Visitor Agreement.
$250 for the wife’s Volvo and $600 for the sprinter. I’d jump for joy at those CDN prices.
I had a mechanic friend, who use to work at that Ford dealership, call the service manager he knew to ask about the car. S.M said codes showed timing and other issues. Friend said they needed to do proper diagnostics. At that time it did have other codes. Can't remember what they were. But they didn't show up again after I put in a new throttle body.
And yeah, that dealership is off my list. I usually take it to an independent shop now. But, now the cooling fan keeps running (at x's) when the engine is cut off, after running short distance in cool weather. Coolant and everything looks good. So may just throw a fan control module on it.
Yep, Bill Collins. "How dew yew dew!" lol
You might want to check the AC thermal expansion valve. I had the same symptoms on my Ford truck. Evidently it’s a known failure point. Usually you see very high, high side pressure in the AC lines. The pressure sensor could be bad as well.
I spend way too much time looking at youtube….
https://youtube.com/@hhwheels?si=Sd8gSPDg_0SWqVuB
Just taken from Google AI,
A full synthetic oil change in Canada typically costs between $80 and $120, with a wider range of $66 to $137. Conventional oil changes average around $60, with a range of $42 to $73. Local factors, like the specific oil brand used and the service location.
So @ab348 paid a little bit on the higher side, but it is a Cadillac.
I haven’t paid for anything yet since the appointment is next month.
The oil is GM Dexos synthetic which is factory fill. I also got a $20 coupon this weekend emailed to me from the dealer so it will be $89.00.
Their Nissan franchise is the one that tried to rip me off on an Ariya. It was a much nicer color, but not nice enough to lease for 3x what I’m paying for mine.
I wondered the same.
When I told the Ford dealership I did not want a new or rebuilt engine, I went into the dealership to pick up the car and pay for the diagnostics. On the sales receipt, to my surprise as it had not been mentioned before, it said I needed a new throttle body. This was a part already recalled by Ford and already replaced once by prior owner. Symptoms of a bad Mercury Milan electronic throttle body matched the symptoms the car was showing. So I took a chance, a couple hundreds bucks, and replaced it myself.
Bill Collins or Oxmorons I bet.
Something similar happened to a co-worker; he told me what those guys diagnosed and a quick Google search reveal ed the real issue. And just last week a friend told me he took his car there for a brake job; he asked them to diagnose a CEL and they told him that would be another $188.
————————————————Since you said “a couple hundred bucks”, that had to be the sensor because the throttle body unit would be around 5 times that.
That’s why I only have my car hand washed. I won’t even let my Genesis service put my car through their car wash machine after servicing it. Genesis offers free car washes for as long as you own the car wash- never took advantage of that perk.
My guy charges me $23.95 for an exterior wash and 44.95 for a complete wash and exterior/interior cleaning. I’ve had my fill of auto car washes and the damage those machines can cause.
Sometimes dealers aren’t the bad guy. Two indie mechanics told me my son’s 2010 Fusion (same as Jipster’s Milan) had a very small oil leak in one head gasket. Not something you could ignore. Neither did head work so I took it to the Ford dealer who correctly diagnosed it as a leak in the timing chain cover near the head at a known weak spot where there was no gasket, only silicone sealer.
While it was there they did the airbag recall which I was unaware of.
Just like @driver100 's Mercedes!
I installed an electronic throttle body. The sensor is internal.
I pulled out the old sales receipt so you guys could check it out. As I mentioned earlier, there was no talk in my phone conversations with the dealership about a faulty throttle body. The talk was that there were numerous codes and talk of timing issues, possible stretched timing chain. Talk of we can get you a rebuilt engine for this much, a used or new engine for this much.
One code indicates possible throttle body fault.
Given there were a lot of “may needs” in there (meaning they were guessing) and only 1 “has to have” you made the smart decision.
That's why I stick with brands that have good local dealers. Ford and VW are off my list because the dealers located nearby are hopeless.
Wait until they hit you up for wiper blades, a cabin filter, gas filter, new brakes, a muffler etc.
This is the inspection report we just got from Honda World on a 2021 Honda Passport.
This is the services they performed.
"Transmission serviced (fluid changed) , transfer case serviced (fluid change), differential fluid changed/ serviced. Replace oil and filter, replace cabin air filter, and wipers. At the body shop getting some minor scratches getting worked on"
Suppose to go in Wednesday morning to buy or decline. The salesman tried to get us to agree to set price last week, with no Inspection. He seemed fairly green, so don't know if sales manager would even agree.
So, I suppose the dealership will add the total cost of all that maintenance they just performed onto the price of the car? Looks to be over a grand.
Hope not. The only scratches I saw were a few on the wheels, and a scuff mark on the lower front bumper. All barely noticeable.
My wife drove the Wrangler to Kroger and someone left a duck on it. We went out to eat later and I parked next to a new Bronco; I wanted to put the duck on it but she wouldn’t let me.
A duck on your jeep means that someone likes your jeep. It’s a compliment. Worse things have happened
my theory on used cars at a dealer (and dealership prices) is they are expected to need absolutely nothing and be fully reconditioned like that.
Now that’s a different kinda duck. You should be allowed to handle chain-yanking as you see fit.
Saw that yesterday on YouTube.
Unless it also comes with something like a 10/120,000 extended warranty on the engine not a very good looking move by GM
I just give mine to my daughter. She loves them and always sends a pic of new ones put on her jeep.
When viewing a commercial this morning, a random thought, occurred to me. Are there ever any arguments over public charging points when someone has a plug-in hybrid versus someone who has full electric?
I’ve never had an argument at a charger. Actually everyone is usually friendly.
Kinda like at gas stations. I’ve never seen any arguments there either.
My fellow Jeeping friend has 3 Wranglers in his family- he drives a Rubicon TJ, his wife has a Rubicon 4xe, and his daughter has a JK. I may have mentioned that he refuses to wave at Wranglers with either a dash full of ducks or an "angry" grille. I might sneak over to his house and leave it on his.
Never seen an arguement at a gas station? Not even during those gas crisis times in the 70's?
C’mon now. Friends don’t do that to friends. You only do that to strangers otherwise it doesn’t count.
How old do you think I am?
Older than me and I remember those days!
Today’s “I’m really too old for this nonsense” project. To make the wife happy.
And yes I know the rebar has to be pounded in. Not doing that until she swears it does not have to move. Then the real fun. Moving all the dirt from the driveway on the other side of the house. That won’t be fun. And I think I ordered double what I need so I will have to move the extra someplace else!
Just remember when you go to export that crop the receiving country is going to slam you with a hefty tariff.
We are exporting it to my wife’s large collection of bell jars.
Doing the math, after buying the materials and dirt, and new lids, it should average out to about $10 per tomato or cucumber. assuming we get any because not sure she can do much with the garden due to bad knees. I have zero desire to screw around weeding but I’m sure I will get sucked into doing it anyway.
