13132343637473
  • stickguystickguy Member Posts: 53,896
    as for slow, my first brand new car (out of college) was a 1985 Dodge colt(1st year of the new body style). great handling car, but slow. Had a whopping 68 HP, and even with a 5 speed (and no AC to bog it down!) it was not speedy. Seemed fast though compared to a 1975 Corolla.
    the Colt was the only car that not only did I have to downshift to 4th to pull the hills on the Pallisades Parkway, I had to drop it into 3rd to not become a traffic hazard!
    Imagine only having to stand in the rainy cold blowing wind once every 1000 miles instead of 2 or 2.5 times as often.
    Long range would be a great feature if one didn't have to stop every hour or two anyway to find a restroom. :P
    The superior fuel is probably natural gas or propane for the big trucks and buses though.
    Yeah, with the 5-Speed the 2.0 liter mill is way more than enough for the Mazda3 (the 2.0 in 2009 only had something like 8 less horsepower than the 2.3) I actually joked to my 17 year old son (now a very proficient stick-shift driver in his own right) that I once had a car similar in dimensions to the Mazda3 with one-hundred fewer horsepower. He was astonished. That I stretched the truth a bit when describing the Audi 4000 is academic, it still got the point across. :)
    In my case, the Audi was my second new car, my first was a 1979 Scirocco, a car that was in virtually every respect (except one) superior to the Audi. Back in that era my daily uniform for client visits was a 3-Piece suit, and the brutal Chicago summers took no mercy on me when driving the Scirocco (which had no A/C). I drove the Scirocco 72,000 miles in 18 months (two summers was all I could take) before I traded it in on the Audi. The Audi in turn only lasted me another year and a half, this time to be replaced by the wonderful Audi GT Coupe of 1982 vintage (which was produced and sold into the 1983 calendar year and the only model year available with the full forty-five degree tuck and roll leather treatment). Mine was black with the very dark chocolate brown leather interior; very nice.
    Good news/bad news regarding the second Audi; shortly after starting my business I realized that the Audi was just too expensive for me to maintain; I think the car couldn't bear to be traded or sold off to another owner so it arranged for some dude in a 1974 Chevy Caprice Classic (a land yacht if there ever was one) to run a stop-sign at 8:00 on a Monday morning, and my Audi T-Boned the Chevy (totalling both cars). I came out without a scratch; not so my car, so violent was the crash that every body panel was bent except the metal sun-roof. The driver of the Chevy spent some time in the hospital and then some more time in alcohol rehab.
    edited February 2011
    ,I think it can cut any number of ways. If I had said that about diesels you would have probably said not enough of a sample to really say.
    But really in the passenger cars area how many people really do run medium duty engines ??? The main one with me would be what is the real Hino nexus with the average gasser truck engine and passenger car gasser satisfaction? Let me put it another way I didn't buy a VW TDI 2.0 because it burns diesel like a ...Mack truck. Or you probably didn't buy a gasser because it runs like a Hino.
    The general "rule" is that diesel engines last longer because they are built tougher because they have to withstand higher compression ratios than gas engines.
    All I'm saying is show me. From my quickie skimming, that "rule" may not even be true for diesel trucks, much less passenger cars. I like fleet studies - those tend to follow the bottom line and ignore "rules".
    Another thing I'm curious about in the beefier debate is whether the same drivetrain is put into cars with both engine options (does VW do that?).
  • crkyolfrtcrkyolfrt Member Posts: 2,345
    Are you asking if the same connecting rod that VW uses in a TDI, is used in a 2.0? If so, then no.
    I have lots of firsthand experience with 800000 to 1000000 mile heavy truck engines that were still running strong and some had had preventative maintenance lower bearing replacement at 400000 to 500000 miles and the old ones that were removed were all still within serviceable spec tolerances. Each engine had never had the head off. Each engine had a full set of fuel injector replacement when the bearings were done. Hp and torque and fuel economy was restored overnight. All engines had 12000 mile oil and filter changes, spec required airfilter changes, and coolant changes were stretched a 100000 miles. One engine had a turbo start to pull oil at 400000. That was fairly unusual. All engines were plugged in for winter starting, and RARELY and I do mean RARELY, were exposed to ether starts. All engines were worked hard, pulled 50000 to 130000 lb, but were cared for.
