Engine Oil--A slippery subject
145791013
    #312
    To add to what this post has said, the syn product has a very low ash content. (ash is the thing that causes sludge) Conv oil has high ash content. (which is one reason why you want to change the conv oil much more frequently.)
  • ggosselinggosselin Member Posts: 22
    I have to respond to the claims that syns. "eat" oil seals; this isn't true.
    Synthetic oils DO NOT have the same chemical properties that parafin-based (conventional) oils do. Hense that synthetic name.
    1. Most importantly, they DO NOT make dynamic seals swell- seals such as the rear and front main seals. Conventional seals do this, and as a result, have fewer leaks due to oil related causes. These are the two most likely places for oil leaks in vehicles. Syn oil will not make them swell to seal around the crank thus causing a major leak. Reason being that they are such "slippery" oils that they will flow out of every crevice that they can.
    2. Yes, they do flow better at startup and maintain viscosity at high temps. but in comes that damn leak issue again. And besides, you're only going to change your oil @3k miles anyway right? If you do this with any oil- conventional or synthetic- you will have no problems with your oil breaking down.
    3. Yes, some cars do specify synthetic oils such as GM's Corvette (the only GM vehicle that specifies this), hi-perf VW cars (Audi, Porcsche), and most BMW and Mercedes vehicles.
    To be short- if your car don't specify synthetic, DO NOT USE IT!! Otherwise you will see leaks- big ones!
  • guitarzanguitarzan Member Posts: 873
    That's ridiculous. I've seen every post here at Edmund's on the oil related topics for the what, 1.5 years the Town Hall has been here, and have NEVER seen a rash of synthetic oil users talking about leaks. And you better believe, for every problem out there, a massive army of the folks who had the problem comes here to tell the world about it.
  • clintonjohnclintonjohn Member Posts: 99
    alphadog,
    from what i've read in various car mags and newspaper articles, it's ok to blend your own syn/dino mix so long as they're of the same viscosity. for reasons which i don't know and weren't explained in the articles, you don't want to mix say 5w30 with 10w30. if it were me, i'd just follow the owners manual recommendations as far as what weight to use at what outside temperature. i've blended a quart of synthetic with 3 quarts of regular oil in the winter with no ill effects, but also di not notice any appreciable advantage either. just did it for the peace of mind of having some quick flowing synthetic in the engine in chicago winter.
  • bluemistbluemist Member Posts: 23
    My experience with synthetic oil is that, not only does it NOT cause any leaks (after 90,000 miles and 3.5 years of use), but it protects the engine better even if changed every 4,000-5,000 miles.
    FYI, I never leaked or burned any oil from the engine mentioned above.
  • cooksterdogcooksterdog Member Posts: 9
    I, for one have used synthetics for many ywars. and one benefit i have seen CONSISTENTLY, is lowwer temperature of the engine here. [soutern caliof desert], it is usually in the ninetys and sometimes over 100!!I drove over 160,000 miles many,[maybe 10,000, in hot desert,.] the jeeps and pickups ALL run cooler by 5-10 degrees.in a nut shell, I BELIEVE IN SYNTHETICS,and a valve job on my 83 scrambler jeep showed NO sludge formation,
    unlike my buddys toyota which we did at about the same time! USE IT DO NOT DISPOSE OF IT IN AN IRRESPONSIBLE MANNER!! ALL OILS POLLUTE IF DUMPED!!
    What ordinary people don't know will hurt them.
    Synthetics may or may not cause leaks, it also has to do with things such as seal/block design.
    If the engine is designed so that front/rear main journal seals are so that they do not have to hold back any actual oil pressure applied to them, no, you may not see leaks. But if the engine is designed in such a way that it exerts oil pressure (not just splash lubrication)on the seals, yeah, then it will leak. It also depends wether or not the car was manafactured with the highest quality parts avilable at the time.
    How do I know this? These RIDICLOUS facts?
    I am a retired Mechanical Engineer for GM truck and Bus, and have seen firsthand what synthetics will do to some cars&trucks. My neighbor for example, he owns a 1997 Chev Blazer w/4.3 V6 CPI.
