Mystery car pix
16276286306326331422
    andys120andys120 Member Posts: 23,400
    bhill2bhill2 Member Posts: 2,474
    Wow! Well, my monitor prevents me from doing much with the cars on the far side of the telephone pole ( I think I see a '55 or so Buick and a '53 or so Lincoln), but on the closer side I see a '57 Chevy 210, a '55 Ford (V-8), a '54 Chevy, an early '50s ChryCo product, and up on the riser, a '52 (I think) Ford, a '57 Plymouth, a '55 (possibly '56) Plymouth, and a '56 Ford.
    Me thinks you got 'em all bhill2. I can't make out the ones on the far left either.
    michaellnomichaellno Member Posts: 4,120
    Jaguar XJ220
    Seven minutes! I figured the Jag would be good for at least 10. ;)
    stickguystickguy Member Posts: 50,683
    Ferrari F40? Or is that a GTO?
    kyfdxkyfdx Moderator Posts: 238,749
    Definitely not an F40..
    That thar is a Ferrari 512, I reckon. I'm gonna guess 1981 and a BBi, but not sure.
    12 cylinders, 302 cid, 360 HP 188 mph.
    edited January 2012
    That's right Shifty.
    You might be surprised to learn that this car is being advertised as a Testarossa!. We know that it is in fact a 1982 Ferrari 512BBi, the last iteration of the "Boxer". The Testarossa (as opposed to the Testa Rossa) began production in 1984.
    Would you buy an expensive exotic from a dealer that didn't know the correct name? :lemon:
    edited January 2012
    Well maybe it has red cylinder heads.
    Looks like a Fiat 500 wagon, what did they call those?
    fintailfintail Member Posts: 57,222
    The old Fiat wagon term was "Giardiniera"
    Keerect it's a Fiat 500 (or 600) Giardiniera. There is talk of one based on the new FWD Fiat 500.
    edited January 2012
    Giardiniera.
    Isn't that what they put on the sandwiches at Al's Italian Beef, in Chicago?
    Giardiniera
    Shucks, usually my fluent Portuguese helps me, but I would not have guessed that in a million years. Sounds like the Portuguese word "Jardineiro" for gardener.
    lemkolemko Member Posts: 15,261
    I'm thinking a Jaguar XK120. Sometimes the rear wheels were skirted, other times not.
    That's right Lemko. It's generally the earlier cars that wore skirts but if you ask me they look very cool with 'em.
    They made about 240 of these aluminum-bodied XK120 Roadsters in 1949-50 before switching to steel for volume production.
    grahampetersgrahampeters Member Posts: 1,786
    G'day
    The only car that has ever looked good with skirts is the Citroen DS.
    Cheers
    Graham
    They weren't exactly skirts, at least not the kind that could be removed. In order to change a rear tire you had to reach in and undo 3 or 4 latches and remove the entire rear quarter!
    magnettemagnette Member Posts: 4,157
    edited January 2012
    In fairness, on the DS you did save time on the other part of the job though - the hydraulic system allowed you to just pump the car up and lock it, then drop one wheel, unbolt and replace it, and then let it all back down.
    ...and put the rear quarter/fender back on. ;)
    I've heard that the skirts on the Jag 120 tended to overheat the rear brakes, which were none too good to begin with. Also no wire wheels if you have skirts. :(
    Might be why there were seen only on early 120s.
    Well the hupcaps suggest that someone is calling for BATMAN!
    Oh, I know, we just have to wait until the wheel turns 180 and then we'll have the answer.
    Willys Aero, ca. 1953...don't know if it's the colors or something, but I don't think it looks too bad.
    Or Super Mario Bros.
    I bet this guy drives it:
    http://userlogos.org/files/logos/zigzag/mario_0.png
    Yup, it's a 1953 Willys Aero Eagle. It looks as nice as the Pontiac Cheftain my Dad bought that year.
    tjc78tjc78 Member Posts: 15,966
    That has got to be an Alfa Romeo with that front end. I can't tell you what model.
    2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
    Maybe I should have said Wario instead, the yellow guy. :shades:
    wgraferwgrafer Member Posts: 592
    Nice turntable! What the heck is this????
    On the table, a '57 Oldsmobile; front left a '52 Buick; in the middle a '56 Lincoln; and on the right a '50 Ford behind a '49 or '50 Mercury.
    This was Dawn Donuts, located on 6th and Germantown Avenue in Philadelphia. You drive in, the turntable moves your car around, and you pull up to the drive up window
    imidazol97imidazol97 Member Posts: 27,171
    > Dawn Donuts
    Wow. I was wondering more what the setup and business was than I was about the cars!
    Where I learned to drive in Wales we had roads like that,without the turntable - but smaller cars, admittedly.
    G'day
    Wales still has roads like that; only the cars are bigger than you remember!
    Cheers
    Graham
    Last call for #32069. Going...going....
    Gone! #32069 was a 1967-ish Trident Clipper, produced by a small British company that combined Fissore coachwork with 289 Ford power. '67 cars were built on Healey 3000 chassis, later TR6 chassis and Ford V6 power
    were used.
    Later models had four headlights>
    explorerx4explorerx4 Member Posts: 19,385
    I like the glass above the doors of the building in the background. 'HOHO'.
    2023 Ford Explorer ST, 91 Mustang GT vert
    odie6lodie6l Member Posts: 1,173
    Odie
    Volkswagen Shwimmwagen, the amphibious, military version of the VW KdF (aka Beetle) used by the Wehrmact in WWII.
    Typ 166, as usual the baddie gets all the cool stuff :shades:
    BMW Z8
