1303130323034303630373158
  • snakeweaselsnakeweasel Member Posts: 19,622
    In Lake Geneva, WI now and saw this:
    Need help from a DIYer:
    The front door is a solid steel door. A few winters ago the door stuck along the bottom, only when it was cold out.
    A friend suggested tightening the 3 screws that hold the door in place.....that go into the frame.
    That worked for a while, and last winter it got stuck again....time to fix it before the winter.
    One guy suggested using a washer on top of the hinge I think, that would raise the door...not sure if that is going to work.
    I read online to buy screws that are 3 inches long, and use those.
    Another online suggestion was to buy slightly thicker screws....not sure about that.
    Some say to tighten the plate at the bottom...but I don't think it is that because it did get better for a while when the screws were tightened. That might mean it sags in the cold weather...hmmmmm.
    All suggestions are appreciated.
    Well, its got the nice big windows that I like, and fairly flat sides in some places. It looks like it was a Bell Telephone car judging by the paint job.
    Obviously an old Citroen
    ....and the owners are probably Episcopalians judging by the sign behind the car.
  • jmonroe1jmonroe1 Member Posts: 9,667
    I’m pretty sure we talked about this once before.
    First off you have to make sure the door frame is square and plumb in the opening. If it isn’t use 3 inch long number 12 flat head wood screws to hold it properly in place. Be sure the screws are below the surface of the jam so they can be filled with wood filler and sanded flush so the screws can’t be seen when you’re done. Yes, the frame will require painting if you had to use screws in the side jams.
    If the frame is already in place properly use longer screws in all of the hinge holes. You can’t use a larger diameter wood screw because the flat head won’t sit flush in the hinge counter sunk bore. If the screws don’t sit flush in the the two hinge surfaces (on the door and the jam) they won’t let the door close properly. I’d take one of the existing screws to the hardware store so you can get the right size flat head screw that is 3 inches long. When you install the longer screws if you don’t feel the longer screws holding well in the jam, use slivers of wood to to fill the holes. Some folks use toothpicks but I like something more substantial.
    Of course this fix is only good if the door is not being held properly and sags after some use. This fix will not correct a sill plate that heaves in cold weather which makes the door stick at the bottom.
    FWIW, a door doesn’t sag in cold weather any more than it does in warmer weather. Therefore, make sure the door isn’t sticking at the bottom.
    I hope this helped.
  • ab348ab348 Member Posts: 20,598
    As much as it pains me to say it, JM is correct. :D
    I had a similar issue with the entry door to my garage which would scrape the floor when swung open. New longer screws tightly installed on the upper hinge cured it instantly.
    I hope this helped.
    It sure does help....and it was explained very professionally so that even I can understand it and probably be able to do it myself. Thanx.....much appreciated.
  • oldfarmer50oldfarmer50 Member Posts: 24,521
    I had a similar problem on a door out of my basement. It was my own fault for using expanding foam around the jam to insulate. This caused the frame to bow and the door to rub.
    Since the frame was mounted into concrete block I had to install lag screws. When I tightened them it corrected the bow so I’m confident that the screw advice given here will help.
    Yeh, I am going to give it a try, and if it doesn't work I'll expect a full refund. :#
    @Mrjmonroe1
    I have a question. The door frame is just over 2 inches wide, with a window on each side beyond that.
    I guess I should get 2 inch screws...what do you think?
    @Mrjmonroe1
    You didn’t say you had side lights. Therefore, you can’t use screws that will hit the glass. Take accurate measurements to be sure you don’t do that.
    FWIW, you addressed me correctly when you called me @Mrjmonroe.
    @Mrjmonroe1
    Great.......excellent information.
    I am always respectful of older wise guys.
    I don’t know if I’m wise because I’m old or old because I’m wise. In any case, like I’ve said before, “if I knew I was going to live this long I would have taken better care of myself.
    @driver100 said:
    @Mrjmonroe1
    Could always use 3 inch screws but angle them so one is in front of the glass and the other is behind the glass😂
  • laurasdadalaurasdada Member Posts: 5,282
    It is national cheese pizza day. I shall be celebrating.
    It's also National be late for something day. So I'll be joining you in a few days to celebrate cheese pizza day.
  • qbrozenqbrozen Member Posts: 33,805
    just cheese? Is there a separate day for every topping and combination of toppings?
  • stickguystickguy Member Posts: 54,068
    Probably.
    wake me for pepperoni + jalapenos day
    Sausage for me.
