Visitor Agreement.
Sounds like your Miata needs Audi & Mercedes' new 7 and 8 speed transmissions! hahahaha.
I honestly thought the first time I got a 6 speed car, that perhaps the first 5 gears would be sporty, but that 6 would be purely for long and straight and flat, but alas, it was not to be. But your Miata is really turning fast, the A3 isn't THAT bad at 80 MPH, I think about 3,250 RPM.
I cracked up when he said something like, "can you PLEASE move? You're blocking the Quinoa!"
I suspect most stick drivers are the same way.
"..even the worst stick driver I've even encountered wouldn't wait that long before downshifting..."
Just what planet are you from....?
I'd bet, other than on the "track", that fewer than 1% of stick drivers even bother to downshift even once, let alone 3-4 times, during coastdown periods.
Now I get it...
That's why it takes explaining something to you 3-4 times...
I only choose a lower gear if I need it for something.
I really don't think I need a transmission to brake my car when it is hurtling towards a red light at 15 mph. :P
MODERATOR /ADMINISTRATOR
Review your vehicle
Yep, and like I said, Mazda got enough complaints that they made 6th gear slightly taller, but barely enough to notice. 6th should be TALL. I want 75mph at <3000rpm.
If I want to pass I'll shift. That's why I got a manual!
1. More POWER.
2. less weight.
3. Lower CD.
Or downhill, maybe..?
And then, only then, would the taller 6th gear be useful.
I've also read that the two new engines will also find their way into the Miata. How about a 50 MPG 6-Speed Miata? Ohhh, I wanteth much.
My point is I'd be willing to give up that responsiveness (in 6th only, mind you) and shift to accelerate at highway speeds.
Go drive one, especially the 2007-08 models. Accelerate in 6th at highway speeds and I swear you'll think you're in 4th.
We've been told "Next year" by manufacturers for a decade.
I'll believe an affordable Diesel car when I see it (ie - $15K, not a $30K yuppie fashion statement)
I'd be first in line to trade up. For me it's not even so much the mileage, as much as it is the range, due to a tiny gas tank. The low fuel light goes on at 260 miles for me (to be fair that's city driving).
Realistically, I'd like to see low 30s highway mpg instead of 28.
SkyActiv should help a lot, Mazda3 improves by leaps and bounds with that tech. Question is, can they do the same for the more tuned 2.0l in the Miata? Or will they scrap that and put in a smaller displacement engine with DI to compensate for the loss in displacement? We'll see.
New subcompacts like the Accent 5 door start closer to $17k.
Add maybe $2k or so for the turbo diesel, and you're looking at $19k at least.
Let's aim for "under 20".
My main complaint against the Miata, a truly brilliant car, is that the exhaust note sounds like a can full of gnats. It's hard to take the car seriously when it sounds like that.
Granted my bone stock 2009 2.0 liter Mazda3 5-Speed is not as fuel efficient as some, I am still able to coax between 38 and 39 mpg out of it on the highway (if I keep the speed at 70), and more like 35 at my more usual 75-80. What may shock many is that my car returns that reasonably good fuel economy in spite of the fact that the gearing is set up so that I'm running over 3,000 RPMs at 70.
In theory, you could gear a normal bicycle to go 100 mph, but in fact, you can't,** unless maybe you pump up the cyclist with steroids and some cyborg muscles.
** Actually I think the record for pedaling on a "bike" on the flats is 83 mph, but that's on a bullet-shaped machine that fully enclosed the driver.
Agreed, for the sake of argument, if Mazda was to take the 5-Speed in my Mazda3 (which as I stated above has me running just over 3,000 RPMs at 70 MPH) and give it a 6th gear yielding more like 2,500 RPMs at that same 70, I don't see any reason why aerodynamic drag would become much of an issue shy of say 120 mph.
Or buy one from Getrag, Aisin or Jatco.
They would have to draft a truck.
I've had this discussion not long ago with wwest. He seems to be under the impression that the engineers who designed a car made it perfect in every way and should not be second-guessed.
Yes, regardless of the fact that my GTI can accelerate uphill from 40mph in 6th gear, I was informed on this board it NEEDS to be geared that short because the engineers said so.
The tall 6th gear will help the highway MPG, but will do nothing for the city/suburb MPG. For that you'll need to up the ratios in the lower gears. It's really city/suburb MPG that makes the big difference with all the around town/suburb driving people do. I think manufactures just throw on whatever gear will allow them to reach the magic 40mpg highway figure.
Well, those same engineers made the 2009 a little taller.
I guess engineers correct themselves all the time.
The odd thing, though is that the 6th ratio on my gearbox is shorter than the 5th ratio on the 5 speed manual. Now that's just ridiculous...
But that is the point. It was supposed to be a throwback to the old British roadster, although thankfully an infinitely more reliable one. Drive the English back roads and you will understand completely why they were designed to handle well, but were incredibly slow. The straightaways tend to be 100 yards long at the most and very rare at that so acceleration was irrelevant. You don't want to be going too fast when you can only see 30 yards ahead on a road that barely fits two abreast ( and some actually don't achieve that without both of you brushing hedges). Being lightweight and able to stop quickly helps there too.
To say that I don't understand that comment is an understatement. The fact is that with the five gears my car currently has, there isn't one city/suburb scenario where I cannot find a proper gear for fuel economy. The thing is, for all speeds under 40 mph, my current fifth gear is too tall, in fact, it's too tall between 40 and 45 if I'm climbing a hill (we have lots of those around here). If Mazda was to simply add a 6th gear to my transmission, a gear which would drop the 70 mph RPM down from about 3,050 to 2,500, then there wouldn't be a speed under 80 for which I couldn't "optimize" my fuel economy.
Funny thing, not only does Mazda already have a 6-Speed manual (and have had for some time), they're also designing a new one under the SkyActiv banner. Go figure. :shades:
I have plenty of power going up the grapevine and 5th gear is never needed unless speeds fell below 55 MPH on a steep incline, then a shift down would be adviseable.
Okay, yes, maybe you can accelerate uphill in 6th gear, but why would you not downshift and prevent undue stress on your engine..?
That would mean an engine upgrade.
Not so; his engine can produce more than enough power.
the passenger surely cannot prefer automatic in those cases when they don't notice it's a stickshift !
my 6-speed GTI is right around 2900 at 80. I wonder if the difference is DSG vs stick or if there are gearing differences between the Audi and VW.
And how difficult do you think it would've been to try and teach that woman to drive a standard transmission? Ponder that for a sec!
Please translate; as it stands your comment makes no sense and/or *appears* to be completely irrelevant regarding the topic at hand.
