General Motors discussions
1436437439441442558
  • drfilldrfill Member Posts: 2,484
    This argument bores me.
    Check Edmunds site for more information about the best half-ton in the land. Toyota will clean up the HD Class when they get around to it. Be careful what you wish for. ;)
    http://www.edmunds.com/apps/vdpcontainers/do/vdp/articleId=119281/pageNumber=1
    Good night.
    DrFill
  • carguy58carguy58 Member Posts: 2,303
    "I cant remember the last time I've seen a camry or accord at the top of JD powers intitial or 3 year reliability rankings. Oh and lets not forget Toyota and HOnda dealers never get top marks in customer service surveys by JD powers and others."
    Yeah but when did Chevy have top marks for customer serice? like never. You forgot Toyota's luxury always got top marks for customer service for a few years there and I know Saturn always gets top marks for customer service as well.
    "You know that to be a fact? The Altima and Impala havent been reliable? Fusion? They have been aroung longer which is a credit to them, but that doesnt mean they are the only reliable cars on the road."
    Yeah but the Fusion hasn;t even been out that long to gauge its reliability yet in my opinion even though in CR rates it great for reliability. As for the 2006 Implala and the 02-06(last gen)Altima(4cyl) they rate in CR as average in reliability and the 02-06 Altima(V6)rated above average in reliability.
  • m1miatam1miata Member Posts: 4,551
    Here ya go, the JD Power list link Honda looks pretty good by the numbers to me. Looks like Milan wins the prize, yet the Fusion does not. Interesting. You think CR is the only one with puzzling results from surveys. How closely mated are the Milan and the Fusion? Looks like, going by the numbers, the Sebring or a Passat would be something to be concerned about more than the rest.
    And what on earth happened with the Aura? I really was expecting more o the same scores as say the Fusion and Camry, though I see the Power- train Mechanical number is higher than the Camry = a good thing.
    Loren
  • pmuscepmusce Member Posts: 132
    Good night
    It bores me as well. Motor Trend and Car & Driver both chose the Silverado over the Tundra in head to head comparisons. What's your point? When Toyota does 'get around to it' and build's HD's and Diesal's we can talk, although there are rumour's that they may have cancelled the program. Do you know if this is true?
    By the way drfill, you always bring up the 6-speed vs 4-speed argument. Toyota only has the 6-speed on the 5.7 models. GM has 6-speeds on all HD models, both the 6.0 V-8 and Duramax Diesel versions. GM sells approx. 250,000 HD pickups a year, which means they sell way more 6-speed pickups then Toyota. My biggest beef with the Tundra is the 4.7, which does not belong in a pickup. That engine does not even have a chain (i.e. belt driven). Toyota should make a smaller version of the 5.7 to replace the 4.7.
  • dieselonedieselone Member Posts: 5,729
    A timing belt doesn't bother me. So you get it changed at 100k miles. I've had many vehicles with a timing belt and I have never had one fail before the recommended service interval. As for the 4.7, it does have quite a bit of torque at a fairly low rpm. Powerwise the 4.7 puts out 313ft-lbs of torque @ 3400rpm vs. 305ft-lbs @ 4800rpm with GMs 4.8. Which would you prefer?
  • 14871487 Member Posts: 2,407
    "BTW, both of them are V6."
    Compare the torque figures then get back to me. The V8 makes about 53 more lb-ft than the Nissan V6. No replacement for displacement. The G35 coupe is slightly faster than the Impala SS in spite of weighing a few hundred pounds less and having a manual tranny.
    "I can't believe they are completely different sheet metal when the belt lines to me look nearly identical. If they are completely different, GM wasted their money, because from a picture I can't tell a difference. Plus the Aura and 08 Malibu are both being built at the KC factory. I wonder if Aura sales will decline when the new Malibu arrives? Wouldn't surprise me. "
    anyone being honest can tell the difference between the two cars. They share length and wheelbase but are totally differnt otherwise. Try looking at the cars for more than 10 seconds before making such statements. I would concede that Stevie Wonder wouldnt know the difference between the two cars though.
    "Since your quick to point out when someone is wrong. I'll return the favor. The last gen Camry indeed had variable valve timing on all 3 available engines available i.e. 2.4Lvvt 4cyl, 3.0VVT v6, and 3.3vvt v6 (SE model). The Camry started using VVT in the 2.4L in 2002. "
    i was talking about V6 engines and the old 3L camry engine did not have VVT. It made the same hp since the 1992 camry came out more or less. I think it went from 188hp to 194hp, that was not due to VVT. I was aware that the 4 cylinder engine had VVT since it got 158hp. As I said, most last generation import cars did not have VVT V6 engines. I'm not even sure if the Altima with 240hp had VVT.
