Chevy Silverado - Continued XII
As to why a running engine was taken apart at 170,000 miles. The rear main seal was leaking on that engine (300 six – Ford) and while the pan was down I put in a high volume oil pump. The crank, rods and pistons are clearly visible at that point. Again not one bit of sludge in the pan or anywhere else for that matter. By the way, I don’t care what oil you use, you’re going to have the metal discolored from the oil. Especially with that many miles.
Quad,
Ash, sulfur & acid are by products due to combustion (I don’t think I said they were added. I said the were low in those.) but Havoline comes in pretty low on the scale.
Use what you want, I’m sure everyone has their favorite oil. That’s just my opinion from my experience. I still stick by multi-weights over straight weights.
I think we can all agree on one thing. If you continually change your oil & filter you won’t have any problems.
Gene
used AC PF59 first two changes, if i can find one, i'll use it again next change. o/w M1 #201. will prefer AC PF59's though.
live in sc now, moving to pa/nj/va/md area in a year.
never used any fuel additives, never will.
my 0.02
kyle
Gene
clay
www.zainobros.com
I thought I saw it all until I tried this brand...
good luck!!
http://www.meguiars.com/fastrack/fastrack_getanswer.cfm
Dustyone
kyle
some are Polish/wax combined..
It's better to do in seperate stages.
Clean
Polish (maybe even more than one step)
Wax
Another good wax is Malms
http://www.malms.com/
It doesn't have the buzz as Zaino does right now...as it has been around for decades. It is mail order only.
For my Hurst/Olds I use 3M hand Glaze. It does not offer much protection from the elements (it does bead water and offer a tiny bit of protection)...but it does not sit outside or even see Rain..so that is OK.
A good clean/polish/wax....and keep shiny with Glaze..(dark vehicles)...makes a very good looking truck.
Good luck
- Tim
- Tim
expert.
Use Liquid Glass, multiple coats, on my purty Street Bike paint. Does look great on purple/blue.....
UPF59 - Ultraguard gold
SPF59 - Duraguard silver
PF59 - Duraguard
Im thinking ill probably go with the gold
Ryan
kyle
my 0.04
kyle
Ryan
Agenda:
1.)wheel flares
2.)spray in liners
3.)bug shields
4.)side steps
5.)3/4 vs 1/2
6.)oil topic
7.)tindra
8.)new business
9.)old business
10.)adjournment
I've used Meguiars products for years and am a real fan of them. Meguiars #9 is an excellent swirl remover which will quickly remove all the minor surface imperfections. Wash the vehicle again and then follow up with #6 cleaner and wax. Or I also use their yellow paste wax. I forget the number but it easy to find in any auto parts store.
If you have more serious problems, e.g., bird poop, or harsh stains, use Meguiars #5 which is a little more agressive but it will not cut too deep. I always use a power buffer with a foam pad but I would not recommend this to someone that has not done it before. Practice on your wife's car first! But, always put the cleaner/wax on by hand with a soft cotton cloth changing it often. A baby's diaper works great, I have used them for this purpose for years.
I really feel you can never wash your truck too often, minimum of once a week, more often if it gets real dirty. I wax my truck at least three times a year, four if I've washed it a lot.
My .02 cents.
clay
know, colors, brands, do you need to drill holes
or not. also you did'nt mention mudflaps or floor
mats. oh, don't forget about spark plugs either.
we'll also need more participation from Tim to
get all the right answers.
Biggest disappointment about my new 2500HD is it will come with those queer looking plastic fender flares.
1. Check master cyl fluid level
2. Check pwr steering fluid level
3. Perform hyd booster functional test-normal function-brake pedal
falls away, then pushes back, abnormal results, see accumulator leak-
down system not holding charge below
4. a.turn ignition off
b.park brake not applied
c.sart engine
normal function-Brake warning indicator illuminates briefly
abnoral results-brake warning ind always on or inoperative
5. With the vehicle in park, perform the brake pedal travel test.
normal function-brake pedal moves steadily toward floor, approx
2-3 inches, brake pedal stops and is firm against the pressure (hyd
brake booster may hiss or clunk/click/clatter w/ high brake pedal
effort)
abnormal results-test for brake pedal excessive travel, test for
brake pedal travel gradually increases
Accumulator Leak-down test for soft or spongy brakes
1. Start engine
2. Charge the accumulator by pressing the brake pedal or by completely
turning the steering wheel in one direction or the other.
3.Turn the engine off. Let sit for 1 hr.
4. Perform 2 pwr assisted applications with the engine off
(pump brakes twice)
5. If accumulator failed to hold a charge after 1 hr, but functions
after 1 hr, the accumulator valves are malfunctioning. Replace the
acculator.
6. If the charging and discharing of the accumulator is audible,
the accumulator still fails to hold a charge, the valve is
malfunctioning. Replace the accumultor.