    He used Pennzoil's Performax 100% synthetic for 2.5 yrs and had amassed 25k miles. One day, he started to notice oil leaks on the carpeting in his garage. His rear main seal was starting to leak. I asked what type of oil he was using, he told me, and I recommended to him to switch to a conventional 5W30 oil. He started using Castrol 5W30 and within 250 miles, POOF! The leak magically dissapeared! Not even any residue seeps out past the bellhousing!
    Folks, I know what I'm talking about and don't appreciate the cocky attitude, I'm just trying to explain a misconception about different types of oils.
    Thank You,
    John Dawson
    -If you don't want to take my word for it;
    just look in your owner's manual and see what the oil type, viscosity, and change intervals are.
    Follow these and you probably won't have any oil realted troubles!
    Ggosselin, I have great respect for your professional opinion and experiences. I just have one question: The Blazer, among other vehicles that may exhibit the same problem, is one of the most popular vehicles in America. Where are all the people who have nearly new Blazers, and accompanying oil leaks? Or for some reason no Blazer owners use synthetic? You probably don't know the answer to this, but you at least understand my point of view?
    Guitarzan-
    I have not a definite/concrete answer to your question, but I was just trying to make a point to the fact that synthetics may be the underlying cause to some unknown oil related leaks. Some people may not even know that the engine problems that they are having are due to the fact that they aren't using the right kind of oil. I also have known some people that have had cars with small ohc alumnium engines designed for lighter weight oils, such as Hondas, Toyotas, etc. but insisted upon using somwthing like a 20W50. First of all, the engine is not designed for this, needing a strong flow of oil almost instantly to keep parts lubed properly. The 20-50 can't be pumped fast enough, and over time, excessive wear occurs on parts such as cam lobes and cylinder walls ultimately causing breakdown.
    One may not know the reason for the failure may be within the type of oil that they used, not just based upon a mechanical problem.
    This maybe what I was trying to say moreless; knowing the proper oil for your vehicle is one of those things that you may just have to trust the engineers that designed your car and use the maintence items that they specify.
    There are a lot of different types of oils be it synthetic or conventional, but as I have said, the best ones are those recommended by the manufacturer. If your hi-perf car says to use synthetic, by all means, use it! But if it just specifies plian-jane 5-or10W30 or your diesel specifies regular 15W40 that meet requirements SH, SJ, or CG, then those- at least from my personal experiences- are the ones to stick with.
    You have to change your oil every 3k mile anyways, right? Why spend 3x more for something you don't really need?
    Not trying to badmouth anyone, I'm just trying to share my experiences to maybe be able to help someone understand why things like this are the way they are.
    1991 Volvo Turbo-Castrol Syntec 5w-50 changed every 4K miles; NO LEAKS when sold at 48K mi.
    1993 Nissan Pathfinder SE-Switched to Mobil 1 5W-30 in 1994 at 37K miles. Oil changed every 6-7K miles. NO LEAKS at 110K miles.
    1987 BMW 535is-Switched to Mobil 1 15W-50 at @90K miles. Oil changed every 4.5K miles. NO LEAKS at 290K miles.
    1995 BMW 318ti-Switched to Mobil 1 15W-50 at 4.5K miles. Oil changed every 4.5K miles. Car sees 4-6 track days per year. NO LEAKS at 44K miles.
    1998 BMW 318ti-Switched to BMW 5W-40 Synthetic at 9K miles. Oil changed every 9K miles. NO LEAKS at 18.5K miles.
    1984 Ford Thunderbird Turbo Coupe-Castrol GTX 10W-40 conventional oil changed every 3.5K miles. A 120K miles, oil leaks at valve cover, rear main seal, and at oil pan.
    Sure, this is just my personal experience, but don't you think that at least one of the cars using synthetic would show SOME leakage? Just my $0.02
    #323
    No leaks TLC 94,96,97, Syn oil. rtfm for proper viscosity.