    Dr. Fill, you can pretend you know everything there is to know about the midsize car market and explain how the Camry is God's gift to the midsize market but if you think the Tundra has leapfrogged the competition, I would suggest that you have never owned a truck. The Tundra is a solid full size truck, but it is far from the class leader. When they pony up and offer an HD, Diesel, a real frame and can sell it on merit without massive rebates, let me know. I can't wait to see how big the rebates will be when the new 2009 F-Series and Ram debut along with the dual mode hybrid GMT900's."
    excellent response. Right on point. I pointed out numerous deficiencies in the Tundra before and he never responded. He always comes back to the same points: 6 speed, 4 piston calipers and slightly larger cabin.
    "Yeah but when did Chevy have top marks for customer serice? like never. You forgot Toyota's luxury always got top marks for customer service for a few years there and I know Saturn always gets top marks for customer service as well. "
    Cadillac, Saturn and Buick typically do well in dealer satisfaction surveys. Chevy and Toyota typically are not at the top. Dont see your point. Last time I checked Lexus is a different brand from Toyota and they provide a totally different dealer experience.
    "Yeah but the Fusion hasn;t even been out that long to gauge its reliability yet in my opinion even though in CR rates it great for reliability. As for the 2006 Implala and the 02-06(last gen)Altima(4cyl) they rate in CR as average in reliability and the 02-06 Altima(V6)rated above average in reliability. "
    good enough for me. If you bother to read CR's details about auto reliability you will see that cars keep getting better and the gap between "good" and "average" is actually quite small. If a good car has 1 problem per year and a "below average" car has 1.5 problems per year I will not be unhappy with the "poor quality" car such as Impala or Altima. BTW, one more reason I have no respect for CR is that they rate cars diffently based on engines. In most cars with two engines there are no substantial differences between models other than engines and possibly wheel/tire packages. I would love to hear CR's explanation for why they get different ratings for the same car depending on engine.
    "It bores me as well. Motor Trend and Car & Driver both chose the Silverado over the Tundra in head to head comparisons. What's your point? "
    I have been trying to figure out for some time why he is incapable of acknowledging the Tundra has lost more comparisons than it has won. He keeps mentioning the Edmunds comparo but ignores the others. He also has failed to mention Edmunds didnt even have pricing when they crowned the Tundra #1 which is kind of ridiculous. Even Edmunds conceded the powertrain was really the main benefit of the Tundra, other than that its pretty much equal to the Silverado.
    Toyota can claim exclusive rights to 6 speed for another year but GM trucks and F150 will have 6 speed next year in half ton models. I have heard nothing about a hybrid Tundra but I do know a Silverado hybrid is coming in late 2008.
    OK genious, where do you get our info. That is flat out incorect. My MIL has an 05 Camry v6. It has VVT right on the engine cover. Both the 3.0 and 3.3v6 have had vvt for several years. Just look it up. Autosite, Consumer. wikipedia, here is the specs from internet autoguide for a 2005 Camry XLE:
    2,995 cc 3 liters V 6 front engine with 87.4 mm bore, 83.1 mm stroke, 10.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder 1MZ-FE
    Unleaded fuel 87
    Fuel economy EPA highway (mpg): 28 and EPA city (mpg): 20
    Multi-point injection fuel system
    18.5 gallon main unleaded fuel tank
    Power: 157 kW , 210 HP SAE @ 5,800 rpm; 220 ft lb , 298 Nm @ 4,400 rpm
    Also, Nissan's 3.5vQ has had vvt since it's 2001 inception. I should know. That engine was in my '01 Nissan Pathfinder.
    Well, anyone being honest can see the similaraties as well. I'm not trying to bash the car. The previous Malibu was horribly ugly, so the 08 is a drastic improvement in about every way.
    Lots of people have a similar opinion as me. Just follow this link at Autoblog.com. A whole discussion on how similar the two cars are, along with the g6.
    autoblog
    Here is my response:
    http://www.edmunds.com/insideline/do/News/articleId=121824
    We can all be fans, and pick and choose the best truck. But the people's vote is all that matters, and it seems they aren't impressed with this brand new truck. GM didn't expect this.
    http://www.aicautosite.com/editoria/asmr/svtruck.asp
    DrFill
  • xrunner2xrunner2 Member Posts: 3,062
    Not sure who the guy is but he is an idiot if he thinks the Lamdas drove like the Venture.
