Nissan Quest/Mercury Villager problems
Quest will have a short production run for 2002 and will be back again on 2004 (actually May of 2003 since Nissan is the first to bring in the new cars). It will be an all Japanese Engine and tansmission however the Cabin will be designed by Renault. Renault is expert in space effeciency and they know how to take advantage of nook and crannies. Also the headlights & grill,bumpers will be European. Will have side airbages and maby curtains too like the Mercedes. If you check the Escape URL you will get an idea. Renault Van have done very good in Europe(#1 for 2 years in a row). Sounds like it will be very hot Van when it comes out. Check this site for preview:
http://www.renault.com/gb/produits/espace.htm
What you will need is a phillips head screwdriver, a pair of pliers, an old toothbrush and a can of spray throttle body/air intake cleaner. Make sure it is sensor safe. It will say on the can if it is.
Start by removing the air filter. This is a good time to change it if it is dirty. Then remove the black rubber hose leading from the air filter to the throttle body by loosening the clamp at the end. You will also have to disconnect a couple of other lines that lead into this using the pliers.
Then (with the engine off) spray the cleaner into the throttle body while holding the throttle plate open. (It's a good idea to wear eye protection while doing this - is smells vicious! I also wear latex gloves to keep it off my skin.) Take the old toothbrush and scrub inside the TB and both sides of the plate.
Once it's cleaned up, button everything back up (make sure everything is connected) and start the engine. It will crank for a while, and run rough for a little while, that's normal.
I've done this about every 10,000 miles on my 99 Quest. It may be related to the fuel we use. We always get gas from the same chain. If there were any ohter station conveniently located, I would switch brands. But PDQ has a lock on this market!
Dave
I read your message on other board that you were trying for Lemon Law protection. Any luck? I am trying the same. Can we get in touch over email? mrugshal@hotmail.com
Have anyone have trouble with Silver Protection Plan from Nissan?
Are there any other better deal?
Should I go for 7 years?
Thank you for those who gives me comments.
Steve
SUV and Vans Message Boards
Carrie
Has anyone ever had a similar experience or know what could cause such a phenomenon?
Thanks for your input.
Anyone else?
Steve
I have just joined the ranks of Quest owners, having just purchased a wedgewood blue 1999 GLE with 21,000 miles for $12,600. Before buying it, I read through the messages posted here (all 600 of them!) so I know some of the things to watch out for: As far as I can tell, my middle bench seat does not shake noticeably. And according to the Nissan customer service computer, my wiper switch and tail light assembly have been replaced. I paid a Nissan dealer to give the vehicle a complete check-up before I bought it. Except for some very dusty rear brakes and loose mud splash guards, the mechanic found no major problems to be concerned about. (Those could be explained by the fact that this vehicle started its life in Arizona and Texas.)
I picked the Quest because I like how comfortable it is to ride in and to drive. I test-drove all 10 models of 2 to 3-year-old minivans before I picked the Quest, and I fell in love with its feel as soon as I drove it. It feels much more stable compared to the Odyssey and Sienna, which both feel like riding an elephant on a rollerskate the way they sway back and forth on quick curves. I also picked it for the removable seats and 4th door. (I had to spend a bit more to get a 1999 to get those features.) Since my husband and I exhibit at lots of trade shows for our business we need to haul a lot of items to furnish our booths. (No kids yet, but now with a van we have room for some.) We are planning a second honeymoon next August -- a repeat of our first one 10 years ago -- driving from California to Wyoming and through 8 Western states. We hope our new van will give us a great trip.
I also have a message for Dave (dhoff #502) regarding the horrid smelling A/C. There is product made from natural herbs which can be sprayed into the system to disinfect all the "yeasties and beasties" living in it. Works on window A/Cs too. Let me know if you would like more information.
Tika
I purchased a console at Costco (I'm fairly certain) for my Quest. It's been great! It comes with 2 cup holder, a little flip up place for glasses, a deeper console for trash if you'd like (I put CD's and all kinds of stuff in it) and a few other little odds and ends holders. It fits perfectly between the 2 front seats. I've tried to transfer it to my new Caravan but it is too loose. I worry about it coming loose and hurting someone in the event of an accident.
And, thank you mrperfect for your input about the fuel pump. I asked the Nissan guy about that and he said that if it was the fuel pump it would be acting up more frequently. However, it is possible there is something wrong in the electronics part of it that acts up when my car heats up. Who knows?! I have it in the shop right now (getting that check engine light to turn off) and I'll call and have him do a check with the fuel pump and see what he comes up with. We are getting ready to sell the van and want to get this problem fixed before we hand it over to anyone.
Thanks again!