    If you look up genius in the dictionary, here you go.
    Sausage for me.
    Somehow, I knew that :p
    Just joking....too good to resist.
    I put the 2 inch screws into the top hinge, it might have made a slight difference but the door is still drooping on the other side.
    I am thinking two possibilities......a lower door sill at the bottom.....I believe it is plastic so can't be planed or shaved down.
    Why not put a pad behind the lower hinge so that it sticks out more, countering the top hinge which is probably the problem?
    I only put the two inch screws in the top hinge because the others were tight and secure.
  • tjc78tjc78 Member Posts: 17,357
    Ok who is with me …. There too many National day of XXX at this point!!
    @driver100
    That was low hanging fruit …..
  • ventureventure Member Posts: 3,188
    edited September 2023
    Sausage for me.
    Didn't you just have that door replaced a few years ago?
    Any possibility the sill is adjustable? Some are.
    venture said:
    Sausage for me.
    The first time MrJMonroe said to tighten the screws that were already in the door....and that worked for one whole winter.
    By the next winter the door began to sag again, and it gets caught on the sill.
    I think removing the sill...it seems to be made out of hard plastic, and getting a thinner one might work.
    But I can see that the door is sagging, there is a larger gap at the top on the none hinged side.
    Always better to treat the disease, and not just address the symptom.
    I’ve seen that in various car crash videos but the shocker was the GMA reporter actually having to explain what lug nuts were for.
  • explorerx4explorerx4 Member Posts: 21,030
    @driver100,
    There are screws on the door side of the hinges. Make sure those are tight, too.
    No comments that the Kia Soul would have been fine if they weren't speeding? That seems to be the "GO TO" for every "speed kills" person out there.
    venture said:
    Sausage for me.
    They sell shims that go under the plate. They are available in 3 screw for interior doors and 4 screw models for exterior doors. The shims have slots where the screws are so they can be slid under the hinge with the door and the screws in place but loosened.
    IIRC there are various thicknesses. There may be tapered shims so that the thin part can be used and the rest cut off or the thicker, whole shim can be used. IIRC takes some studying.
    I had steel insulated patio french doors that gave some trouble at the hinge mount on the one door that was moveable.
    https://ezshim.com/products/hinge-shims/
    venture said:
    Sausage for me.
    Try this; grab the door on the edge where the handle is (don’t grab the handle because you could break it) and try to move the door up and down. If you have any movement, something is loose. It almost has to be one or more hinges unless the door is coming apart but that is highly unlikely. Make sure ALL of the hinge screws are tight. Both on the jam and the door.
    If everything is OK and you can’t tighten down the sill plate, remove the rubber strip from the sill plate and get a thinner one if you can.
    @driver100,
    I noticed those but forgot to see how tight they are........thanks, I'll check those tomorrow.
    @driver100,
    I've worked as a framer and volunteered on a dozen or so rehab's, so I have some tricks up my sleeves. :)
    Just renewed my SIRIUS/XM Subscription for another year. When I called, I wanted to be connected to the cancellation department. Told them I wanted to cancel because I couldn’t afford going rates. So they renewed for $60.00 plus taxes and fees, which is what I paid last year.
    It’s a full service package including internet access.
    @abacomike
    Thanks for reporting that. That was the rate at which I would have renewed and likely kept one car on after renewing if I decided to cancel--one on, one off. Instead I cancelled both cars.
    But they don't seem to want to renew for me. And now that I've used CDs, FM, and USB sticks for music,
    I don't really miss them. I did listen to CNBC's market reports despite my boycott of the channels of that type, but I can get that on WLW at times or use my phone to download the page while driving, illegal now in Ohio, The Heart of It All is our slogan.
    Apprently SiriusXM has given up on calling and emailing. Or my email client has gotten smarter about dumping their emails in trash bypassing the spam folder. LOL
    Joys of the salt belt. Walking today past a construction site went by 2 workers talking. They were next to one guys big HD GMC pickup. Shiny black, looked brand new. Definitely the current style I think.
    Snippet I heard was, “ I can’t believe it’s rusty already”
    South main auto on YouTube just had a video on a 2019 GMC in for a bad sensor or switch. But when he had it on the left, he showed how crusty that already was at 3-4 years old.
    I might need to get a winter beater like farmer, and keep the good cars inside unless the roads are bone dry!
    Actually should go with a sporty car to never see bad weather, and lease a truck of some sort to not care about.
    I've seen a couple of license plates that were interesting in our CFA visits.