    "idiot"?? Page 7 of July 23, 2007 issue of Autoweek lists Raynal as Executive Editor. Perhaps 62vette could give his credentials re writing about and "testing" vehicles.
  • grbeckgrbeck Member Posts: 2,358
    I wasn't referring to him in particular. Buick drivers in general are in the slow lane.
    The other day a friend - without any prompting by me, I swear! - remarked that when he is waiting to turn on to a road, he dreads seeing a Buick coming down that road, as he knows it will be slow drive behind it.
    If an old guy that bought 3 Buick's in a row doesn't go back to Buick, then Buick is doomed!
    But, they might go to Caddy. Saw a real old guy getting into his new looking DTS, burgundy color with tan padded roof and white wall tires, at a big box store yesterday.
  • louisweilouiswei Member Posts: 3,715
    Hey, did you mention torque anywhere in your previous post? I was merely following your train of thought...
    What's slightly faster? 0.5 seconds? I don't have the exact figure for Impala SS's 0-60 time but both the G37 and the 306HP (only!!) IS350 are running at the low 5s (R&T has the IS350 at 4.9 secs :surprise: ). By the way, like you said, this is achieved by engines put out MUCH lower torque than the SS V8. Which makes me wonder what's the point of those low output V8s (around 300HP) when the high feature V6s can do the same task with better efficiency? :confuse:
    Don't do that. That train has many stops. :P
    More information on the relative abilities of the SS. Slightly slower than 4.9.:
    http://www.edmunds.com/insideline/do/Drives/FullTests/articleId=107952
    A V6 Camry will smoke it up like a blunt. :surprise:
    DrFill
    RTs 4.9 0-60 was on a preproduction model. A later retest netted something like 5.5, IIRC.
    It's really not a fair to compare an Impala SS with a IS350 or G37. For one, FWD will always have a disadvantage due to weight shifting off the front wheels when launching. Also, flywheel torque/HP is not the tell all. You need to get that power to the ground. The Impala is saddled to a 4speed. An extra gear or two can make a huge difference.
    But this puppy was legal. It was just 6 months ago:
    http://www.roadandtrack.com/article.asp?section_id=7&article_id=4462
    DrFill
    Hmm, I thought it was RT, maybe it was C&D that tested a preproduction that ran around 4.9, then a later retest was about 1/2 a second slower. Not the low to mid 5's is anywhere near slow. The IS is definitely a sweet car.
    It is small inside, but the one thing you say when you step out of it is "That thing is fast!" It has a one-track mind.
    Not that I would get a slushbox.... :(
    DrFill
    I agree, it would be hard for me to buy that type of vehicle with and auto.
    You can't spot the same girl wearing a different dress? :confuse:
    Loren
    P.S. Something tells me the new Malibu rendition will be the winner of the bunch. At which point the G6 & Aura become redundant.
    It did. Nissan has had some form of variable timing on their DOHC V6s since the 300ZX back in 1990.
  • michaellnomichaellno Member Posts: 4,120
    Might that have anything to do with the number of Chevy dealers compared to the number of Pontiac or Saturn dealers?
    dieselone, you are wrong...
    R&T's 4.9s was on a PRODUCTION model. All the previous tests before that was on PREPRODUCTION models.
    Since this is a GM's forum this will be my last post about IS350 and G37.
  • chetjchetj Member Posts: 324
    with 162 k on it...but my bro in laws superior camrys timing belt broke and left him stranded in canada...not that he has ever maintained any car he has ever owned
    No doubt a timing belt will break. I've had several cars with timing belts and had one belt fail on a 86 Ford Escort I had in high school. While I'd prefer a chain, I wouldn't avoid a vehicle because of a belt. Get it changed at recommended mileage and you shouldn't have an issue.
