Visitor Agreement.
Fail; epic fail!
If you think driving a car is like piloting a boat then it's no wonder why you don't understand the concept. Like it or don't, believe it or not, if you apply too much negative acceleration to the rear wheels of pretty much any wheeled vehicle from a coaster-brake bicycle to a multi-million dollar F1 car, it's going to have the back end come around.
for that unit also...any Alero 3-pedalers out there?
Sticking around is still sticking around. Fine by me.
Also, how many practice runs would YOU need in the RWD of your choice in order to come out just as close to the top as you did with your FWD...?
Well, like I said, I'm not going to be as fast in my 540i no matter how much practice I get. It is 400-500 lbs heavier and easily overpowers its rear tires. If we go by cost, there is not such thing as a stock RWD car for the same price as my GTI (new vs new) that will outperform it.
I'm thinking there are precious few RWD cars of any stripe or cost that can challenge a GTI on a tight track; the Honda S2000 (no longer in production) comes to mind as one of the few.
"..apply too much negative acceleration..."
Negative acceleration, REAR braking, DRAG at the REAR, and the rear would begin to come about...!! Did you really flunk physics that horribly...?
For example, a C5 Z06 is still the overdog in a class that includes the Elise.
which reminds me... I NEED MORE POWER....what with ordinary sedans these days sporting 250+ HP, I can't get away from these maniacs fast enough. Maybe a Corvette would do it--used ones are cheap.
Really? Just rented a 4-cylinder Camry for a week... was thinking, what's the point of the V-6?
I was chirping tires all over the place... :surprise:
Of course, I think Mr. Shiftright is thinking in different terms.
Auto as well...all the weight shifts back. You could use momentum, though.
Long wheelbases make the problem worse. My Sienna struggles to climb up my driveway when there's snow.
My Subaru laughs it off like it's nothing.
GTI are not particularly quick at track events.
I think I need about a 4.3 to 4.5 -second car so that it's "no contest". :P
Was actually pleased with the local driving habits... fairly courteous, though they use the horn a little more than I'm used to...
And, hey, as long as its a manual trans, who cares, right?
No, but clearly you did.
Don't believe me? Get on an old coaster brake bike and slam on the brakes; the back will come around 99 times out of 100. If you don't know how to ride a bike (wouldn't surprise me) take a car out in the snow and yank the parking brake; the back will come around 99 times out of 100.
Does your GTI have a limited slip? Mechanical or e-diff?
Then my bike(s) only had rear braking.
If one's speed at the end of onramp is properly FASTER than the freeway traffic, then merger/mergee is reversed, and such faster onramp traffic can then be very polite about letting the freeway traffic merge.
The GTI doesn't have any form of LSD. I'd like to add one, but that, of course, would put me in a modified class.
Face it, we all know you've got it wrong, in fact, we all suspect even you know you've got it wrong and you're just being a contrarian because you're too embarrassed to admit you messed up.
RWD, power, over-driving the rear, yes, but braking at the rear...??
ABS, Traction Control, Skid Control, all of the above, none of the above, it matters not; if the driver of a manual transmission equiped RWD vehicle dials in enough negative acceleration to to cause the tread of the rear tires to exceed the traction available at the rear wheels, the car will attempt to spin.
I looked back and I see that you conveniently ignored a post I made in June which outlined a scenario which would result in a spin due to the loss of traction in a RDW vehicle.
http://townhall-talk.edmunds.com/direct/view/.ef6716a/6884#MSG6884
You'd have no problem if you ever drove my '79 Honda Accord hatch which had a nasty habit of locking the rears under hard braking on slippery surfaces (it was fine on dry ones). Usually I could catch the swing by countersteering but a couple of times it caught me out resulting in fender-benders.
Light in rear+weight transfer forward under braking=loss of rear traction (skid) with slightest change of direction.
It's not that hard to figure out and I could do it at will on a bike by jamming the rear brake only.
Actually, simple physics will tell you that the rear locks up first in this situation. Think about it, you are headed downhill and you slam on the brakes. The rear of the car becomes very very light. Without that weight over the rear tires, they lock up far easier than the fronts that have all the weight fighting the brakes. It is quite possible the fronts didn't even lock. They were still rolling along with all that weight behind them, the rears locked, loosing all traction, and tried to swing around. Pretty simple.
http://www.youtube.com/watch?v=raBWKJhevh8
I think the point of that video is to show that when a car is not in balance (such as, just in one case, it's leaning in a turn), that any sudden application of brake or gas will cause serious instability.
I remember when I was taking the Open Wheel course at Skip Barber (RWD Formula Dodge) and we would go around sweeping turns at (for me) considerable speed), that even if I let off just a bit too much on the gas, even "feathering it", I could feel the car move in the seat of my pants.
Which is okay, to a point. If you actually want to win races, you have to be right on the edge of control. "If you're in complete control of your car, you're not going fast enough" said one famous driver.
Saying that a RWD car will not deviate from a straight line when heavily braked is like saying that every car crash you see will be just like the ones conducted in DOT videos.
What part of simply rolling down a hill in second gear using engine/compression braking didn't you get? So, no brakes, no downshifts, no nothing, simply rolling down a hill.
Hmmm, sounds like wwest is in "grasping at straws to desperately try and save face" mode. Sorry, you lost that chance a long time ago.
Sure, those were RWD/4WD, but I'm talking throttle up, braking only scenarios that would make those things swap sides.
Those pickups simply had no weight on the rear axle, so anything at all would cause the rears to lose traction, accelerating or stopping.
My bad!
This was especially effective on my '83 GTI which would lift the outside wheel instantly cutting rear traction by 50 %. :P
