Visitor Agreement.
Having "The Guy" diagnose is correct because that requires equipment the typical homeowner doesn't have, along with clear understanding of the electrical diagrams and knowing which connection on the circuits to use to turn on just certain electrical parts, in my case he turned on the compressor by itself to check the amperes over a few minutes and then he checked the blower fan on the condenser unit outside. The compressor tripped the solenoid off inside the unit but did not trip the circuit breaker in the house. He also was able to check the new compressor for integrity by checking each of the windings in the motor and they each drew the same amperage indicating they were all good.
I was happy as kid learning they had a snow day off from school when that phone call came.
I told my son about his gas heat in their home they just bought, that he should have a heat pump/gas combination put in if they every have to replace theirs, which the inspector said was almost new and efficient at gas heat.
The ability in being able to use electric coils or heat pump as backup heat if something goes wrong with the gas supply or your gas furnace is a big advantage I would have paid for were gas available on our road which was built in the 70s during a gas connection moratorium.
I hope Junior listens if they need to replace his gas furnace or the AC portion. With electricity in our area at 4 cents/kwh to 4.3, unless the greenies get their way with forcing everyone to pay more for their solar cell farms and windmills, the use of the electricity to heat via heat pumps and the Carnot Cycle or direct resistance heat is pretty good. We also have 2 nuclear plants that don't add carbon in Ohio, whatever that means, so we don't need the high cost subsidized farms.
If I’m putting my money into backup sources, it would be a generator, hooked up to my natural gas for fuel. (But, I’m not)
backwards.
But price of gas has dropped with our energy independence in the past several years. If it goes back up...
Our electricity here in W Ohio is great because DPL uses gas-fired generators that come online as needed. Cheap gas--cheap electricity.
I also have told Junior I'd install a whole house generator as soon as they're comfortable with it financially. I also said he needs a power backup unit for their computers and cable box setup.
How much does a whole house system cost that runs a gas-fired heat system and other things for a 2600 sq ft home? @driver100?
Since September the power has been out 4 times, 3 for one hour, and last week it was off for 3 hours. That is a long time to be in the dark, with no cooking and no entertainment. Our house is 2200 sq ft but The Guy said a 17000 sq ft unit was sufficient since there is only two of us. Total cost was about $12000, could be more or less depending on how it has to be hooked up.
I think it is more competitive in the U.S. so there are more bargains. You do need Guys who know what they are doing, it can make a big difference. Even the inspections are faster if the inspectors know the company installing has a good track record. And a knowledgeable guy can advise you on short cuts or by telling you a smaller unit will suffice.
I am glad we got it now. If it was extremely cold, and power was out for a day or more.....it would be pretty hard on us. I wouldn't make it a priority item, but, if it is affordable and you have the extra dollars it is definitely a nice thing to have.
“The SRT cars, including the brake pads, tires, suspension and cooling systems, are track-ready from the factory. We verify that every SRT model can handle 20-minute track sessions in 100-degree ambient temps with a pro driver. That means the brakes won’t go away, the driveline won’t overheat, the ESC system won’t have problems, etc. We also run 24 hours of track durability at Nelson Ledges with the car absolutely stock. We test for brake fade at Gingerman, where some of our high-profile and more expensive competitors lose brakes in just three laps”
I still don't prefer something as big as a Challenger, but I'm a little bit tempted since real enthusiasts are at the helm.
I have - me no likey.
I saw a 4 series in person. Wow and not a good wow
I'd always assumed if my car was still and I pushed the brake pedal, the lights are on.
Has anyone else checked their brake lights before the car was turned ON? My Malibu has brake lights without the key.
Add to that Rhodium and Paladium and you can get rich quickly with spot prices humongous.
That's also the car that will blindly merge into you, stop for a green light, be going 10 under in the left lane, etc.
Now it's the opposite, with the A4 having an annoying like 15 minute time limit on keeping the radio on without ignition (Drive-In movie for the little one; allows cars to park every other space for social distancing). So every 15 minutes if you forgot to touch and adjust the volume the sound would go out.
btw...in case you are wondering, yes, I have changed lots of tires on the many hoopties I have owned. But this was the first car I ever had that had a key to get the wheels off....I had no idea where the key was or how to use it, and didn't have time to mess around with it...so I called The Guy.
Way back when, I drained the fintail's battery via the radio. I was a student, only drove the car once or twice a week, on weekends. One weekend day I left the radio on, came back next week, no go.