    So when Pontiacs go all RWD, and have a total new line up of cars from down under, will it be the topic of discussion for the North American car industry. Will this be the new focus? Looked like a new life for Saturn, but drilling down deeper it is and isn't. Basically they are the same line of car of which say Chevy has, just a different look and dealerships. The new and unique then gets shifted on over to Pontiac. They will get the buzz. Is there a RWD small car though to replace the G6 (please give me a name) car? Looks like in a year or two there is promiss of some sparks coming from Chevy, with a New Impala and Camaro. If the Pontiacs / Holdens are good or is that great cars, perhaps Pontiac will steal the day, or at the very least share the spot light. Those dealerships are really praying for the new stuff, no doubt. Guess the next question is how reliable are Holden cars? JD Power info. not overwhelmingly positive, though inital quality control is but one indicator.
    Loren
    A kevlar timing belt will outlast the car, and most any timing chain.
    And will keep on working even in the worst gun battles :surprise:
    Maybe something Detroit may consider. ;)
    Are they using these on stock cars?
    Loren
  • cooterbfdcooterbfd Member Posts: 2,770
    HUH?????? A quote from YOUR LINK, BUB:
    So it's thirsty, but it's also quick. With its traction control active you can throw a brick at the accelerator and the Impala SS will rip to 60 mph in 6.4 seconds and bound through the quarter-mile in 14.4 seconds at 97.5 mph. Although that's quicker than a Camry or Accord, it's about two-tenths slower than the last Charger R/T we tested
    Bumpy, do they come factory installed? If not, what's the cost over a conventional one?
    That's nice. 303HP to get to 60 MPH 5/10 of a second faster than the Accord V6, while using getting less gas mileage. Sorry, but the V6 in that car is just fine. Adding DoD V8 to get to 60 MPH seems like one waste of money and who knows about repair bills. The DoD may be a leap into the unknown for reliability. Maybe a diet to lose weight would have been better, as the Accord with 244HP is almost as fast as the 303 HP Impala. Guess adding a gear would help too.
    Loren
    Guess I'll have to learn ya somethin': :surprise:
    http://www.edmunds.com/insideline/do/Drives/Comparos/articleId=109710/pageId=692- - 78
    DrFill
    Both your links show the Camry slower than the SS Impala (albeit only a couple of ticks, but the last one is the '07 Camry)
    Here's Car % Driver's link:
    http://www.caranddriver.com/features/12242/2007-chevrolet-impala-ss.html
    Base price: $28,655
    0-to-60-mph time: 5.6 sec
    Quarter-mile time: 14.2 sec @ 101 mph
    MUCH Quicker.
    Why does GM feel the need to have a 3.5, 3.6, 3.8, and 3.9L v6's? Along with the 3.5 I6 and 4.2I6. What other mfg. has this many different sized engines, much less v6s alone? I'm sure the reason has something to do with the state of current mfg facilities and union agreements,
    IMO, the 3.8 and 3.9 shouldn't exist, it's neither very powerful or fuel efficient. The 3.6 will cover those applications and GM could tune it to each individual vehicle, instead of having a completely different powerplant. Just think how many resources could be saved in the parts department alone.
    "Will this be the new focus? Looked like a new life for Saturn, but drilling down deeper it is and isn't. Basically they are the same line of car of which say Chevy has, just a different look and dealerships."
    How is Saturn the same line of car that Chevy was? Can you please explain more to why you think Saturn is the same car line as Chevy?
    What are you talking about? :confuse:
    Edmunds tested the Camry at 6.0, and the Impala at 6.4.
    How does that make Impala faster?
    Did Gagrice send you over here? :lemon:
    DrFill
    New Malibu is the Aura, and the SUVs are clones, aren't they between Chevy and Saturn? The Sky is what seems to be more liked look wise version of the Solstice, so I guess that is one for Saturn, though a low volume seller. The Astra will be a good import from Opel. All these are something borrowed, something shared. I take it the real volume of sales is from the SUV lines, which all seem the same between brands to me. Am I wrong?
    Loren
    GM's largest success so far is to build cars which Japan and Europe are not building. It should be obvious that Corvette and CTS are success stories.
    GM when brilliant, is making a CTS, which has no comparison. It is something to buy which is sporty and less expensive to own than is the BMW, and does NOT have to out drive a Bimmer to hit the mark.
    What are you talking about the CTS is something that the Japanese are not building? In terms of exterior styling no the Japanese are not building anything that looks like the CTS but on the other side of the coin you don;t think anybody crosshops a CTS with a Acura TL or Infinti G35?
    I;ll agree with you on the Vette the Japanese don;t build anything like that.
