The Future Of The Manual Transmission
1152153155157158205
    Apples vs Oranges....
    You're missing two fairly important factors.
    Nope, I didn't miss either point; at 2,500 RPMs it is impossible to lug my engine (or pretty much any modern engine for that matter) even at WOT.
    Fact, if I want a lower gear for better acceleration, I'll simply choose a lower gear.
    How is it Apples to Oranges? Are you saying that the engine in automatic equipped car is capable of maintaining a steady state speed of 70 at 2,445 RPMS but that the engine in the manual equipped car would be unable to maintain the same speed at 2,500? :confuse:
  • plektoplekto Member Posts: 3,738
    edited August 2011
    Remember as well that
    1: there is far more friction and mass involved with the automatic as opposed to the manual. The same physics apply as they always have. Automatics have 5-10% power and MPG loss over manuals at the same RPMs.
    2: Most manufacturers set their rpms as low as absolutely possible to get the same MPG ratings for their automatics as manuals. (!) The final gearing on most automatics is there just to make the EPA happy and has no correlation to real world driving patterns. If you so much as touch the pedal with one toe it will unlock the torque converter and drop down a gear. It's good for level ground only and is essentially coasting or close to neutral RPMs as it can get away with. Because of the higher masses involved and more friction/drag on the driveline, the automatic transmission acts like a very large flywheel so it won't actually stall out or lug as easily. The transmission will almost always shift as soon as it physically can as well, which would nearly stall most manuals. All to get better MPG.
    The manual? No such gimmicks or problems. Better speed and driving dynamics at all times. And the same MPG. (and a slew of other benefits, not the least being $600 for a clutch vs $4000+)
    Yes, but only if your desire is to accelerate to a speed ABOVE 50MPH.
    To simply "hold" a set speed "peak torque" as you're using it has no meaning.
    You fail to understand that these 2 tasks are not mutually exclusive. What do you think happens when you start climbing and incline and want to maintain a steady speed? Well, I'll tell you, you open the throttle more. So maintaining a set speed is completely dependent on the power available.
    "Lugging" an engine means trying to maintain or attain a speed without the necessary power available so that it is struggling.
    edited August 2011
    on all camaro V8s the torque converter can stay locked in both 3rd & 4th under a variety of throttle/acceleration conditions. no way does it unlock when you give a small blip to the throttle at highway speed. only if you stand on the gas would it do that.
    with 'underpowered' slushbox or other automatic-transmission cars, yes, the slightest throttle blip might unlock torque converter or otherwise downshift at highway or any other speed.
    regarding torque peak and road hp - it is very relevant to have torque peak be near the rpm which provides the optimal rpm & necessary road horsepower to keep the car moving at highway speeds. diesels & v8s tend to have lower torque peaks ideal for this, providing ideal highway mpg 30 mpg or more, with big and/or sporty cars.
    a real world side effect of these vehicular/engine differences is that the speed for peak mpg can vary widely between various vehicles. the speed vs mpg curve can similarly vary. one can select a vehicle optimized for mpg depending on the highway speed one prefers to drive, whether it's 80 mph or 45 mph, in right lane either way :) (right lane is both the slow lane and the fast lane on modern USA highways. :| )
    "..even at WOT..."
    And therein lies the problem with your understanding. To maintain a constant roadspeed of, say, 70 MPH, requires nothing close to WOT, far from it for most engines.
    70MPH and 2500 RPM can result in lugging for LOTS of engines. At partial throttle, only enough A/F mixture charge in the cylinder to maintain that speed, there often is not enough energy in that charge to push the piston downward as fast as need be, so you get knock/e to engine lugging.
    DSG only for the 2012 VW EOS .
    No, but I am saying the ECU in the automatic NEVER SLEEPS nor does it EVER get LAZY. So automatics can be geared, and are geared, to run much closer to the minimun torque production level for common US highway speeds since the ECU will NEVER allow it to enter a parametric level that would compromise the long term or short term engine/transaxle life.
    There is no way, ABSOLUTELY NO WAY, that I ever wish to be burdened with continuously shifting my manual transmission up and down the way most automatics do these days in order to obtain the absolute best FE for ANY road conditions.
    You may wish to take note that modern day automatics are attaining better FE than their manual brotheren, even with a driver trying the utmost otherwise.
    1. Lossy torque converters are being bypassed in as many as 4 of the 6 gears. ATF gear type fluid pressure pumps are now under real time ECU control (linear solenoid) and only pump against a pressure head during actual shifts. FULL coastdown fuel cut techniques can be used with automatics whereas manual transmission engine MUST always be "fed" idle level fuel.