    I agree that the most important thing is to follow the manufacturer specifications ESPECIALLY with respect to viscosity.
    However, as long as you follow the specifications, and your engine doesn't show any unusual leaks (which very few do), synthetic oil is superior because it offers better protection especially at engine startup.
    If most engines leaked oil or had other problems with synthetics, nobody would use them and synthetic oil wouldn't be produced for normal cars.
    Also, owners' manuals would clearly and explicitly state "DO NOT USE SYNTHETIC OIL IN THIS CAR BECAUSE IT MAY CAUSE ENGINE DAMAGE AND VOID THE WARRANTY" or some such disclaimer, like they do for oil additives.
    So, I'm pretty sure that most people won't have a problem when using synthetic oil.
    If I were an oil company, I would not sing too loudly the praises of synthetic oil. I would still produce/sell it. It costs the same or less to currently manufacture and in some cases sells for 2-4x the price.
    But, no other product has the capacity to DECREASE the usage of conventional oil by 2 to 3x than synthetic oil.
    So dress up the "powerful wolf" in grandpas/grandmas clothing, and announce how good it is (not many will believe it, let alone switch) and you preserve the conventional oil for wide spread use. Some may call this devious, but I would call it marketing correctly to human nature.
  • robohaverrobohaver Member Posts: 1
    Here is a simple question for you.
    What is the difference between 10W30 and 10W40 motor oil?
  • mummamumma Member Posts: 2
    Has anyone recently purchased a 1999 SUV of any model? I would like to know what the Manufacturer recommends for the oil type. I have been using Castrol GTX 10W 30 forever (My current Jeep Cherokee has 187,000 miles on it) and I change my oil and filter around 3500 miles. I shoot for 3,000 but it is usually raining, snowing, or its Hunting Season! Anyway, I plan on purchasing my "RETIREMENT SUV" later this year and I'll be hitting the roads to see the USA via the "Backroads" From what I've read in the 300 plus responses, it seems that people who like DINO will stay with it and those who like the SYN will stay with them. I was thinking about trying the Castrol SynTech or Mobile 1 in my new vehicle so that I could do the ol' Oil changes around 5000 miles and save my aching back from the driveway. Any experienced comments would be welcomed!!
    Chris
  • rmoyarmoya Member Posts: 11
    Based on the plethora of info on this discussion I have narrowed my oil changes choices to 2 for my new Mazda 626 ESV6:
    1. Blend of synthetic and dino.(by the way, does it matter to use cheap oil i.e. walmart tech2000 and a quart of mobil 1.
    2. Synthetic oil all the way.
    I live in Florida and drive many highway miles during the week (50-70 a day on weekends I take a break and do normal city driving) and am looking to change about every 4000 miles. I dont want to seem cheap, but the price can really tally up using synthetic.
    Can anybody give me some friendly advice? Am I better off just using Dino?
    Any info is greatly appreciated.
    If you don't want to use full synthetic, I'd go with straight Dino Juice, since you won't get the protection of synthetic by only using 1/2 or 1/4 as much synthetic as DJ.
    I prefer to use synthetic and I drive 120 miles/day (highway miles), for the better protection. But, to each his/her own.
  • bobbybebobbybe Member Posts: 7
    Regarding question on #327 (ROBOHAVER)
    Someone above listed this link...it's a little
    dated but the basics remain the same:
    http://auto.msk.ru:8101/auto/ehoilfaq.htm
    Regarding GGOSSELIN the General Motors Man:
    I can get Castrol/Pennzoil-Quaker State at Kmart
    on sale for 99 cents on sale and Fram filters for
    2 bucks when they're on sale. The 99 Dodge is too
    new to discuss....the 89 Escort with 1.9L engine
    (the weakest thing on the road) no leaks/no oil
    consumption. Changed every 3 months regardless of
    milage. Cost averages out to 20 dollars per year per car. It doesn't get any cheaper then that.
    I totally agree to your phliosophy of the three month policy; it is one that I follow myself.
