Chevy Silverado Problems
-- Don
Ryan
I personally see no reason to not use Mobil 1 when I change mine. As for the front axle, it calls for 80W90 lubricant, so I'll need to do a bit of research on that one. All I can find in the stores is 75W90 lube. As for those who have AutoTrac, I believe that you do have to go to the dealer for that fluid.
Erik
What does autotrac have to do with the rearend?
I know heat kills, but GM is telling me my truck has sufficient trans cooling capacity from the factory, even for class 3 towing. I find this hard to believe.
If your second sense is telling you "it ain't right" beleive it and act upon it, don't believe everything your told by wanna be technicians or inept service reps.
Ray T.
Ryan
My truck only has 6000 miles and is used strickly for hauling or towing. I even use this truck for towing in 4 wheel drive Lo in off road conditions. I do not want to void the warranty beacuse I may need it under these conditions. I suspect the trans and rear axle are the weakest links. I already have had the front diff replaced. The engine I expect to last forever using past experience.
Are you removing the cover off of the back of the diff.?
-David
Ryan
Also, what's the torque setting and installation pattern for those diff. cover bolts?
You don't want to void that warranty now.
-David
Seriously, I'm coming up on 20k miles, and I love this truck. Sierra Excab 4x2, 5.3l, 3.73. Great truck with no problems.
Peter
Also the torque setting is 30 ft-lbs
I click on your posted link, a new Netscape window opens up, but there is nothing displayed in it and no pages to print either.
Try
http://home.att.net/~m.prendergast-alliedsignal/
at the top click on the silveraod link
Ryan
-David
Ryan
"I am interested in using RP MaxGear oil in the rear axle of my 2000 model Chevrolet 3/4 ton truck. The owner's manual calls for 75w-90 synthetic axle lubricant meeting GM specification 9986115. Does RP MaxGear oil meet this GM specification number?"
the reply from Royal Purple:
"Royal Purple Max Gear is suitable for your truck meeting all specifications required by GM (API GL4/GL5 and GM 9986115) for warranty use. thank you for your interest in Royal Purple."
Sounds good enough for any possible warranty problem to me. Now using RP Max Gear @ $8/qt.
not to be anal but many salesman will tell you anything like i learned talking to bilstein yesterday
Ryan
I feel you should be able to use WHATEVER you want in your truck without issue. Im not telling you what to do.. just trying to open your mind a bit.... And in any event NEVER trust the dealer... they are out to make money and that is the bottom line.
My 2 cents anyway. Have a good weekend man!
Later,
Jim
-- Don
I've got to believe GM when they say the truck can tow with no additional coolers.
Mike L
Jim
The good news is that GM Parts Direct has GM spec gear oil for $15.60/quart. GM Wholesale is given as $19.50, and GM Retail is given as $26. The bad news is that it comes in a 12 pack quantity.
Some of you guys that live close to each other may want to coordinate purchases. How much oil does a front and rear differential oil change require?
Mike
Well, I like to always do the job better than it would be done by someone else.... so I used the gasket and black RTV sealer.
And .... 500 miles later I have a small leak from the cover!!!!!!
Next time I'll try the gasket alone if the machined surface on the differential carrier and cover look good.
2001 Silverado 1500 ext cab 4x4 Z71 LS model.
Is the a/c compressor supposed to be engaged
when the recirc switch is on, a/c switch is off,
vent is selected (not defrost) and regardless of the temp selector?
Mine does. This is against what I believe should be true.
If you turn off the a/c switch the compressor should not engage (unless you are in defost).
Can anyone with a 2001 shed any light on this?
Thanks..
-- Don
It took 2 quarts and i estimated about 9ozs which is .28 quarts. So about 2.28 qts total.
Hardest part of the whole thing was getting the rear cover off. Was under the truck foot on the rear bumper and two hands pulling. Finally it came off and went flying into the driveway. Old gasket looked like crap. Could barely even tell it was there.
Some metal shavings around the magnet. Fluid came out kinda greyish looking. Also the last of the fluid to drain looked like a milky color.
Thanks for all your help guys i really do appreciate it
Ryan
Grey and milky; suspended fine metal particles and moisture. Damnit, now I'm going to have to change mine, too. Figure with buying a MagTech cover that job should only cost me a little over $300 if I use Mobil 1. Maybe I could change to 4:10s while I'm in there and then have to do the front end, too, and really drive the bill out of sight. Why didn't you just leave well enough alone?
-- Don
I dont believe this. I am going to do a little checking around...
Only way to get another brand is to shell out some $$$. Thats what i did and i am glad i did it.
Ryan
Ray T.
We are heading up to Ontario end of the week for some camping and as yet I haven't changed my rear end fluid so far w/18,000 miles to date but probably will after this trip.
Ray T.