    I know of not one single heavy truck gas engine that has managed more than 180000 miles and even that was a rare beast. And if I recall I think the head had been off that engine even before it hit 100k. My memory is failing cuz that goes back a long time. The longevity potential for a diesel vs a gas, when treated properly, is just simply not fairly comparable as the diesel simply annihilates from everything from longevity to fuel economy to torque.
    I was thinking of the engine and transmission when I said "driveline". Do manufacturers hook up these "robust" diesels to the same transmission they use for the gas version of the car?
    180k seems short. My neglected minivan isn't too far away from that landmark at 150k. And again, I'm not sure that experiences like yours translate well to passenger cars. Surely there's lot of TCO reports for European diesel taxis out there we could dig up (and conversely, we could wonder why so few US ones are diesels - the new ones in NYC are Escape Hybrids).
    I know the feeling. :shades:
    In the VW, the answer is no, they are not the same. As you can well imagine, the issue is being able to handle the torque. So on a 03 1.8 T/122 ft #'s vs 1.9 TDI 155 ft #'s or 33 ft #'s more.
    2011 versions are even greater: so the
    2.0 L posts 125 ft #'s.
    the 2.5 L (5 cylinder) posts 177 ft#'s,
    the 2.0 TDI posts 236 ft #'s.
    Hey now, you're not supposed to blow my theories out of the water like that. :P
  • dave8697dave8697 Member Posts: 1,498
    612 mile range for a 27 gallon Astro
    These are summertime hwy numbers, 22.7 mpg for last trip I took to Fla in Sept.
    How a diesel gets 1000 miles on a tank has me puzzled.
    40 mpg with a 25 gallon tank, but what is small enough to get 40 mpg and still has a 25 gallon tank? My '70 Delta 88 had a 25 gallon tank. It was 21 ft long and 7.5 ft wide.
    Were you referring to my quote? I might have said 1000 mi, but meant 1000 km, and i was being conservative. I have a friend who just replaced his 86 Jetta 1.6 turbo. He has done 1100km= almost 700 mi (over 60 miles/Imp gal.) I didn't mean to mislead.
    well, for gas engines, NYC crown vic taxis go 2-300K at least (or more) without engine rebuilds or failure. and that is hard use!
    medium to heavy duty trucks are a whole different animal though. You just don't see many gas engines anymore it seems on those.
    Good find. They liked the Prius too, but the way they got there wasn't as strong as with the diesel/gas comparisons. Interesting that the F-250 gasser holds its value better; the engine reputation got around I guess.
    Interesting too that Bosch funded the study. I thought they did a lot more than just diesel fuel injection stuff; stuff that isn't limited by fuel choice.
    they cost more, but the VWs also tend to have stronger resale to more than make up for it, right?
    That and Power Strokes are not known to have very good FE compared to either the Cummins or even GM's Isuzu. Nonetheless, i have to question if it was a misprint. lol F250 gassers are also not known for their thriftiness, altho I guess I am thinking more than 3 years ago. Their newer engines with that 6 sp auto apparently do way better.
  • 4mercoachrick4mercoachrick Member Posts: 133
    Not a whole bunch of math involved in my post. $3/gal for gas vs $3.60 for diesel at our closest stations= 20% increase for diesel vs gas. During the last crunch, it was ~$3.50 for gas, $4.50 for diesel...and the diesel simply couldn't be found at many, many more stations vs outright gasoline outages. I couldn't tell you where the closest truck stop is...what I can tell you is I'm glad I wasn't 'deepinthehearto' Texas looking for one. If I could get the same performance from a diesel that I can get from our twin-turbo 3.0 Volvo XC60(avg over two years of 20mpg), THEN I might consider a diesel...remembering all the while what happened two summers ago when I drove 4000 miles in three weeks. Would you expect 30mpg avg from the diesel? 40mpg? in our 4400 lb vehicle? The numbers would still have to be significant to get my attention. Fuel economy isn't everything. Filling up every 360-400 miles ain't gonna kill me. Again, if I had to drive a much heavier truck hauling loads, that changes things considerably. I'm just answering the question posed in the topic title.