    I too change my own oil and (surprise) buy my supplies @Wal-Mart. You are one of the few people out there that follow maintence schedules religiously and benefits from them. It's cheaper to change your oil than your engine. I stand with the attitude that I have because of past experiences, and just want to let somebody know that certain things just aren't worth the extra expense. Especially when you're only going to drain that thirty bucks worth of oil every 3k miles anyway. Of course, if your car calls for the good stuff, by all means, use it! Otherwise, just use what the owner's/shop manuals call for and you will be fine.
  • gusgus Member Posts: 254
    Thanks for that link, bobbybe!
    You'll never use a Fram filter again!!
  • kd6awkd6aw Member Posts: 3
    I just sold a 1986 Nissan Maxima with 190,000 miles on it and had been using Mobil 1 synthetic. The engine used no oil at all between changes. I now have a 1999 Maxima and wouldn't use anything else. Mobil ran a BMW for 1 million miles on it and the teardown showed all parts to be within specs. The extra cost of the oil is really worth it and doesn't amount to much each year. Love Mobil 1 and no I don't work for the company. By the way all jet engines use synthetics because ordinary oils don't have enough protection at their high rpms.
    I have a 1999 Maxima and switched to Mobil 1 at 1,ooo miles. I called Mobil and they said it is fine to use it right from the start. Also many new cars are delivered with Mobil 1 in the crankcase ie Corbette, BMW and Mercedes.
    Paul
  • kevm14kevm14 Member Posts: 423
    Our 96 Maxima SE 5-speed has a tad over 60k miles
    and is actually 1,500 miles overdue for an oil
    change - it is scheduled (as well as the 60k
    service at a private shop) for next wednesday. My
    dad does not feel that Mobil 1 is worth the cost,
    but I think it is...so I just wanted to gather
    opinions on whether I should foot the bill for a
    few quarts of Mobil 1? It's not my car, but I
    drive it a lot, and given the fact that it's a
    5-speed, I tend to rev it up more than once in a
    while. so will the car last longer? Run cooler?
    More power? Go longer between oil changes? What,
    if anything, can I expect? Also, longevity is
    priority number 1 in my family, and if Mobil 1
    increases this substantially over a standard
    conventional oil, I want to know!!
    My dad is not convinced - he has talked to a few people at work (knowledgable car guys) about the use of a full synthetic...they say no, but he didn't give them the full scoop.
    He didn't tell them we have a 5-speed Maxima (read: it revs, so synthetic is good here)
    He probably didn't tell them I had Mobil 1 in mind, not just any synthetic.
    I am going to be footing the bill for the oil, that is for sure. But he won't even let me do that! I don't know what his problem is. What can I tell him that will be convincing evidence/convincing argument?
    I also told him many of you guys on here say Mobil 1 is good, but he believes the car guys at work over you. he thinks most of you are unknowledgeable and/or don't know what the hell you're talking about (i.e. what you notice is all psychological)
    Please help me here! I want our Maxima to last as long as possible.
    Well, he's right about me, in any case :)
    There is no substantiated proof that synthetic oil makes engines last longer.
    Personal belief: We know that when it is cold outside and/or the engine is relatively cold, the oil can take a substantial amount of time to reach all the parts of the engine. We do know that a substantial amount of engine wear occurs at startup. Synthetic does get to the parts significantly faster. I started using it mainly for that reason. Hey, let's face it, these newer overhead cam engines are sophisticated machines, and who wants the cams running dry? This is why I use the oil. Better flow while cold.
    During the summer? I use it anyways because of the ol' psychological thing your dad was talking about. I can tell you that when you are revving that engine near redline, a change from 5 to 10w30 will substantially reduce friction. At least I noticed that in my Integra. I could actually feel less vibration through the gas pedal! The effect on other cars, not sure, I leave it up to you to test it. I would never use thicker than that, though.
    Something way more important: Get the oil changed promptly. I don't know if it matters anymore if you do 3000 or 4000 mile changes. Just don't ignore it too long.