  • andre1969andre1969 Member Posts: 26,111
    Well, that 3.5 is actually an inline-5, not an inline-6. There's also a 2.8 4-cyl. Both of these engines are derived from the 4.2 inline-6, just with a cylinder or two removed. I think they're also designed more for torque, so they work pretty well in the truck applications where they're used. But then GM also has the 4.3 V-6, which is used as the base engine in big pickups, and I see a bit of overlap there. I guess they could ditch that 4.3 and use the 4.2 inline-6 in its place.
    The 3.5/3.9 are also basically the same engine. One just has a different bore and/or stroke from the other. The 3.9 is basically a copcar engine, and GM spread it to some civilian models to get more use out of it.
    Isn't old Buick 3.8 on the way out? I think the only cars that use it anymore are the base LaCrosse, base Lucerne, and the Grand Prix.
    I think the 3.6 DOHC is a relatively expensive engine, and therefore merits a bit of premium-car status, so GM isn't going to put it into too many cars for the masses.
    Oh, and as for too many V-6es, Chrysler was guilty of this for awhile. They have the 2.7 and 3.5 for cars, and they're both totally different designs. Minivans use a pushrod V-6, in 3.3 and 3.8 liter versions.. There's a 3.7 SOHC that's used in trucks. And just recently, they came out with a 4.0 version of the 3.5 car engine. So far I think only the Pacifica and Nitro R/T use it, but it may end up in other applications.
    I agree with ya, though. GM (and Chrysler too) could probably stand to drop an engine or two. Personally, I'd like to see Chrysler get rid of its 2.7 DOHC V-6, and just replace it with either a lower-output 3.5 or a different displacement version, such as the 3.2 they offered for a few years. My Intrepid has a 2.7, and while it's not a bad engine, and mine has been pretty reliable, it's overmatched in something like a Charger/300/Magnum, it's prone to sludging if you slack off on maintenance, and it's expensive as hell to replace when it breaks.
    I know in GM's case, the Colorado/Canyon have too narrow of an engine bay to take a V-6 engine, which necessitates the 2.8/3.5 inline engines. And I believe its engine bay is too short to accommodate the 4.2 inline-6. So I at least see some justification there. I kinda wish GM had based the Colorado/Canyon on the Trailblazer platform, which may have resulted in a more substantial truck, rather than just forcing us to accept something that was originally slated for the Taiwanese market.
    Quote from YOUR link ('07 Camry):
    Performance:
    0 - 30 (sec): 2.7
    0 - 45 (sec): 4.4
    0 - 60 (sec): 6.5
    0 - 75 (sec): 9.1
    1/4 Mile (sec @ mph): 14.6@97.3
    30 - 0 (ft): 31.1
    60 - 0 (ft): 124.0
    Quote from Car and Driver link on '07 Impala SS:
    Base price: $28,655
    Edmunds 6.4 sec for Impala SS was for '06
    I knew the 3.5 was 5cyl, don't know why I put I6. Anyway, I've always heard the Colorado platform couldn't accomodate a v engine. Isn't the Hummer H3 based off the same platform? Yet, Hummer managed to shoe horn the 5.3 in the H2 either for this model year or next.
    My new 07 tundra 5.7 just ate the transmission with less than 5000 miles on the vehicle. My truck is sitting at the dealer, while Toyota scratches its head. Anyone else hear of this or experience this? I didn't abuse or offroad my vehicle. It just happened while I was driving on the freeway without warning. The tranny started shifting all over the place, all the dash lights started going off like wildfire, and then I couldn't get it out of 4th. Toyota has now told me the tranny is bad and needs to be replaced. the trannys are backordered and they want to see my tranny to see what the deal is. they also said I am the sixth 5.7 this has happened to in June.
    doesn't sound too good. They're not the only one either.
  • imidazol97imidazol97 Member Posts: 27,734
    Translated: trannys are backordered. a lot of these are needed for repacing the failures.
    Translated: they want to see my tranny to see what the deal is. They don't know what's going wrong. Probably just a snap ring. Or maybe it's the supplier's fault?
    Did they use the Camry transmission in the truck? So much for the great powertrain compared to Chev and Ford trucks.
  • andres3andres3 Member Posts: 14,082
    Sounds like those Texans can't build a truck.....
    Okay so there are 2... :confuse: :confuse: :confuse:
    By the way, why would this post end up on the GM board is beyond me. ESPECIALLY the poster started a new thread on the GM board to post about Toyota is double beyond me.
    :confuse: :confuse:
    As you can see, I am super ubber confused.