    Well, they say variety is the spice of life.
    All things being equal (& let me be the first to say they never are), they do tend to have strong to stronger resale values.
    If one does a quick scan of Edmunds.com (used car section) the (low) ranges for the GASSER 03 Jetta Sedan are $4,932 to $5,871 for the 1.8T . The (low) ranges for the TDI 03 Jetta Sedan 1.9 TDI are $7,7,36 to $8,313. The TDI is a range of $ 2,804 to 2,442 more and 56.9% to 41.6% more.
    Yes truthfully, I wish there were more DIESEL VARIETY ! :surprise: ;) A lot more oems and models make a lot more sense with turbo diesel and twin turbo options, including the Volvo XC 60 (in D) of which you speak.
  • bpeeblesbpeebles Member Posts: 4,085
    I find it interesting that you mention the Dodge Colt..... were you aware that had a Volkswagen engine in it (minus the Bosch fuel-injection which the Rabbitt used.)
    Dodge was so cheap, they used the VW engine (rated over 80HP with FI) and used a carburetor which dropped it to below 70HP.
    Weren't certain year Colts, basically Japanese? Which used a Mitsubishi (I think) 1.5 litre. Seems to me one of the models had an interesting dual range manual tranny, or something...I forget now. I think it had two ranges tho. From what I understood, aside from rust potential I think people were reasonable happy with them. I even think they turbo'd one but not sure.
  • george2040george2040 Member Posts: 1
    Three words: Toyota Hilux Diesel! The barrier to buying a diesel isn't fear of diesel, it's fear of long-term repair expense for a European brand car. If Volkswagen would follow Hyundai and offer a 10 year 100,000 mile power train warranty on a diesel Golf or Audi A3 I might be interested. I'd also be interested in an Acura TSX diesel with the European Accord grill in place of the shield/beak.
  • larsblarsb Member Posts: 8,204
    Correct on the Colts being Mitsu. My first car was a 1974 Dodge Colt and it was a Mitsubishi.
    Re variety, gosh yes. Anyway, I used that expression because I realized right away that some people are open to the possibilities of diesel superiority (especially in low rpm torque and FE) and others aren't and never would be no matter how compelling the info was laid out.
    So it takes all kinds and I guess that helps keep our world interesting.
    Btw, it wasn't me who mentioned the Volvo XC twin turbo. It was that other chap. I have a feeling it is a gas job, even though after a quick search, it appears Volvo had some impressive diesel options in an all aluminum 5 cylinder. I suspect tho, like so many other diesels, that they are probably not available in our mkt.
    For interest's sake, one of 2 diesels has 420 Nm torque from 1500-3250 revs.
    And the inline 6 cyl twin scroll gasser has 440 Nm torque from 2100-4200 revs. Both have impressive numbers, but when you consider the diesel has almost as much torque only it arrives 600 rpm lower, at only 1500 (pardon me while I take time out for a vicariously imagined giggle here for a moment) :shades: which is only just up off idle. That 600 rpm difference is pretty significant in real world driving because in stop and go, 1000 to 1500 rpm is mostly the rev range you are using. That type of roll-on torque, at diesel-normal low revs, is all encompassing and intoxicating. I believe that is why you enjoy your TDI so much. Not just for the FE, but for the very nature and characteristic of how the engine works.
    They listed another diesel that has 400 Nm torque from 1400-2750 revs.
    They are available in AWD with a 6 speed manual. I wonder if they know how lucky they are to have such options available to them? Probably not. It is human nature for us to take for granted.
    since you all mentioned it!
    The Dodge Omni was the car that used a rabbit engine (block, not sure how much more of it though). The Colt was a Mitsubishi underneath.