    Oh, hey, this is your dad's car? Don't spend the money. By the time the Maxima is aged and starting to lose power, make noises, etc., you'll have your own set of cool wheels. Save your money for that set of wheels.
    yes, it is my parent's car (officially my mom's, but you know how that goes). However, my mom said that when I graduate from college in 4 years, if I want, she will give me the Maxima. Now you see why I am so motivated...even so, it's not all self-based. I feel that I put that car (and all cars I drive on a regular basis) through an inordinate amount of stress (I like to drive - I don't beat it up, but I drive agressively and relatively hard) so I thought I'd pay for at least one Mobil 1 change as sort of insurance against future engine failure due to my driving habits...but one oil change with synthetic isn't going to do any good in the long run, unless my dad notices some differences, and then decides he wants to pay in the future, which is unlikely.
    So I guess you're right - not my car, so I won't worry about it.
  • citroen7citroen7 Member Posts: 62
    Can anyone tell me what the best synthetic base stock is. Both Redline and NEO claim theres uses the best base stocks. I am now using Royal Purple and they claim their additive synerlic is best for racing and of course all the major oil companies make a synthetic with various claims. I'm told the additives are a waste i.e teflon(military tests show no benefit). I'm told Cen-Pet-Co pariffin refined with syn additives is great too. Has anyone done any real testing and comparisons(any Magazines)I doubt it they would hurt advertiseing.
  • mtsangmtsang Member Posts: 70
    I had a 88 Accord that I got an oil change for a Goodyear service center. The numb-nut so overtightened the oil drain plug that he stripped the thread on the oil pan. He tried re-threading, bigger plugs, ...nothing worked. I finally footed out 300 bucks and had Honda replaced it. What a bastardization of a simple job.
    On the subject of synthetic: once a car starts using synthetic oil does it have to stay that way? or synthetic and regular oil can be alternate between oil changes?
    I think goodyear owes you 300. and not to worry any synthetic can be used, mixed, stopped, and, started, any and all the time. My questions are more difficult but I would like some of you to look into these questions as well as Prolong and Duralubes additives, abilities, and advantages, if any. I've heard, Prolong has chlorides and they may be harmful, what gives, any tribologists out there. I do wonder if any GM engineer uses 5-30(GM requested oil in new vehicles) (synthetic or not) in his vehicle on long and hard driving. I think at least a 15-40 is wiser.
    If your owners manual calls for 5W30 using 15W40
    will void the warranty if it is determined that
    you are using it. First of all 15 weight at engine start-up will not flow fast enough. From what I have read the 40 weight can 'tear' at high RPM thus not properly doing its job. (I imagine this in my mind as it being too thick and thus peels off like Elmers glue drying on your skin.)
    This summer has been exceptionally hot where I live so I am running 10W30 but come the fall I
    will be back to 5W30.
    There is a retired GM engineer who visits this site every now and then but I think he will agree
    with what I have posted here. Coming from the "Old days" of V-8's it's difficult to think that
    a 30 weight oil is better than something that is
    heavier. But I guess the tolerances are much tighter these days than in my old V-8 400 that
    got 15 miles per gallon going down hill in neutral with a tail-wind.
    I'm told light weight oils just don't lubricate at high rpm and very hot tempertures. I know what the warranty says(perhaps to get the mileage up) and it used to say oil changes every 12k miles too. I think I was really thinking about the middle grade Mobil l the 3rd 20-50 grade may be better for the exceptionally hot weather you refer to. I really would like info comparing all the synthetics. No magazine is willing. Advertisers would not like there products tested. Lets face it the Mags are written for them anyway not the consumer. Have you ever read a bad reveiw of any car or product. I would like to see tests done in an all being equal scientific analysis of the synethetics vs regulars with and without additives.
    I've always been a 'change-it' every 3 months regardless of mileage person. Perhaps the greatest advantage of doing that is that you don't have to be concerned with using the very best oil the industry has to offer and you don't have to worry that your filter is not the highest quality around.
    I see that you live in New York State. We've been hot here in the northeast but still moderate compared to some parts of the country.
