Visitor Agreement.
P.S. I had a 98 that I don't recall having the same issue.
Frankly never heard of dealers doing this one-cutting CV boots is the most common. Obviously never go back to these people again. Betcha it is a big city dealer.
It seems pretty random, happens when engine is cold or warm. It's happened while pulling into a parking place, turning a corner, driving through Taco Bell, when I started accelerating to pass someone going about 35, once while going up a pretty steep hill. At first I thought it happened in wet weather but it seems to be doing it all the time now.
The check engine light never comes on and I haven't noticed any other problems. I started using Premium gas like the dealer suggested and it's still doing it.
I've had it to a dealer twice and they can't find anything! It's pretty annoying and I'm sure its none too safe. Any ideas or suggestions would be wonderful!!! THANKS in advance.
" It never leaked oil until you guys fixed the brakes"
That Accord is almost ten years old and it has 130,000 miles on it! Not at all unusual to have a oil pan gasket start to leak a bit.
I think it would be highly doubtful that the shop tampered with it, still, I guess that *could* happen.
You can keep a close eye on it or get it fixed. It may not get much worse for awhile.
Myself, I try to stay on top of the little things. I would probably get it fixed so I wouldn't have to think about it.
Do keep an eye on your oil level.
Were those the front tires. Maybe the previous owner cornered hard and had worn out the outside part of the tread and then flipped the tires around.
I still have the paper work which gives the code for this procedure which I had done on my 97 I4 accord. If the dealer is reluctant to perform this warranty work-go someplace else. I think the recall is good till 150K but sounds like you need an answer now.
I forgot to indicate that it was the rear left tire that had a flat. When I 1st got this car after driving several miles, I had the old tires balanced and rotated where they placed the now worn tire at the back in the same shop where I got the new tires and they never told me about any irregular wear and had drove it for around 11,000 more miles before getting the flat and discovering the worn out groove. On a side note after the rotation on the old tires it felt like the wheels were drifting a little to the right. I was told by a Honda dealer that it's just normal for front wheel drive.
Thanks again
Or it may be related to the poor mpg's you're getting. I get 20 mpg in my 2k v6 city driving.
If it's really that low, there is definitely a problem!
The service guys said that it was the styrofoam in the seat rubbing against the metal frame. They've claimed that they have replaced the frame and cushions twice now, but the problem keeps coming back within a couple of days. The service advisor says that he can't fully explain what is wrong, but the parts just aren't lining up right.
Since they've replaced the frame and cushions, what else is there to replace? What else should I ask about? Should I start making noise with somebody higher than the service department at the local dealer?
Thanks in advance for any help!
But I'll let auburn give his professional experience.
Well, not anytime soon anyways. Actually, while the highlander is a decent vehicle, I wasn't thrilled with it. I've never driven an RX, so I'm not sure if the +5K in savings comes in the form of sloppy steering, rattles and an aweful sound system. My Ex loved it, so maybe it's directed more towards women (which I suspect is the case) I prefer more of a "drivers car" and while the Accord is no S2K, it does have plenty of pickup and the best steering this side of the 3 series...
And as far as the wife, well she had a few rattles too and a really bad sound system that I couldn't turn the volume down!
sflora
Still sounds like a plastic bag on the exhaust as we see and smell alot of these...
During one of my visits to my Honda dealer, one of the guys there suggests a fuel injector flush for my Accord 2.3 2000 at $150!
I happened to notice that there are a lot of fuel injector cleaners sold in the market, are these cleaners good enough for me to use on my car and skip the expensive advice from these sales folks?
Thanks a lot.
Thanks a lot.
There is a system that has you remove the incoming fuel line, disable the fuel pump and has you use the cleaner(under presure)to run the car and clean the injectors.This system is better because it is more of a concentrated cleaner mix that is going directly through the injectors and spraying the backsides of the valve at normal fuel presure.
The other kinds of fuel injection services in my opinion are not as good. They usally have you inject the cleaner solution through a manifold vacuum source (which may clean a stream down the intake but not much else)into the cylynder past an open valve(maybe touching the valve maybe not) under no presure, then burning away. Then they also have you add an additive in the fuel tank that does the actual cleaning of the injectors and valves under a diluted fuel mix.
So if the type of system used is the secound way then just buying some over the counter cleaner would be just fine. I like Techron if it is available in you area. Honda as of now doesn't have a recomendation for when if at all this should be done so it comes down to what you want and can afford for your car. Hope I answered you question without giving you more things to think about..:)
and then every 5,000 miles thereafter.
Do whatever you feel is best, but I think the fuel system flush is a service department
rip-off...
one thing tho, at high RPMs the CR-V doesn't sound as good as accord, it sounds kinda cheap, like a toy.
Have heard good things about Techron-but if it ain't broke-don't fix it. Carry a bottle of Techron in my trunk but no EFI problems yet.
I am almost certain it comes from tranny.
Any advise or have you heard o this problem before?
All you are doing by letting it warm up in your garage or driveway is wasting gas. And it is actually bad for the vehicle, IMO (although plenty of car experts will say the same thing).
I have a '01 Sedan with the Michelins which I am mostly happy with. The only problem is they seem especially loud over rough pavement. Does anyone else have this issue or is it the car itself?
I now thinking of changing to better tires when these wear out in about 10-15K more miles. Although I haven't made a final decision, the Dunlop Sport A2's are my current favorite. They are "H" rated tires (the Michelin MXV4+'s are "V" rated), much quieter, have better traction, and are supposed to be better performers.
You can go to tiretrack.com to compare various brands and attributes of tires.
read the ratings on tire rack for the MXV4, X-one and any other tires you are considering.