    The twin stick was on the model before mine (the run ended with the 1984 models). really neat car. My 85 had a normal 5 speed stick.
    the turbo model was the hot set up (would run with, or around, a GTI). I had the turbo package (suspension, tires, seats, trim) but without the turbo engine. Handly like a go cart, but slow.
    actually, it was much like a diesel at the time. You needed good handling to not have to slow down for on ramps if you wanted to merge safely! Momentum needed to be maintained at all costs!
    That was the Omni/Horizon that used the VW motor, not the Colt. The early Colts had the Mitusbishi 2.6 IIRC and the later ones had 1.5s and 1.6s. I know the later 80s ones (Dodge Colt GT) had a 1.6l turbo and the hot swap was the 2.0l turbo out of an Eclipse.
  • cdnpinheadcdnpinhead Member Posts: 5,631
    Yeah, me too. I bought my current daily-driver gas TSX when the rumour of a diesel TSX was fairly strong, about 3 years ago. Well, that was then and this is now. I don't think there's going to be a diesel TSX anytime soon, if ever, in North America.
    My original plan was to allow a couple of years for the diesel TSX to settle out, then trade mine in.
    Plus which, if it doesn't come with a manual, I'm not buying it.
    Oh well. . .
    Yes I think any oem that brings a "capable" diesel to our shores faces a lot more hurdles. To semi weave into what you are saying, the BMW 335 D (twin turbo diesel is a good example. For a three series (small car) the 3.0 L I-6 TT packs quite the power: (265 hp) @ 425 ft #'s of torque !! Their smaller and cheaper platform knocks the power cover off almost their whole offering line. In the US anyway it gets the BEST freeway mileage. Needless to say their automatic has to be beyond "robust". It really needs to be able to handle 450 ft #'s and more like 500 # ft. !!!! A 6 speed manual obviously can be fried in short order. I am no BMW expert, but I am pretty sure they do not have a 6 speed manual yet able to handle this monster torque. 36 mpg highway has to be a welcomed first for (US) BMW.
  • zambaqzambaq Member Posts: 14
    "Yes (you can google for the latest information) The .gov agency responsible for opening and conducting the investigation, documents 160 complaints (on the HPFP issue, Robert Bosch Co., oem vendor) of app 97,272 diesel engines (09,10 MY) or an aggregate of .0016448 %."
    Thanks for pointing me to the news about the report from the NHTSA wrapping up its preliminary evaluation of the HPFP problem, which apparently was issued just before I wrote my post about my personal concerns on the matter. How could I have missed that!
    Good to see that the investigation at least forced VW to go on record, making it clear to all that they were aware of the pump's vulnerability even before the first "Clean Diesel" was sold here. (So glad to be of service, Wolfsburg, as one of your unwitting guinea pigs!) Just as clearly, the company's response, particularly as illustrated by that excerpt from its May 2010 TSB, confirms what we already believed regarding VW's short-sighted strategy, i.e. to deny warranty coverage whenever possible on grounds of alleged fuel contamination. Hard to swallow the claim that gasoline is the cause of 90% of the failures (though if their own service jockeys and salesmen are pumping gas into TDI's, perhaps ignorance truly knows no bounds!). That assertion would seem to be belied by VW/Bosch's avowed efforts to beef up its fragile fuel pump -- 3 redesigns in 2 1/2 years! I don't think anyone really expects them to design a pump capable of surviving a diet of petrol...
    Although the overall incidence of HPFP failure doesn't look too bad statistically, unfortunately for me the rate was highest for the '09 MY -- a bit over 1 in 200 so far, worse than I'd hoped. On the other hand, now that the investigation has been elevated to the "Engineering Analysis" stage, the chances of an eventual recall would seem to be greater. So if my puny pump can survive long enough, maybe I can get me a more "robust" replacement....