    I understand the heavier oil might sound better in that it is thicker but mechanics claim the first seconds are the most important during startup(you can read it 100 times in this discussion group). These same mechanics claim that too thick of an oil film will tear against moving parts as discussed above. These claims also are supported
    by companies like Castrol/Pennzoil-Quaker State...etc. I think I believe them moreso than
    if it was Ford/GM/Chrysler making those statements. So since there is no perfect world, I suggest using what the manufacturer recommends and changing it often.
    3 months unless you go near 3000 miles before that.
    Your owners manual probably has a chart that looks
    something like this:
    Outside temperature range expected:
    0 degrees F 100 degrees F
    <---------------------------| 5W30
    |-----------------------> 10W30
    Well, here in PA we seldom go above 100 degrees
    although we were pretty close to it this year.
    For the last 10 years I have been running 10W30
    in the summer and 5W30 the rest of the year.
    No leaks no oil consumption on an 89 Ford.
    But the 3 month schedule since I do it myself
    is probably the reason I have no leaks or oil consumption.
    The discussion over dyno-juice over the syn. oil will be debated forever. I don't want to touch that subject.
    Unless you have a VERY specialized condition climate-wise, you should always use the rating listed by the manufacturer. The 5W30 is a multiviscosity oil, which means it flows as "5" (i.e. lightweight) when cold and "30" (somewhat heavier) when hot.
    If you live where temps can go below 0 often, use 0W30 (Mobil 1 makes this, and synthetic oil DOES have a lot of benefit in such extreme conditions).
    As far as the syn vs dino oil, I've said my piece: synthetic oil's benefits won't be obvious unless you keep the car past 100,000 miles.
    I think Consumer Reports tested taxicabs with synthetic and dino oil and found after 60,000 miles, no difference. However, I don't think taxicabs (which are almost always idling) are a fair comparison to most drivers. It is an interesting comparison though.
  • mwiklemwikle Member Posts: 62
    I just made an effort to read all the posts in this thread! Wow what a bunch of good, and sometimes slightly mis-aligned (but undoubtedly believed & well-intentioned) information.
    Anyway, I am going to attempt to offer a new view and answer any burning questions you may have on lubrication from time to time. So consider this post a solicitation for your queries.
    Well, who the heck is mwikle, and why should I believe him...I'm going to stick my "neck" out a bit to the group and let you know that I am a Chemical Engineer, and an S.T.L.E. (Society of Tribologists and Lubrication Engineers) Certified Lubrication Specialist (CLS). I Supervise End-Customer & Distributor Training for a major oil company. I have been involved in lubricant & fuel additive manufacture and sales for over 10 years. Our team members develop advanced lubrication formulations in-house, & license virtually all next-generation base-oil manufacturing technology (i.e. Group II stocks).
    My opinions are my own, not my employer's, period. This work is on my time, not theirs. My opinions are *completely biased*, but I believe my biases are based on good science, and sound engineering judgement...you be the judge.
    I get kinda teed-off reading some logic & misinformation in the automotive aftermarket, people want their cars to "do better" so badly that,frankly, a lot of useless crap is sold to unsuspecting consumers...I hope help some of you make better judgements about your cars. The FTC cannot catch all of the "small fish", and it is surprisingly easy to get into the automotive chemicals business.
    Now onto Lubes 101 topic number 1. Let's have some fun...
    The single most important characteristic of lubricating oil is viscosity. Bluemist #348 is correct, always follow OEM recommendations on vis, even with synthetics, unless your operating conditions (or engine age) are such that they were probably not fully considered in the OEM spec.
    Only the folks that designed the clearances in an engine, and tested it, can truly say the best vis for a given setup. Anything else is secondguessing without know all of the pieces, it may not hurt to vary vis from OEM rec (probably won't in fact) but, what is the upside for this varying from OEM spec on vis?...not much...perhaps a bit better mileage if you go lower vis/but you risk a too thin of an oil layer under some conditions in the bearings, & some lower vis oils may be more volitle and lead to earlier catalyst poisioning too...on the upside of vis, yeah you might get a thicker film that can handle more "stress", but once moving parts have an oil film between them, more oil film does *not* = less wear. A thicker oil from more vis will handle more loading before film separating the metals breaks down---but clearances may not accomodate adequate flow of heavier oils at startup or even running -- possibly accelerating wear. Gas milage also suffers with heavier oils. The OEM considers these facts in picking the oil.
