Nissan Armada Maintenance and Repair
I have a 2006 Armada with 12,000 miles. I have owned it for a few months and over the last couple months there has been a squeaking/grinding sound that is coming from the front end suspension. I believe it is suspension related because the only time it squeaks and grinds is when the vehicle passes over a dip in the road...when the compression occurs as the suspension reacts to the dip in the road the noise is produced. Anyone out there with a similar experience and/or some advice?
1. Roof TSB done twice, NOT fixed
2. Rear axle Pop/Click 5 times.
3. Engine pinging noise under passenger foot well.
4. Brake squeal, warped rotors etc 5 times
5. Misc rattles ALL over the interior.
The first time they repaired it, they said it was a bad regulator. I said Ok thats possible, but the second time they said it was a porton of the track assembly, that needed repair. Personally I think it's a lie, and I'm not happy. But at the same time if thats the worst that goes wrong...
Anyone else experience anything similar????
I didn't want to buy it this year, knowing that first production year is always a bit of a headache, but the wife was pushing for it. You see who won that struggle.
Tires, the second and the most annoying issue. Continental ContiCrap tires. This is my forth tire that will be replaced. These tires wear prematurely and treads are beggining to come of of one. Off course the tire dealer won't honor the warranty nor will Continental. Another law suit coming.
burning smell every once in a while, heat misses toes (you'll see when it's -5 :<), Great truck otherwise, dealer fixes everything. Rotors too small for truck like this.
What's the overall quality and your opinion about your Armada since you drive it for one year? Were there any other issues with Armada?
Anyone have a fuel gauge problem?
The service department is starting to get rude with me concerning my fuel tank issues.
What have they told you concerning your problems?
My dealer has replaced the plastic "switch covers" due to flaking/disappearing surface finish. Now the replacement covers are doing the same thing.(the switch covers have a sort of metalflake finish that is being rubbed off and now there is black "primer" visible).
I know my hands aren't greasy or oily (I work in an office all day) and I've never had this on my Tahoes, wife's Lexus, cell phone buttons or anything else. Dealer is getting pretty snotty about replacing the covers again - says I must have have been "scratching them with my keys".
Help !
Thanks!!
Can't tell you how many other problems I've had, though. I'm dealing with Nissan directly now after 10 service trips in a year!!
Other problems that I have had include a defect hole in the right front half shaft boot that required replacement of the entire right axle assembly, and shuttering front brakes that required the installation of a special repair kit that Nissan has come up with.
All of the items were warranty covered items and the work was cheerfully done by my local dealer's service department. I am unused to having to be bothered with these kinds of problems since our other vehicle is a 2000 Honda CRV; we traded a 2001 Toyota Sienna in on the Armada.
Overall, I appreciate the performance and style of the Armada, but so far it can't favorably compare to what I have experienced with Honda and Toyota products.
HELP SOON PLEASE.
I just remembered this after reading your email. I forgot to tell them when we were getting it serviced. We filled up when we were about to 1/4 of a tank and the gauge never showed that we filled up until a few days later.
I purchased a late 2004 LE 4x4 Armada(last on the lot-For a great deal under invoice), and have put over 5K on it since Late December. I haven't had any brake problems--knock on wood. I haven't had any fuel gauge problems--knock on wood. The only problem I've had is some squeaks and rattles (Dash and overhead console) which the dealer (Peoria Nissan, AZ) has fixed.
Otherwise, the Armada is a dream. Took it to Durango CO for skiing--no problem in the snow at all. All systems work fine. Mileage about 20 on the highway and 15 city. Tires look like new. My only complaint is the spotty FM reception on the stereo--dealer has ordered parts to replace antenna embedded in rear right window-still waiting for arrival (after 4 weeks).
Go with the Armada--BMW is too damned snobby!
Steve (Peoria AZ)
My only complaint is that it does not come with front mud flaps like the Infinity version. The optional front flaps from Nissan are cheap looking unlike the rear.
- Driver side window rattles when halfway down.
It was fixed and hasn't reoccured.
- Button to disable reversing sensor broke off.
- On a very cold day the driver side door lock froze in the "engaged" position so I couldn't fully close the door. It was fixed and hasn't reoccured.
- Rotors and pads went at 9500 (now have 10000) All replaced and haven't reoccurred.
Also I think I hear a slight rattling when I have the HVAC on anything higher that level 1. Not sure if this is a flaw but I haven't had it checked out yet.
Despite all of this I still love the truck. My Nissan dealer has dealt with all my problems swiftly and nothing has reoccured(yet).
Strange to say I can still recommend the vehicle despite my problems and everyone elses. It looks and handles beatifully and none of the problems have been dibilitating. The engine runs great, the transmission runs great, the 4WD runs great and I've have no electical problems and those are the things that would really scare me away.
Thanks - 81 trekker
- drivers side window weather stripping replace 3 times - came off the track.
- other three window weather stripping also replaced for wind noise
- sunroof replaced twice and it's cover twice
- one hub replaced
- brakes replaced and turned 3 times in 17K miles
- door lock froze - unable to close unless in locked position
all the buttons for brakes/door adjustments have broken two to three times
I notice that the fuel gauge indicator sticks and the airbag light is intermittent.
Apparently there is no fix for the brakes - If it wasn't for my service person at Silver Star - I would have returned the car long ago. The only thing is the truck looks good but it's one problem after another. Never had any such problems with our Honda, Toyota or BMW.
http://www.delsack.com
GoodYear has the same size tire (wrangler). There is some sizes to consider that will fit the 18" wheel, 255-70-18 and 275-65-18. Be aware of the load ratings on the tires.
The 04 Armadas had alot of problems since it was the first time they came out with this size. But now, most of the issues, if not all has been addressed. Is the Pathfinder going through the same cycle? I thought since Pathfinders have been around for a long time that they would or should not have any problems such as what i read hear. I thought all Nissan did was redesign the body in and out, and tweak some minor things.
If this all new design is gonna go through the whole cycle that the Armada did, wouldn't it be better for me to get the Armada? Help soon!!
Thought you might enjoy seeing Nissan Consumer Affairs reply to my question. They don't have a clue.
81 Trekker
Thank you for your correspondence to Nissan North America, Inc. It is always a pleasure to hear from one of our customers who has taken the time to write and provide us with comments about their vehicle.
We are sorry to hear of the concerns you have regarding the quality and design of your 2004 Nissan Armada?s tires. We recommend contacting your local Nissan dealer for technical assistance and recommendations. You may also contact your tire manufacturer directly for information regarding your tires.
Thank you again for writing to Nissan North America.
Sincerely,
Alexander M.
Consumer Affairs Specialist
and put in the size, 275/60-18 or 285/60-18. (There are more tires under the latter size.) Note the survey results and reviews. Michelin, Yokohama and possibly Bridgestone seems to have good tires in the latter size. Check with your local Nissan dealer if you want to be sure on size and load issues. Unfortunately, there do not seem to be any good all-terrain tires at this point.
81 Trekker
