I don't find electric mode to be any different than hybrid. I guess maybe it lets you push the pedal a little further before kicking on the ICE, but foot to the floor gives the same result in either mode. The only time I use electric is when it is cold out and I'm waiting in the parking lot for my kid. It lets the stereo and heat work without letting the ICE kick on and idle.
4xe #3 is supposed to arrive this morn.
2500 for sure. And most people at that weight probably go diesel. And get the fancy trans. Maybe a ram Cummings with the Allison. Hopefully don’t need a 3500 dually!
Big trucks are very expensive. Diesels even more. And modern diesels are very maintenance intensive and problematic thanks to the emissions tech.
Maybe a 2500 ram hemi with tow packages is good enough.
Or get a normal car, and an RV.
Here’s a chart. Looks like a hemi with right gears can just handle that. But getting up there. That is a seriously heavy trailer.
https://s3.amazonaws.com/chryslermedia.iconicweb.com/mediasite/specs/2021_RAM_2500_3500_HD_TowingChartevlal4hu4iu465hrhh9udegr4.pdf
My cousin has a very large fifth wheel and his 2500 with the gas engine (while in spec to pull it), wasn’t all that great and a total pig. He upgraded to a 2500 Diesel and he said the difference was night and day. Naturally six months after he got the truck he parked the trailer for good at a campground
$50-$60 a year? Hell, that amount monthly wouldn’t stop some people from driving what they really wanted. There might even be a few in here in that category.
Definitely worth it!
But it ain’t black.
Maybe tjc78's cousin is willing to sell his truck.
So you’re not only taking in a renter but a big rig and trailer. How big is your driveway.
The bigger gas engines indicate 18k capacity. Should be enough. I might see if I can talk her into a reasonable SUV and separate driveable RV.
What’s her lifestyle with it? Does she drive it to a seasonal campground and leave it for 6-8 months or travel around a lot.
She doesn’t even own one yet.
But ya gotta give credit to someone who doesn’t make the mistake of buying something and then realizing they need more towing capacity.
If she buys it right away, she'll just need a place to park it. No temporary housing required.
Yes that’s good planning. I guess my reading comprehension is off today… you said future purchase in your first post.
At any rate depending how she plans to use the camper should play into her decision for the truck. If she is going to be moving it around a lot the diesel may be better in the long run
Couple things to note about trailers. They are making them so fast that the quality has been slipping lately based on some videos I’ve been seeing. Also they age very quickly the more you move them around.
Looks very nice!
- Ray
Blue - similar to my BMW!
I budget $450/mo to maintain all five vehicles. So far so good…
Hi, my name is Q …. No! I do not have a problem!
Big ruckus on the Maverick boards. Apparently Ford forgot to send out the scheduling emails that normally go out every Thursday when orders get scheduled for production.
That’s awesome. Same dealer group I got the XC90 from down in MD.
So, at this point, is it only the Sprinter still on order? The fleet otherwise complete pending soon to happen flips?
But driving a HD 2500 truck pulling a huge gooseneck trailer is whole nother animal.
and as others noted, desired use is important.
I seem to have talked her out of the idea. A more normal vehicle now plus driveable RV in the future.
Yes, I have 3 vehicles with temp tags. I did get plates for the wrx but have yet to put them on.
Still awaiting Volvo and Sprinter.
ML63 and one 4xe soon to be sold. Second (well, 3rd) 4xe likely to be sold after sprinter arrival.
My advice, if you plan to tow heavy, go diesel or go home.
Stella this is building a new engine called the Hurricane- it’s a twin turbo I6. Rumor is that it will be installed in the Wrangler. I think I’ll definitely keep looking at reasonably quick RWD coupes- and put off replacing the TJ until I find out if the JL is the recipient of a proper six cylinder.
That paints gotta be cheaper doing it your way.
The 4.0 that was in wranglers for what seemed like an eternity was a straight 6
However, if she also wants it as a daily driver, modern heavy duty pickups can be a real chore, and they are expensive vehicles to wear out commuting. If she were hauling the trailer on a regular basis, then I would recommend diesel. Otherwise, don't do it. The extra complexity of emissions, and the high cost of maintaining that as the miles accumulate, are not worth the gains in economy and torque for towing on a limited basis.
Those were a previous generation which didn't have a couple of turbos hanging off it.
The I6 will make a lot of power, so if anything it would be a limited edition model.
But seriously, the 4.0 was larger displacement so larger pistons and a longer length than a 3 liter straight 6. Turbos are exhaust driven so will be off the side or even underneath the passenger compartment.
Hey now…
And with my next vehicle, would really want a new vehicle and not a CPO unit if possible. Guess I need to make a spread sheet of all vehicles under 176" and see what comes up. Anything bigger just won't fit on my side of the garage. And an FYI, petrol prices have gone under the $4.00 point in the West Palm Beach area and I paid $4.03 yesterday near the house. So prices are starting to come down as predicted a couple weeks ago.
The A7 PHEV does most of the thinking for me, I can't choose levels of regen braking. Three drive modes, electric, hybrid and battery save (I'll guess same as the Jeep esave). I, too, use the nuclear power for local drives, hybrid on the highway. Sometimes I just use the Radio Shack electric kit motor to battery depletion to test electric range. Haven't used the esave yet.
What's a bit cool to me, I've driven ~360 miles since I last filled the gas tank. I've used 1/4 tank of dinos, averaging 88+ mpg. For a car the size of the USS Massachusetts! But, on the negative side, the at speed handling lists towards the USS Massachusetts side. Still, a wonderful high-speed cruise missile.
Base version makes 400 HP.
So I might look into getting a L2 charger installed. I charged up last night. Fired it up this AM with a full 99% 25 mile charge. I ran a bunch of local errands on the battery. I filled up Friday night. Have driven about 70 miles since I filled up. According to the Jeep, 1/2 those miles (most which were today) were run on battery.
