1278627872789279127923158
  • sdasda Member Posts: 7,712
    edited April 2022
    CPAP update ... got a phone call from the device provider.
    Turns out I will be getting a new CPAP machine, whereas before I had an APAP system.
    What's the difference? A is for Automated, meaning it adjusts the flow of air into the mask during the night.
    In other words, I'm being downgraded.
    However, the delivery time for the new system is 6-8 weeks, not 6 months, so I'm OK with that.
    Over $500 to purchase, all in.
    If your doctor believes you to have sleep apnea, I recommend getting a CPAP. It's amazing how much better you'll sleep with use. Yes, it takes some time to adjust to, but after a week or two it was not a big deal.
    I've been using one for 10 or 15 years now, and the few times where I haven't had it were miserable.
    FYI, there are two types of apnea - physical and mental. I, lucky for me, have both.
    I agree 100% with your observations. As much as I hate the mask I won’t sleep without it. I’ve tried once or twice and between my wife elbowing me and telling me to stop snoring or holding my breath and the poor sleep I get without it anyway I’m resigned to its use.
  • kyfdxkyfdx Moderator Posts: 271,091
    I think it looks more like the new Sonata, than the Elantra
    jipster said:
    O.k. Feeling a little better. The HVAC guy came out this morning. Said it would be at least $8,000....KA-CHING! Has to replace the old 10 seer unit with the minimum 14 seer unit. Replace copper lines, interior coils, filter box...as another poster had said. Said something about drywall, which I don't think is correct. Mrs Jip gave me the report. It's a clear shot from basement a/c and furnace to outside. Runs thru a rectangular chute in the ceiling. So not sure why they'd need to do anything with drywall.
    This company installs York and Trane systems. I told the company rep I preferred Trane. He said they had been licensed York installers for decades,, just became Trane installers 3 years ago. But in speaking to Mrs, Jip said York is better because it has a better warranty. So, any opinions on which is better....York or Trane?
    Also, we could move up to a more efficient or 2 stage system, but we'd have to pay for the price difference. They also suggested utraviolet light for cleaning the air? Never heard of that.
    Is it a gas furnace? If so, I'd get them to quote the whole thing. The big advantage we got was variable speed blower on the furnace (even though the A/C unit is single stage). We can't even hear it run, any more.
    The direct vent pipes are bigger than on your old one. That might have something to do with drywall? I know they had to drill a bigger hole through my foundation to accommodate them.
    edited April 2022
    Yes. Gas furnace. Thanks, was thinking it may have something to do with venting pipes as they said would need a new filter box.
    Still waiting for my neighbor to drag his chimney off my a/c unit, and off my property. Hope this isn't the equivalent of a neighbors leaves or branches blowing on your property and you have to clean them up.
    Sounds like some poorly built chimney's to me.
    I would go with Trane or American Standard, which is essentially a Trane, made by the same company. According to CR York does not have a good repair record after it ages. We have an American Standard Silver Series SEER 16 with the variable speed gas heat and have been very happy with it.
    edited April 2022
    One interior wall was rotted, but it was held on with about 10 nails, not screws. May not have blown down if it was screwed in.
    My chimney is sideways to that west wind that hit. Otherwise it may have gone too.
  • tjc78tjc78 Member Posts: 17,383
    I guess I have an APAP then. It starts off slow and then ramps up through the night.
  • driver100driver100 Member Posts: 32,677
    carnaught said:
    Elantra’s rear…more chisled.
    They really overdid it on that angular effect.
    All of the ones mentioned resemble the new Genesis G90 to some degree
    They are running out of new designs.
  • stickguystickguy Member Posts: 54,128
    I just started CPAP therapy. I have to say…. While it’s working I absolutely despise the mask. I’m truly thinking surgery is the answer. I’m sure losing weight wouldn’t hurt either.
    I know that I could never, ever sleep with one of those things on. I can't even stand to have my fitbit on.
    what about that gizmo they keep advertising on TV? The implant with the clicker to turn in on and off? I forget the name of it but I like the ads!
    Still sounds like negligence to me, but if it is considered an Act of God and won’t affect your rates I guess it doesn’t make any difference. But I don’t trust insurance companies.