Carrie (proud new owner of a Dodge Grand Caravan)
Regarding the center console, I was at Big K earlier this week and saw one there that looked like it would fit perfectly. It had a storage compartment in the top with a door. It was even a gray color that looked like it would match the interior (if that's what you have). Didn't look at the price.
Cutnfun, it's either a fuel delivery or electrical problem (just call me Mr. Obvious). Too bad it didn't store an error code when it quit. Just to help narrow it down, does it jsut suddenly die or does it sputter or miss a bit before it cuts out? If it's really sudden, I think it would more likely be electrical. Let us know what happens.
Dave
Help!
AltimaMan
Can someone please help me with this? Is there a recall or something out there that I don't know about? If other people are having the same problem with the same van, same year??????? If so, then something must be done! If anyone knows anything about this or how to find out about these kinds of things, please let me know!
I would love to sell it and get something newer, but my husband just bought a new Nissan Frontier, so I really don't want to have two notes to pay. I really need to get this problem solved!
Do you think Nissan is covering something up???
Thanks in advance for any responses!!!!
Susan
I also had the same intermittent problem a few years later and had to tell the Pontiac dealer what to replace. Have seen caddys, Lincolns, Mazdas, also with the same problem. It is a bear to convince half-trained mechanics what to replace. Even if you have to pay for it yourself, fixing the auto is the primary thing -- who cares why they fail. Many ford products have the fuel filter clamped to the frame under the rear of the car -- talk about out of sight, out of mind.:-)
My full load '99 SE is about 15 months into its warrantee - seats still shake miserably - still as far as i'm concerned a potential safety issue.
Chris
Greg
Thank you to you and others who have commented on various center consoles. I found a very nice heavy-duty one made from wood (not plastic) through the Herrington catalog.
Anyone out there with this problem?
I am having a problem with the van hesitating, usually when I first drive the car after a resting period, but not consistenly--maybe once a day. There's also sometimes a bad exhaust smell in the cab (!) when the heater is on. And, the O2 sensor is tripping the check engine light, though the O2 sensor is fine. I've got 107,000 very reliable miles on the van. The last technician I spoke with mentioned that my catalytic converter "might not be as good as it used to be." I know nothing about catalytic converters. Would problems with the CC cause symptoms like mine??
BTW, after checking your site, and lemonaid.com, I did decide to press Nissan and got them to pay $316 in parts for the replacement of my exhaust manifold. They had to drill out 3 broken bolts. I'm hoping they'll pay the $53 I paid to have my breather hose replaced just prior to the recall (of which I have not been officially notified...) Thanks!!
I bought a $3.97 can of throttle body cleaner and followed the directions. I have not had a problem in the past 1000 miles. Larry
Steve
Main complaint is mileage. Can't get up over 21.5 on highway @ 7o mph, steady foot. Is this normal for the new 3.3? Met a man the other day with a 3.0 (assume he's honest) says he gets 27-28. Best I can get goi
Steve
27-28? I kind of doubt that. Maybe drafting behind a semi. :-) May have been the kind of people that figure their gas mileage by looking at the gas gauge rather than how much gas they actually pump in.
Did you really get 29 once Steve? Are you sure you didn't put $5 worth in the tank and forgot about it? ;-) Heck, I get 29 mpg in my Nissan NX. 1.6l 4 cylinder, 5 speed, frontal area about 1/3 of a Quest... I suppose it's possible. I'd be really skeptical if someone claimed to be getting that consistently.
Dave
As far as the transmission goes, in a few years of monitoring everything I can find on the internet about these vans, I have heard of very few transmission problems with them. That's not to say there are none, but compared to the others, not many at all. I know that is of little consolation to you though. I suppose it is possible the tranny failure could have been related to the engine repair, if they connected something wrong or something.
As far as trying to get some of this covered, do some reearch first. Check Alldada for TSB's. They can be purchased online. I'm sure you will find something on the crankshaft there. Once you find the info, take it to your dealer and let them know that you know there was a known problem with these engines, and you'd like the repair covered. Try to be firm and polite, and don't lose your cool, because the dealer will have to contact Nissan for you and it would be good to have them on your side.
I wish you luck on this. That's a whole lot of cash to pay out for repairs. Let us know what happens.
Dave
I got 29.9 on one tank calculated after putting 10.5 gallons in at 31,166 miles on 11/26/99. My figures never lie:-)
I got 10.3 on a 16.2 gal. fillup at 28,533 miles on 11/10/99, but I think that was an anomaly, lol.
stevenb1; here's the link to the VillagerQuest group. I think it's a public group so you can search the archives without having to join if you don't wish to.
Steve