    #552
    If it is a choice between having an oil cooler or not, I would get one installed. Mine has an oil cooler installed in front of the radiator.
    please continue
  • anne4anne4 Member Posts: 35
    Yeah, Mwikle, please DO continue. Stick your neck out a bit further and venture your opinion on synthetic vs. dino oil. C'mon: it's only an electronic forum. If you get flamed (not by me...I won't flame you), remember the old "sticks and stones may break my bones, but flames will never hurt me." And if you know of some research studies on synthetic vs. dino that haven't already been referenced in this topic, all the better.
  • edwardh1edwardh1 Member Posts: 88
    mwickle and of course we need your opinion on Wal mart generic versus name bend oils, and your opinion on the Consumer reports taxi study (no, they don't idle all the time, least not in NYC and they do shut down at nite) recommendation to change every 7500 miles (which is counter to Jiffy Lube et al who say 3000 but have no proof except that it works) - so does changing at 1000 miles.
    Kinda figured the petro versus syn thing would be a burning issue...someone sent me an email with a similar question too.
    I think for *many*, probably most, drivers, following reasonable maintenance practices, using a "good" petro-based motor oil, syn-based motor oil is really not beneficial in a *quantifiable* way. If it was *quantifiable* the OEMs would spec it --- the car business is very competitive for one of them not to do so.
    Syn base oil itself (not the addpack) provides three (3) properties of interest here: MUCH better flow at low temperatures (lower pour point), better resistance to oxidation (high temperatures), and less volatility (the new ILSAC GF2 spec is very concerned about this due to possibility of catalysts being poisioned by oil --- OEMs must give a long emission warranty & do not want premature catalyst failures)
    There are *no* problems or downsides (other than cost, of course) with modern syn formulations by major manufacturers: syns used to have seal swell issues (i.e. caused leaks), and can be bit tricky to formulate as solubilities are different than petro oils. All this stuff has been solved. Some syns use a really good addpack, that may provide other benefits and "safety margin".
    If I had any turbo or high performance (hot) engine, I'd use syn or possibly a group 2 conventional oil (another topic). Some OEMs will call for syn for these reasons.
    If I lived in a really cold climate, I'd give strong consideration to syn (near or below ~0F). Syn can improve oilflow at startup, helping reduce the potential for wear. This can lead to longer life. We sell a lot of syn in AK, for example...Jets use syn, in part, because it's damn cold at 40,000 ft.
    Finally, as long as the oil met the SAE or ILSAC spec, I'm not too concerned about the catalyst poison thing.
    With syn, I think most vehicle owners really want their cars to last longer &/or get better milage/performance.
    Syn cannot directly help durablity in operation because once any (syn or regular) oil film is established virtually no wear happens (that's why highway only engines, and stationary engines last so long).
    Startup wear is mitigated by getting oil in the lubricated surfaces quickly, to do this at a given temp/vis syn is probably not materially faster getting to the lubricated surface a than conventional oil(think about it: why should syn flow any faster at the *same* "thickness" as a comparable conventional oil).
    At very low temps, syn is far better. Period.
    Again, I would be very suspicious of claims of longer life (because there is no lubrication mechanism improved by syn itself), or better mileage by syn (other than the better milage obtained from using a lower vis of any oil). I *personally* think some small suppliers flat out tell a "Clinton" on this type of claim.
    One CAN design a addpack to improve the chances of a long engine life by doing a good job of suspending combustion particles, controlling oil oxidation, having good EP additives that minimize wear when there is no oil film, controlling sludge formation, etc...My point here is that such characteristics are not a property of the syn, but the addpack.