    Today was "ROCKY TV" on Toyota Supra gr.
    Couple days ago was "XLR ATNG" on a Cadillac XLR.
    I wondered if that was to be Accelerating or Exhilerating they were
    trying to sound out with the letters. It was driven by a lady about 30 IMHO.
  • sdasda Member Posts: 7,708
    Anyone hear from @henryn recently? Did he divorce us?
    I probably told this story before but …
    Back in the days of my old employer we needed a vehicle for the execs and whoever else to use for trips, etc.
    The Denali we had was aging and they wanted something similar. My boss at the time had a brother in law who ran a Chevy dealer up by you and OF. He sold us an off lease Tahoe LTZ. Looked brand new until I looked underneath. Wow, was it rusty. It had nothing but problems with the air suspension (all corroded connections and wiring), exhaust, power running boards were shot among other things.
    It only had 25K miles on it. I suspect it was a soccer mom vehicle and must have constantly been in the salt doing short trips and never cleaned.
    Check out SMA’s video on underbody rust proofing with Fluid Film. I could never afford that on my hoopties but it should be no problem for a well off guy like you.
    I just had the ATS in yesterday for its annual rustproofing respray and inspection, all good was the report. $40 in worthless Canadian dollars is money well spent.
    There is a guy who does some outside maintenance for me and my neighbor who has a spotless 2012 (I think) Silverado LTZ pickup that looks brand new. He told me it needed frame repair because (IIRC) some crossmembers had rusted away, apparently a known problem. I was shocked.
    I asked about @henryn a few months ago but no one said anything. He stepped away a few years ago then returned. I hope it’s nothing more than that now.
    I got an email about a guy who buys a $100000+ EV Jaguar F-Pace as his final retirement car. He talks about how it doesn't go close to the mileage promised, and all of his problems trying to find a fast charger. His trip turns into a nightmare as he runs out of juice on a highway, and has to wait for hours for help to come.
    The final summary is this;
    BUT HERE IS THE BIGGEST NEGATIVE TAKE AWAY:
    Let's say you get to drive in OPTIMUM conditions all the way to Florida, for instance, and you are lucky to achieve 90% of the range estimates. That is 213 mi between stops. And, let's say you are fortunate enough to find high-powered charging stations, without going too far off the beaten path (Assume 12 to 19 mi) to be acceptable). And let's assume the charging cables fit your vehicle, the payment screens work, and they are not already in use.
    BE PREPARED TO SIT FOR ONE AND A HALF HOURS FOR A 90% CHARGE!
    Again, using actual mileage data from Owen Sound, ON to Englewood, Florida as an example, a distance of 1440 miles, at an average speed of 56 mi per hour, and a 90% range of 213 mi, would require A MINIMUM OF SEVEN ONE- AND ONE-HALF HOUR CHARGING STOPS! This would add an additional eleven-and one-half hours of travel time. A total of thirty-seven- and one-half hours travel time, compared to twenty-six hours in a gasoline automobile. An extra hotel night, meals, etc...
    His figures seem accurate. I agree with him that if you use the car around town for shopping trips etc., no problem, but going on a long trip could be a nightmare. I also read that only 1/3rd of hotels have proper chargers.
    You can’t believe everything you read. It sounds like you’re not going to get an EV until I get one and give you a thumbs up. So far I’m miles away from the fence let alone being on it. You’re probably safe for about 10 years minimum.
  • MichaellMichaell Moderator Posts: 267,420
    And when your gas powered Jaguar SUV breaks down in Macon, GA, the closest dealer is in Atlanta, which is 85 miles away. In the wrong direction, if you're driving south.
    You don't have to keep sharing antedoctal evidence why you won't ever buy an electric vehicle.
    Lots of people have taken their EV's on cross-country road trips, with no problems finding chargers. I suggest you watch some YouTube videos by "EV Motoring" - he's taken his VW ID.4 and Polestar 2 on some epic road trips, and shows the data regarding charging.
    It's also good to know that for most EV purchases, you'll get some sort of free charging for a period of time, so your fuel costs would be next to $0.
    In addition, many of the newer EV's can charge from 20% to 80% in as little as 20-30 minutes. The Jaguar EV is older technology, so it stands to reason it will take longer to charge.
    It is a technology that is in its infancy. It will continue to get better with new advances. Perhaps solid state batteries will be the ticket.
  • kyfdxkyfdx Moderator Posts: 270,805
    Or, just maybe... a whole lot of people won't take their EV to Florida? :o