    In my experience, the quality of the installer and the after-sale service they provide outweighs the reputation of the brand of the HVAC.
    UV light purifier? I wouldn't; you'll still need a filter.
    Insurance should pay for clean up.
    jipster said:
    @oldfarmer50 said:
    I still don’t see why it’s not the neighbor’s responsibility to pay for it. If my car rolls out into the street and hits a parked car it would certainly be my fault. Why does someone’s chimney get a pass? If the chimney fell inward and damaged the guy’s house his insurance would cover the additional damage, why not your property?
    Can’t you at least get your deductible reimbursed?
    I asked my agent that question. She said the wind caused the chimney to fall. The wind caused the property damage, not the chimney. I can see both sides though.
    Our house was built in 1974 and last year the chimney needed some extensive tuckpointing. If you don't take care of problems like that the chimney can crack and fall.
    When I had my gas furnace put in in ‘06 I got it in my head that I wanted it to have an electronic air cleaner (not UV, but the electrostatic kind with plates), so I had them add that. I came to hate it because it was constantly popping and you could hear that in certain parts of the house. Plus you had to clean the thing every year anyway which was a pain. A couple of years ago I noticed I wasn’t hearing the popping any longer, investigated, and discovered it had crapped out. Rather than getting it fixed (if it even could) I just bought a couple of filters that are the same size as the plate units and those seem to work well.
    I now find myself wondering how much life the furnace has left in it. It’s a Tempstar high efficiency one and I have never had a problem with it but it being in its 16th year I am wondering.
    Thx. When they get up on the roof I'll have them check the chimney really well.
    Thanks for the comments everyone.
    The furnace can last a really long time. It's usually the central A/C unit that goes first.
    Our A/C made it 18 years. Decided to replace the furnace at the same time.
  • MichaellMichaell Moderator Posts: 267,664
    If you're asleep, how do you know? :smile:
    I looked up the model I'm getting on-line; the information is somewhat vague, but it could be an APAP system. I'm not 100% sure I trust the information the vendor is giving to me.
    Whatever. When it shows up, it's apparently already been pre-programmed for my needs. I just need to plug it in and start using it.
    I sure hope the hoses fit it; I was on an automated refill program and just got the replacement equipment for my old machine a few months ago.
    edited April 2022
    @ab348 said:
    When I had my gas furnace put in in ‘06 I got it in my head that I wanted it to have an electronic air cleaner (not UV, but the electrostatic kind with plates), so I had them add)to clean the thing every year anyway which was a pain. A couple of years ago I noticed I wasn’t hearing the popping any longer, investigated, and discovered it had ]pp out. Rather than getting it fixed (if it even could) I just bought a
    My Goodman system was 22 years old and counting till a chimney fell on it. 😞
  • oldfarmer50oldfarmer50 Member Posts: 24,544
    I still can’t see it. If the wind blew down the neighbor’s whole house and it fell on your house and knocked it down too, would the neighbor’s insurance pay for his house but not yours? And if you had no insurance would you just get to sleep in the rubble?
    I’m sure there’s a legal justification that I’m not seeing but it just seems unfair.
    Sign of the times, earlier today after returning the CR-V to mom I turned onto the street that leads to our neighborhood. Lined up to turn onto the street that I had turned from were 15 various SUVs, black, silver, white. Not a sedan in sight, other than the one I was driving. Continuing down the street oncoming another 3 SUVs, then 2 pick up trucks and finally a Corolla!
    The way most people avoid color on their cars is quite puzzling. I was thinking that the new iPhones that come in red and green seem quite popular, so maybe that would lead to a renaissance in car colors, but it hasn't happened yet.
    @oldfarmer50
    Tornado comes through... Will they check to see if the tornado actually hit your house, or if you just got in the way of the neighbor's house blowing by? :D
    I just can't stir up any interest in a CUV/SUV(other than a Wrangler); the really outrageous BMW and Porsches are a lot of fun, but I still prefer a coupe.
    @jipster I think you mentioned an ultra violet light. It is a small light bulb that is supposed to kill bacteria or something. We didn't have any problems with our Florida furnace, but during the annual inspection our excellent service man said the ultra violet light wasn't working....he asked if we wanted to replace it....and he rolled his eyes. I took that to mean don't bother, so I didn't and he seemed to think that was the right decision to make. That was before covid, but I don't think ultra-violet lights kill covid anyway.