    Cheers! ;)
    it would take a hell of a lot. With much fanfare and eagerness, he went out about 4 years ago and bought a Beetle TDI, one of the last years they still had a diesel for the Beetle. He believed all this crap you hear about how diesels last forever, VWs are such nice cars, etc etc etc, blah blah blah.
    After 4 years with the thing, he can't WAIT to trade it in on, of all things, a top-of-the-line loaded Fiesta. He had so many problems with the Beetle, lots of them paid for by him because he has a long commute and so does a lot of miles in a year, that he says he will never consider another VW or another diesel ever again.
    He also wasn't that impressed with the mileage because he had a spouse with a Prius, and all the times he couldn't drive the VW for extended periods, he drove the Prius in and so had a chance to compare the mileage back to back. He said the Prius was always 5-8 mpg better. He has a fair amount of stop-and-go to get through each day.
    To say he would never consider another VW or another diesel is very strong words, but I was witness to some of the strandings that VW did to him, and I can appreciate how he might feel that way. I feel confident that diesel has no future in America in passenger cars unless some non-premium make BESIDES VW starts to produce them in large numbers. Perhaps one day we will reach the point where every person's first VW is not automatically his/her last, but we aren't there yet....
    I think it is (now) fairly well known that the new Beetle has fallen quite short of people's expectations of reliability, at least compared to the Golf or Jetta. And those issues, by human nature, has likely contributed to tarnishing his opinion of the powerplant. But I get the feeling he did have engine specific issues also. Did they surround the troublesome HPFP's?
    Tell us the specifics of his disdain for the diesel.
    And to be fair, anyone who has never had or considered a diesel before, that then ventures into oil burning waters, sometimes inadvertently bring upon themselves their own grief. Like lending their car to a friend or neighbour who 'tops up' the tank with gas. Other woes that can surround diesels (although doesn't seem to apply to your co-worker, but does to many) are owners who do very short trips and the engine never gets a chance to warm up properly because it produces heat almost too efficiently. And cold weather climates exasperate that further.
    CR's and other auto magazines have rated reliability and durability poorly on the VW Beetle ( mostly gassers 96% + and by default Beetle TDI's, WAY less common: less than 4% of Beetles)
    I would certainly agree that VW's (gasser or diesels) are not for everybody. I would also most certainly agree that turbo diesels are NOT for everybody. I think you can say the same for gassers, even as they are 98% of the passenger vehicle fleet. I would also agree that VW's probably has/have more reliability and durability issues percentage wise. Because they are a relatively small to niche market share (03 MY=225,000 Total produced) VW's TOTAL 1.5 to maybe 3% of the total US market share, that other oem's " more reliable and durable" might have less percentages, but have much GREATER NUMBERS of reliability and durability issues.
    I am a tad confused (logic wise). IF he had such good luck with the Toyota Prius,(why has) he has decided to get a Ford Fiesta ??
    "Is this only on the 2.0 TDI which they call Clean Diesels? In Cda, 06 was the last year for the 1.9 TDI. We had no TDI's for 07 and 08. Then out comes the 2.0."
    Correct -- the TDI timeline was the same in the U.S. The gap was due to the more stringent emissions standards that went into effect. In order to meet them, VW had to redesign its injection and emission-control systems, so the 2-liter "Clean Diesel" comes with EGR, a particulate filter and a NOX trap, and the Pumpe Duse was replaced by a Common Rail. Meanwhile the U.S. & Canada were replacing sooty ol' LSD with cleaner-burning ULSD, which without sufficient additives, has much less lubricity. New system, new fuel, ergo new problems. And to compound matters, it now appears that VW released its new version TDI in a kind of beta form so that we early-adopters could have the honor of testing it for them!
    Planned obsolescence or, as you put it, padding "the profit margin on the customer's dime", is certainly nothing new (maybe the heart and soul of capitalism?). But if we are to be made guinea pigs without our consent, then VW should be made to bear the cost when the experiment goes awry!
    Anyway, sounds like you've had a pretty adventurous motoring life, so may the road stretch onward! :)
    Your post raised an interesting wonderment I have had for years.
