 9670 cab over and once I got rolling I simply ignored the left foot. Unless I was coming to a rather sudden stop. If my ears and brain could find a way to relieve my left foot of the need to depress the clutch pedal for all those miles I can see no reason a computer couldn't as well. Even after all these years since I quit driving for a living I still catch myself shifting the family car without a clutch. Down shifting is a real test but up shifting is pretty easy.
    No, I put the shifter in neutral instead of making the downshifts. Ride along at 60 mph in 5th, decide to brake, clutch-lift-neutral, brake as necessary and coast along in neutral down to 25 mph, clutch-3rd-gas.
    qbrozen: what kind of car we talking about??
    2000 Hyundai Accent, runs about 2700 rpm at 60 mph in 5th. Theoretically, it could go down to 19 mph at idle in 5th, but 5th doesn't have enough torque multiplication (torque division actually, since it's overdrive) for the 1.5L to keep the car rolling much below 1500 rpm or so.
    I've never met anyone who drove a MT this way.
    I personally wouldn't want to do this, and one of the reasons why is that by having the engine connected to the transmission, the compression braking is saving wear and tear on the brakes. Your engine has to do the revs anyway, why not use it in this manner to do some work... Your brakes will last longer.
    Another very good reason for NOT AND NEVER EVER COAST, is that you are always in immediate position to re-apply gas to the vehicle and get moving. Yes, sometimes, power/acceleration is a safety feature.
    I have learned, when on very slippery roads, not to make control input changes if possible, meaning applying brakes, shifting gears, turning the wheel. If you are crossing a patch of black ice for example, or on an iced over bridge, and you decide to shift then (up or down), if you aren't perfectly matched, i would think you'd induce a change of forces at the points of road/ice contact that could put you in a loss-of-control scenario.
    I could be wrong about all this of course. :sick:
    Now let's say you're in twisties. Do you
    a). just brake going into the curve and accelerate out,
    b). brake and apply clutch going in, then let out clutch and accelerate comming out,
    c). brake and down-shift prior to entry, and accelerate on exit?
    d). other?
    d). other?
    Well, that depends on many factors, not the least of which include your mood and the power of the car you are driving.
    Answer a if not in a hurry and the curve is not very sharp. Answer c if you are having fun and the curve dictates slowing down enough to warrant a downshift (although, technically, the shift would occur just as you enter, not prior to entry). :)
    My brake pads last forever (relatively speaking) since I almost always long brake. I think engine braking should be used as an occasional supplement to regular brakes when necessary, and not as a regular substitute or complement.
    d). other?
    All of the above, depending on how tight the curve is, how fast I'm approaching, how much I need to slow, and whether I'm driving FWD or RWD.
    Agreed too many possibilities and also what you do on a public road just having a little fun is very different then driving at 9/10ths or so at a race course.
    There are some situations where you might need to brake and down shift going into a fairly slow corner at the bottom of the hill and if there is a series of turns after the first turn that changes things.
    You want to go into that corner using a gear that will carry you through the entire series of curves without shifting.
    Depending on the car and the course that could be second gear or third gear.
    and if you are on a straight, and comming up to a red light far up ahead or perhaps another vehicle? :shades:
  • plektoplekto Member Posts: 3,738
    Well, I do this every morning when I drop my son off at school. I take the freeway two exits and do this when I come to a stop on the offramp. It's curved in an S-shape and you can't tell whether the light at the end is green or red until you are almost at the end - and you can't take the second curve near the end at more than about 30mph.(I swear L.A. freeways were designed by people on acid sometimes)
    So it's 5th gear, put clutch in(technically optional here), stick in neutral, hit brakes. If red, come to complete stop(do nothing). If it's green, at ~20mph, put in in 2nd to take the turn. You can really minimize - actually cut your clutch use in half with a few simple changes to your driving style. Perhaps that's why I don't find heavy traffic to be a chore with stick.
    P.S. - most all modern manuals can be taken out of gear/into neutral without a clutch. (well, technically all of them, but modern fully syncro'ed ones are a cinch)