    2. As you may note above most modern day automatics are geared sunstantially TALLER that their manual brotheren. With an automatic the ECU is available to INSTANTLY switch gears, downshift, if the need arrises. Also be aware that the ECU already KNOWS the engine is entering a parametric zone prone to knock/ping BEFORE it actually happens.
    "...just to make the EPA happy.."
    Along with 99% of the public now paying north of $4.00 for gas.
    "...Better speed and driving dynamics at all times.."
    Dynamics, yes...YES, speed...NOT.
    "...same MPG.."
    Sorry, just no way, yesteryear, sure, but no more.
    Exactly, which is why a 6th gear in my car netting 2,500 RPMs at 70 would be perfect; thank you for finally admitting that.
    I've driven well over 100 cars with small engines and I have never once driven a car which can be lugged at 2,500 RPMs (although it wouldn't surprise me to hear that two and three cylinder engines can be lugged at that speed). For the 2.0 liter Mazda3, 2,500 RPMs at WOT isn't even close to lugging the engine.
    edited August 2011
    That comment has zero relevance to the discussion at hand, namely gearing the top gear of a Mazda3 or an Audi A3 (both have been discussed in this thread) tall enough to achieve a few hundred RPM reduction at highway speeds.
    Nothing in what's been discussed here would suggest constantly shifting when running down the interstate. If my car had the theoretical 6th gear we've been discussing, it would probably be necessary to downshift from 6th to 5th when climbing a steep grade of say over 5% at 70 mph, but hey, I can live with that no problem. In the case of an Audi A3, even that downshift wouldn't be necessary.
    "You may wish to take note that modern day automatics are attaining better FE than their manual brotheren, even with a driver trying the utmost otherwise."
    Please name me even one car where the field reports indicate better fuel economy from the automatic models versus the manual models. I've read numerous test reports and anecdotal fuel economy reports for cars which the EPA tests indicate the automatic returns better fuel economy, and as of yet, not one field report confirms the EPA findings of superior automatic fuel economy.
    "..not one field report.."
    And just how many "valid"(***) field reports would you expect to see..."
    *** Same, same, same, except manual transmission vs automatic. Anyone out there have those vehicles, two otherwise EQUAL vehicles, at hand to provide that field report....??
    I thought not....
    Yes, no doubt, your new gas-hoggish Camero V8 (Mustang, Charger,etc.) have a fairly wide operating range in any given gear ratio, vs a tuned for FE V6 or I4, wherein it can remain in lockup. On the other hand if the engine/transaxle ECU decides that the engine load is high enough to warrant an A/F control mode(***) switch it WILL also disable lockup.
    Didn't you write:
    Please provide us with support for such a claim; by all indications no such a car exists (at least not yet).
    "...underpowered.."
    No, just adequately powered, no need for a gas-guzzling V8, or EcoBoost V6, such as today is found in the new fleet of muscle cars/trucks.
    Cayenne + many others. Do your own research.
    edited August 2011
    When was the last time you saw a HP/torque curve/chart that indicated the engine performance throughout the RPM range but always remaining in A/F mixture control of only the oxygen sensor(s), not the MAF/IAT...?
    I believe you were indicating real-world results not EPA results; you made the claim, please back it up with some data.
  • bobw3bobw3 Member Posts: 2,989
    True, but spend some time on any Mazda board you choose and see if you can find even one owner of an Automatic equipped Mazda5 reporting mileage figures as good as the EPA numbers. On the other hand, there are numerous reports from owners of the stick-shift model reporting numbers which handilly beat the EPA estimates.
    The EPA esitmates are not real world.
    edited August 2011
    Nor is anecdotal evidence, in a sense. Anecdotal evidence is very tricky. What you really need is people who *don't* own Mazdas (or whatever vehicle) driving them and rating the MPG--I mean if you want REAL real world, without bias, tricks, math errors, etc.
    Or, if it's from the owners, then their log books for say 6 months of driving.
    edited August 2011
    To be sure I'm one of the first to dismiss the odd anecdotal report as irrelevant, however, at some point anecdotal reports start carrying some weight when said reports are numerous and point to a very identifiable trend.
    Regarding the Mazda3 and Mazda5 fuel economy comparisons (the two cars share their platform and their drivetrains); I currently drive a Mazda3 and spend quite a bit of time on several Mazda related boards. Choosing my words very carefully here; the indications of the literally hundreds of mileage related reports I've read suggest that automatic equipped Mazda3s and Mazda5 are unable to (or are barely able to) achieve EPA figures even when driven extremely carefully. On the manual transmission side of the house, reports of drivers easily besting the EPA numbers are a dime a dozen.
    Does the above constitute hard and fast evidence? No. Does the above indicate a trend which might be worth further analysis? I think so.
    I'd much rather depend on an auto magazine longterm test for MPG, if I were actually making a financial decision.