    It is not uncommon to see a higher tow rating in vehicles which can be optioned with either an auto or a stick, with the autos. And this example seems to hold true whether comparing a modern day car like a Chevy Cruze, all the way up to a Dodge Cummins diesel.
    I have always assumed the mfgrs were concerned about clutch or 'smooth' use of the tranny in the manuals, so the autos were, by nature of the beast, more naturally immune to abuse. But I still have not read any definitive reason, unless that's it in a nutshell.
    It's not as if they can't build a manual to withstand the stresses of monster torque...consider big trucks...their manuals are actually more sturdy than their autos. Granted it will be beefier (read heavier) in every way, but then, surely an auto capable of big torque must be more sturdy also?
    If I could buy a 3 series with that wonderful diesel (providing it had an oil sump dipstick), great seats, and a 6 speed stick with AWD, if not for my concerns with "The Right to Repair" looming forever over me and my limited funds, I could actually justify a one last time huge lay down and have that car go to the end of my driving years. Of course I would have to keep an eye on rust potential so might do an annual chassis oiling. Anyway.. :( the Right To Repair is the biggest of deal-breakers even if a 6 sp stick and AWD could be had.
    It's a chick car.
    Hmm, but he had a New Beetle (even the TDI can't overcome that "stigma").
    Nevermind. :shades:
    "But if we are to be made guinea pigs without our consent, then VW should be made to bear the cost when the experiment goes awry! "
    Gosh, no one could say it better.
    So regarding the lower sulphur content diesel we are forced to use now, what are the ramifications on longevity when used on older diesels, say the first generation TDI's up to 2006? What about on the pre TDI's?
    My friend recently replaced his aging but much loved 86 Jetta turbo dsl 1.6. He bought a 2011 Golf wagon TDI. Dan and I are both mechanics and fear the Right To Repair issues have already infringed on our usual practices of doing all our own repairs. But it was very evident on my last call with him as you could tell that as he explained the complexity of his new car (eg pumping fuel back to the cat for burning off carbon etc) and etc etc that I couldn't believe my ears when even Dan, a diehard do-it-all himself no matter what it is, relented and said he feared the time has finally come that the new cars now are very strategically designed to put us shade-tree mechanics out of business.
    I can buy his old 86. But it has many many troubles. Leaking fuel pump is one of the biggies $wise. It has a lot of miles, but have been cared-for miles. Can only guess the miles cuz the odometer broke over 10 years ago around 175k. Pretty sure it is deep into the 300's now. Engine and turbo does not use oil. (He idled it down for a minute every single shutdown to keep the turbo bearings lubed if he had been working it either spirited up his own street or any destination atop a hill). He drives heavy truck also, so I know the tranny and clutch will be fine. But suspension is tired all over again. He replaced all four corners about 12 years ago. I had thought of buying it to see if it could be a spare 2nd car for summer use. But alas I think it is just used up a bit too much to justify it as a project. A lot of moulding has fallen prey to the rays of the sun of course.
    An interesting piece of trivia I think you (and a few others..ruking etc) will appreciate..the entire exhaust system (save for an aftermkt hanger bracket or two) is still original on that car. And that was pre-SS systems. Not without a bit of on-your-back effort mind you.. twice in the 25 years, when he used a portable propane/oxygen torch kit to reweld some pipe unions at the muffler and front pipe. lol Isn't that incredible?? Show me a gas job that can go 25 years on the original exhaust system...soot is your friend, my friend..LOL :shades:
    I've read that before ...
    gerbs, "Jeep Liberty Diesel" #10886, 23 May 2010 4:28 pm (last sentence in the post).
    I mus tlike to live on the edge. The upcoming passat is going to offer the TDI with a 6 speed manual.
    If I had the commute to justify the premium, that would be high on my shopping list.
    hopefully by the time that comes out, they will have worked out the bugs on the powertrain! Oh, and a nice long powertrain warranty sounds good (though since I would likely only but a TDI if I was going to put a ton of miles on it, a 100K warranty won't go that far).