    Sounds good to me. From a bigger view, whats missing is long range testing by an independant agency (not the manufacturer) on any of these issues - generic vs name brand, syn vs regular, and change at 3k vs 5k vs 7.5k. Only long range test I have ever read is the Consumer Reports one. Barring a test all we have is opinions, some informed, some just opinions.
    #345
    Why would anyone conduct an independent test to potentially sell 2-4x LESS product? (which is what potentially you can go more, between oil changes with synthetic)
    Also, the synthetic and conventional oils conform to the same standards (check the standards on the labels of the oil you buy)
    you are right, no one selling oil would do that, that why it would need to be someone independant - consumer reports, SAE, ASME, etc.
    Someone independant, not trying to sell you something.
    #356
    Given the posts in this topic, it is almost genius to place the price of synthetic oil 2-3 x the price of conventional oil.
    Yeah, I'd like to see more rigorus testing too, but motives and economics are not there. Looking a Syntec brochure, for example(their brochure was hand at the Honda parts store), it contains pretty good info and some test related claims---but is clearly not the "whole" story *relative to other oil choices*, of course. Nothing in it strikes me as unique or better than comparable oils, other than the marketing angles. BTW, I suspect Syntec is darn fine oil (I may buy some for my car), just not certain it any "darn finer" than say Mobil1 or any less promoted major synthetic (their brochure was hand at the Honda parts store). We spent something like $250K+! on 4 or 5 engine tests to "prove" advertisable performance attributes for a non-PCMO (Pass Car Motor Oil) product.
    Engine test (& other tests) costs & complexity are one reason I am always *very* suspicious of the smaller PCMO brands.
    If I wanted to make a motor oil, and was willing to "stretch" the truth &/or skimp on trying to do qood Formualtion QC & Development a bit by not fully qualifying the oil in tests, one can buy a decent "off-the-shelf" PCMO addpack from folks like Lubrizol/Paramins/Oronite and just "stir it in" to a given base oil based on simple vis tests and addpack mfr's advice. It will probably be "good enough" in many (if not most)cases.
    The big guys can do this too I suppose, but they have a lot more to loose & are watched more closely. People do publish misinformation if not "Clintons" in the automotive aftermarket. Look at past FTC actions. Buyer beware.
    #358
    Yes, the standards are the real catch 22. As said in other posts, conv and syn meet the same standards. While syn oils are better for 6 reasons, there are no magic bullets. (Not to mention the price premium.)
    It is almost a no brainer to say; buy the major syn based on price; just as conv oil.
    I,m still interested in the best base stock syn question both Redline and NEO claim theirs is best and of coures so does Royal Purple. If you go to their Web sites perhaps you can decifer this for me.
  • hohohoho Member Posts: 64
    Hi to all of you!!
    I have read and re-read most of these posts and I gotta tell ya... WOW!
    Let me see if I can sum up what you all basically say and if I am wrong please advise,
    Synthetic oil is the best for your engine...
    Conventional oil is the best for your engine...
    Changing your oil and filter often is best for your engine...
    Stay away from a cheap grade of oil...
    Stay away form a cheap oil filter...
    Don&#146;t mix and match oils and / or viscosity, it is not worth the time or the hassle. Not to mention the unseen repair costs that you may have later...
    Read your owners manual often...
    Make your choice of oils based on your driving habits / styles and topographical areas...
    Understandably we (normal consumer types) do not have access to design features of an engine or it's ability to withhold oil pressure forces at any speed or service. What is missing is the sealing design coverage of certain sealing mediums such as gaskets or cup seals or even orings. Nor does the normal public consumer know the difference between Buna-N, (or any type of seal for that matter) Neoprene or specialty seal. Knowing that how can we make (and thinking deeper, do we really want to find out? Job and economy based questions might arise. Besides we pay enough on welfare and other services. Grain and staple foods are the back bone of our diets! Hence, vehicles are the backbones of our life as well. Take away the auto part industry and where will the economy go? ) choices on the vehicles we buy.
    To leave you wondering let me say....
    If it works for you do it!!!
    Just let me read something that will help us all.
    Signed, no one in particular.