    Boards that post MPG only sample a sliver of owners. The ones who post that they beat the EPA stats are undoubtedly proud, or at least pleased, so they post. The ones that don't beat EPA would only be those that get miserable mileage. I mean, who comes online to boast "Hey, I'm getting the mean average MPG with my Mazda!"
    So those anecdotes are dangling out there in space. Logic suggests (well, MY logic) that if one bought that model of Mazda, one is more likely, statistically to get EPA or less than to beat it.
    edited August 2011
    I would say that is true.
    Longer story even shorter, the FULL mpg RANGE is actually published on the new car sticker, pretty close to the stated EPA ratings. They are normally in MUCH smaller print. ;)
    But then on the other hand, that really negates the whole concept of reading the owners manual: specifically, the performance characteristics of one's specfic engine and transmission combination. Really unless there is something technically wrong with the specific car, driving for mpg (or lack thereof) is between the headsets, (given, given, given, etc., etc.etc.) Nowadays because of the "appliance mentality", most folks don't even have a clue as to the performance characteristics of their vehicles.
    edited August 2011
    There may well be something to what you say, however, there are numerous thread which take shape in the following pattern:
    Post 01: The EPA numbers for my Mazda5 Automatic are 21/28 and yet the best I've gotten is 19 on 300 mile trip at a pretty steady 65 mph; it's more like 14 when I drive around town.
    Post 02: Wow that's bad, our Mazda5 Automatic typically gets about 25 on the highway and 19 in the city.
    Post 03 - Post 05: Similar in nature to Post 02.
    Post 06: Geez, I'm so glad I got my Mazda5 with a stick, we just got back from a 1,700 mile trip with the family and we averaged 30 miles per gallon for the entire trip. We had two tanks which were almost all highway which got more like 33 miles per gallon.
    So there you have it, kind of a cross section of posts, those with terrible mileage, those with exceptional, and those in between.
    Like I said, none of the above makes hard and fast evidence, but I do think after reading thread after thread after thread like the above, that there are at least a few compelling indicators which could justify further controlled analysis.
    The reason you don't want your stick shift's top gear turning minimum engine RPMs at typical road speeds is pretty obvious. If, at 70MPH, your engine was turning over only just enough RPMs to put you on the "cusp" of needing to downshift should be more than obvious.
    I just drove 300+ miles over the weekend in our '01 Porsche C4 6 speed manual, 300HP. Seattle, I90, to Ellensburg, then to Yakima, and back over Chinook pass. Initial leg was mostly at 70-75MPH and mostly in top gear, 26.7MPG. Yakima back to Seattle, 55-65MPH, mostly 6th gear but some 5th for climbing, 24.7MPG.
    What I came to realize was that in 6th gear I had a lot of leeway, I could drop down all the way to 2,000RPM and still have enough torque to regain speed provided I was on relatively flat terrain and was "graceful" with the gas pedal.
    What I came to realize was that while the engine control system could not command a downshift as it might well do with an automatic, it could still switch, and undoubtedly DID switch, the A/F mixture control loop from idle/cruise mode (oxygen sensor[s]) to air/fuel mixture enrichment mode (MAF/IAT) if/when I depressed the gas pedal enough to attain that result.
    So, would I like my 6th gear taller, tall enough to drive 70MPH at the minimum RPM that produced only enough torque to move the car along at that speed...?
    No, absolutely NOT.
    On the other hand would I give a hoot if my automatic did exactly that...?
    Same answer....
    No, absolutely NOT.
    That's exactly what CVT's are all about. Take your choice, enrich the mixture whenever you wish to accelerate with a stick shift remaining in the same gear....sacrifice FE...
    Or...
    Have an ECU in charge of BOTH engine A/F mixture and gear ratio selection thereby allowing the ECU to always judge the best, OPTIMAL, action for ANY level of acceleration required...enrich the mixture, downshift, or even a combination of both.
    On my just completed drive I'm fairly sure I could have gained at least another 2 MPG had my Porsche come with an indication of entering A/F enrichment mode AND had I religiously downshifted whenever that indication came on.
    You believe....WRONG...!!
    Do you lay awake at night trying to come up with silly and controversial things to post? Apparently so because you seem to be a lone voice at sea when it comes to things like rear braking causing a spin or how well an engine might operate with slightly taller gearing.
    Long story short, I'm thinking you need a refresher physics class.
  • cdnpinheadcdnpinhead Member Posts: 5,635
    edited August 2011
    . . . you need a refresher physics class.
    Refresher? Wouldn't one have needed to have taken physics in the first place?
    "..things like rear braking causing a spin.."
    No, my position on that is you have to be an extremely inexperienced driver, or a foolhardy one, to have rear braking, rear braking ONLY, result in a spin.