7. Empty the accumulator by pressing the brake pedal 30 times.
8. The accumulator can will rotate or wobble if the accumulator has lost
its gas charge. Replace the accumulator
Brake pedal travel should be no more than 70mm (2.75 inches),
most common causes are 1. external leak, 2.internal leak
(master cylinder), 3. air in system,
Hope this helps
Dustyone
Guys went to 3 more placers today
2 kmarts and 1 autozone no oil filters. Can you buy them online anywhere??? PLEASE HELP!!! haha
Ryan
looks to make sure i was'nt seeing what i thought
i saw. sorry to hear that yoy're gonna get stuck
with the extra plastic.
just wash it out and then reoil it. be careful
when reoiling though. this way you can change oil
as often as you like.
Ryan
trucks yet. i do have a 1/2 dozen pf59's though.
be glad to give you one but, you gotta come and
get it or pay for shipping. fair enough?
...red
They also have the best floormats for $5 ea. or so. Look like they'll hold a 1/2 gal. of water. I threw the originals right in the garbage.
Also I went to Sears to buy some 285's this weekend. They said "won't fit" your stock 1500 rims. He looked it up in the book. I've seen pictures of trucks with 285's and even 305's ... but haven't noticed if they were aftermarket wheels? What about it?
and for the best purchase price?
...red
Red,
I thought you were the King of waxing it?
- Tim
...red
But if Sear's follow the book - they probably won't install them for you.
There are many people running the 285's on stock wheels, including myself. So try finding another tire dealer and enjoy the upgraded tires. By the way there is absolutely no rubbing on my 2000 Z71.
Greg
There are a lot of good waxes and cleaners out there. Find a brand you like and stick with it. It's not so much the brand you use...it's just getting out there and doing it!
Your truck will always run better if it looks good. No kidding!
clay
PF-59 Oil filters are available at your local Chevy/GMC dealer. It might cost a couple of bucks more than someplace else but at least your not running all over town trying to find one.
Randy
Randy thanks man good suggestion. I dont know if im gonna do my oil change saturday now (dads golfing and i am gonna go to a softball game, yes its for the girl) it might be early next wk so i still have some time.
Thanks guys
Ryan
Clay,
Yup...the key is to do it!
I used Meguires Cleaner/Wax for over a decade. Did it work good?...yes. It will take slight oxidation off as well as Wax and leave a damn good shine.
It all comes down to how anal you want to be I guess? For dark colors..to me...a cleaner wax is like using sandpaper. I Polished my Hurst/Olds so much..you could see the primer in some spots. So i finally broke down...Spent about $6000 on a nice paint job...and she is soooooo nice now. Not a spec of Orange peel...smooth as glass. It was that way before after all the waxing...uhh..where is this going?...oh yeah wax!
..Lot's of good stuff out there. Will you see a difference on white or pewter using Zaino or Malms VS Meguires?....maybe not....
Now Black and Blue you will..
Use whatever you want...and it all comes down to how farr you want to take it how long you want to spend doing it...and of course..How much mooolah you wanna pay!
Every time I wash the Olds..I glaze the entire car. Now the truck..(I hate washing that damn thing)...I think I have yet to vaccuum the interior?.....LOL
- Tim
Ryan
* performance accessories like:
k&n intake
magnaflow exhaust
edelbrock ias shocks
whipples
hypertech chips
* all of us picking on ryan for any number of things
kyle
my 0.02...
by the way, what do we have to do to see a pic of this beautiful paint job on your hurst/olds. i know, it's a silverado board, but i think we can take the criticism of a few folks who are jealous. post some pics man!!!
kyle
Since I'm the lazy type when keeping records, I'll just have a friend who is an ASE certified mechanic with his own shop sign off on the servicing of the truck. Keeps the dealer happy and me under warranty...
Pics of the Olds?...Ya know...all these pics I have snapped with the Digital...and I have yet to do any with the H/O....hmmmm
I don't even think I have any in the computer!
it's still in the back room of the garage, but I can uncover it..(may be a little dusty) and snap a few soon for yawl..
I will have to scan some pics of it in the sun..or wait until voodoo Ryan quits his rain dances here!
LOL
I like 68/69 H/O's....but didn't end up with one. When I was at the end of high school..the 15th Anniversary H/O (1983) was out and I thought it was the nicest car around. A few years after High school..I bought one...(rolled it later)..then bought another nicer one. The 81-88 Cutlas Body style was always one of the body styles that just grew on me....and the H/O was the only configuration I would have it in.
The early eighties were the "we gotta use emissions, but have no clue how to get power with them" years...but it goes good for that year. Fastest car for that year..beats a Camaro/Firebird/Stang...and there was no Grand national or even an 83 vette....( I know...it's still farr behind todays cars..so don't tell me)..but it gets lots of looks.
blah blah blah...
I'll get something posted soon...
- Tim
Ryan
Just let me know if you want to see them.
-Jarvus