    I still don't get the concept....a neighbors chimney falls on your home and his insurance doesn't pay for it. It is an act of God or something? I thought the neighbor bought a policy to protect him from having to pay when something goes wrong....on his property - like for example when a piece of his house falls off and destroys someone else's air conditioner unit.
    edited April 2022
    We watched one "Better Call Saul" on Netflix. The concept seems good but it's not quite good enough to watch more....but I really like his car. He is a very unsuccessful lawyer, and he tries to meet with potential clients by not letting them see his awful office or his car;
    I also like Detective Grace's car in Unbelievable on Netflix:
    @oldfarmer50
    And if your house drops on the wicked witch of the west, are you liable? :#
    I think in some episodes he’s driving a Neon.
    You know that it is the prequel to Breaking Bad, right?
    I’m only going with what they told me! I do know if I wake up in the middle of the night it is pushing more air than when I start to go to sleep.
    I may look into it.
    No, I didn't know that....I thought it was a new series. I only watched one, it was OK but I got the impression I could find something with a little more substance to it.
    I haven’t watched it yet, but Saul was Walt’s lawyer in BB. The Better Call Saul series is all about who Saul was before getting involved with Walt.
    I really want to watch the series, but the wife hated BB (didn’t finish it) so no way she will watch it with me
    I felt the same way about BB. Tried to watch it but the people were so vile it turned me off, so I turned it off. So this spin-off series has zero appeal for me.
    It has a very strong cult-like following though.
    edited April 2022
    It’s one of the polarizing series. Starts off a little slow and then builds and builds through the seasons. The use of symbols and colors throughout the series is unmatched and the acting was spot on
    IMO the second best series of all time only beaten by the Sopranos.
    edited April 2022
    Oh, puh-leaze. I haven’t seen it, but there ain’t no way in heck it beats Sesame Street in that category
    I actually can’t tell if you are joking or not.
    Symbols and colors … sesame street … get it? Lol
    edited April 2022
    Ha ha I got ya Q. Little slow this morning
    Sesame Street would also win for the best use of puppets category too :p
    edited April 2022
    @oldfarmer50
    Depends on the weather and also where the wicked witch of the west is standing when the afore mentioned house crashes down on her. Also depends if the house was in poor condition and the witch sent a certified letter to the homeowner prior to the incident…
    edited April 2022
    carnaught said:
    I happened to see a commercial yesterday for Inspire, a device like a pacemaker they implant to replace the mask? Anyone ever heard of that? Bueller?
    If I had sleep apnea I would talk to an ENT for a consult about it. I have heard of good results from it.
    The Inspire is an interesting device. You turn it on and it provides an electrical stimulation to your tongue which causes your tongue to move forward (anteriorly) to open up your airway. The device is $30,000 IIRC.
    You have to have a “drug induced sleep endoscopy “ to see if you are a candidate for it. You get a protofol infusion until you start to snore and the ENT looks through your nose with an endoscope to evaluate your airway. (Not that I’ve done one recently…)
    There are also more simple devices that are mouthpieces that have adjustable bands that move your jaw and tongue forward that also open your airway (Panthera). Those are about $1200 (they also include a sleep study) but I do not think it is covered by insurance.
    Some devices work better for some while other devices work better for others so YMMV.
    Looks like Zorro was there.
    Acts of God can affect your rates. Using the actual payouts they will use a more complex math formula to come up with a modifier to adjust your rates by experience. If you don't have very many claims or it's been a while since you made a claim it usually won't affect your rates by much, if any. But if it commonly happens then guess what?
    It's not the fact that the neighbors chimney falls but what was the cause of the fall. If due to poor upkeep by the owner then the owner would be liable because it was his/hers actions (or lack thereof) that caused the damage. If it was a storm that blew off a perfectly good chimney then the owner was not responsible because they had no control of it.
    Ultra violet light could kill most things except some bugs (it's the same light that causes sunburns). However the intensity of the light and duration of the exposure are the major factors. A single UV light in a duct isn't going to expose anything in the passing air long enough to do anything.