    Put me in the camp of wanting Ford to put on in the Focus hatch, or maybe Honda in the upcoming Civic redesign (along with the 5 door hatch, am I being greedy?)
    Yes, well said. I would also agree.
    On the ULSD (15 ppm sulfur by law) issue, BUT (nominally delivered at the pump between 5 to 10 ppm sulfur) it can be a two edged sword.
    Some good news RUG to PUG is 2 to 18 TIMES dirtier !!?? Not even many in the know eviron cons know that ppm sulfur by law is 30 ppm. It also can be delivered@ the pump up to 90 ppm sulfur with "OFFLINE" FEE mitigation. Biodiesel for discussion purposes is pumped @ 1 ppm sulfur (ZERO is more the rule) So in this example RUG to PUG can be up to 90 times dirtier.
    Another item is most later model diesel are actually designed to RUN lower ppm sulfur diesel. So in that sense ALL good.
    If there are any concerns with lubricity one can run an additive. Another is run bio diesel every so often.
    Well, he says leather seats are a must-have, etc etc, plus he really likes Sync. To equip the Prius the way he would want it would give it a sticker about $8000 more than the Fiesta or something like that, and he still wouldn't have Sync. I think he is dumping the VW earlier than he intended to replace it, and so going with a less expensive vehicle as a result.
    Diesel continues to be $0.25/gallon MORE than premium unleaded in my area, as it has been consistently for well over a year. That makes it about $0.45/gallon more than regular unleaded, or about 13% more at current prices, which is one more reason I probably would go hybrid before I would go diesel. But a really good diesel small car from anyone besides VW would get a look from me even so.
    690 lb-ft.
    Sometimes it's just fun to make you torque fans drool, lol.
    Dyno-Tested: Dodge, GMC And Ford Heavy-Duty Diesel Pickups (Straightline)
    I would settle for half that torque and twice the MPG in a midsized PU like my Frontier. A 2.5 L diesel is more than adequate to pull as much of a trailer as I need and return 30+ MPG. The only reason people buy those big diesels is that is all that is available. My guess is more than half would buy a 1/2 ton with a smaller diesel engine, if they were not penalized by the IRS and regulations. It is a regs game to keep the higher road tax rolling in.
    I read in passing about a (custom) Corvette that got a (re/de) tuned GM (truck) turbo diesel . Evidently it is able to post 48 mpg @ app 75 mph.
    How much could it tow?
    probably a gas job... inside-out ;)
    I truly have nothing against folks who chose to pay more per mile driven like for like). I also do not think any time soon you will see a smaller car (hitting our shores) getting better than 50 mpg that is so called "affordable". Not to use a VW example, but @ 70 mpg. VW Polo
    As for the price of fuel per gal most folks over look the real calculations 1. like for like 2. per mile driven.
    So for example the real competitor for the VW Jetta TDI is a Camry Hybrid. As such it is thousands more and gets worse fuel mileage than the Jetta TDI.
    Some folks claim to "run the numbers" but I OWN the numbers. I use a spreadsheet to track every drop of fuel pumped into my TDI.
    The real number to "run" is Cost Per Mile. This metric can be used to compare apples-to-apples between ANY vehicle no matter what fuel it consumes.
    My TDI (over 120K miles) averages $0.09 USD per mile.
    I dare you to find another vehicle available in North America that can come even close to that number.
    Lets not forget that VW Jetta is a REAL car with heated leather seats, thick steel body, Unlimited Mileage corrosion warantee and German roadcar manors. It has returned 56MPG with 4 adults on a 12-hour trip during 90 degree weather with the AC on high the entire trip.
    The "hybreds" I have looked at are made of thin metal, cheap-feeling materials and do not drive like a German car. Oh- and dont forget to "run the numbers" on replacing the battery-pack.
    Yes, I just ran the numbers for the 03 Prius/Camry/Jetta TDI/Jetta 1.8 T. One can cusomize it for whatever realities one actually projects and or sees or even a look back. (Mine happens to be @ 20,000 miles average)