    You're being deliberately dense; the scenario I outlined where an individual is rolling down a hill at a slow and steady speed in a RWD car using only engine braking to control the speed can and will result in a spin as soon as enough snow or ice is encountered to cause the rear wheels to lose traction.
    Like it or don't, believe it or not, the above will happen; contrary to your tossing out an anchor behind your proverbial row-boat.
  • lemmerlemmer Member Posts: 2,689
    This is riveting. The only way it could get better is if we reopen the kid's bike coaster brake conondrum.
    edited August 2011
    I think that in the time of Queen Elizabeth I, they used to call this sport "bear-baiting". I believe it was banned by parliament for being too cruel to watch. :P
    Now that was an entertaining post!
    As for manual transmissions, I still love them. When I reached driving age long ago, cars usually had a choice between a slick 5 speed manual or a lumpy 3 speed automatic. You'd usually end up losing 10-20% of your economy and acceleration to a manual. That gap is gone. I still like to have a manual simply to have more control of the car, but I am pretty sure I am a dying breed.
  • Kirstie_HKirstie_H Administrator Posts: 11,247
    We have a mixture, and I think for me it depends on the vehicle. Would I want a manual in our clunky '98 Chevy pickup? No. We wouldn't gain anything in terms of a fun ride or fuel economy, and we only use it to tow or haul. It'd be nothing but a PITA. I don't even really want it in my Escape, which is auto. I don't use it to tow or haul, and in fact, I use it very rarely. I've gone a grand total of 16.5 miles in the past 14 days. May add another 1.5 to it today.
    Now the Crossfire? That would be a LAME automatic. We will probably always have one little 2-person coupe, and that will always be manual.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    I'll see if I can keep my fingers in check even when certain posts grossly exceed the absurdum ad nauseam threshold.
    Adhering to the basic and reasonable rules of the Edmunds Forums is excellent training in anger management, diplomacy and character-building. I've also lost 10 lbs doing this and I feel younger and have more energy. :P
    Shifty, say it isn't so; when did you become a politician? :P
    I've found that if certain members have strong views that vastly differ from my own education and experience, and that of anyone else I know, that it's pointless to waste my time debating. I'll listen for awhile, lest the member turns out to be a lone-voiced visionary, but unlike Shifty, I'm getting old and have to focus my limited time on more valuable pursuits.
    Review your vehicle
    edited August 2011
    I'm sure this article has been posted here before, but never mind EPA numbers, in the real world manuals kick asphalt:
    http://www.consumerreports.org/cro/cars/new-cars/news/2008/10/save-gas-and-money- - -with-a-stick-shift-10-08/overview/manual-vs-auto-ov.htm
    Bottom line
    A manual transmission can deliver better fuel economy and acceleration
    A significant 2 to 5 mpg better and significantly quicker EVERY time, no exceptions to either.
    This is true even in the case of the Forester, which had identical EPA mpg numbers, it still did about 10% better with the stick in the real world. And it's not like Consumer Reports drivers are the world's most skilled, either (a bigger factor with manuals).
    Better automatics will slowly close the gap, but the gap still exists, never mind what the EPA says happened in a lab. Automakers perform those tests and EPA doesn't even verify most of them.
  • stickguystickguy Member Posts: 53,997
    someone above mentioned the gap having been wiped out, but I don't think that is really true.
    plenty of car magazines, and especailly consumers reports, still show the stick model to be quicker, especially on smaller engined "normal" cars. And I believe they also tend to get better overall RW MPG out of them too.
    I know CR has its critics, but at least they test acceleration the way normal people drive (no brake loading the AT or high RPM clutch dumps!)
    great minds thinking alike. Though you post links!
    My opinion? The makers are good at programming an AT to do good on the test, but that does not always translate to the RW (such as going to top gear as soon as you hit 20 MPH!). a stick must be much harder to massage the test results with.
    so, sticks do at least as well, while the AT suffers a bigger hit to actual drivers and conditions.
    Snuck it in 1 minute before your post. LOL
    I stand corrected about the MPG.
    I wonder if the gap narrows when you are looking at midsized V6 cars.
    So true, and you end up mashing the pedal to keep the trans from going to overdrive too soon. I remember hearing enough complaints about the GM Lambdas with the then-new 6 speed auto that GM had to recall them and reprogram the trans.
    They claimed that mileage was not affected, and kept the same EPA numbers, but that sounds fishy to me.
    To be fair, some sticks force 1-4 shifts, I remember some Vipers and Vettes did that. And to counter them you did the same thing - mash the throttle, then it would let you find 2nd.
    So in both bases, and over-eager attempt to improve mileage in a lab might actually have hurt real-world mileage.
    re: 1-4 shifts.
    Or you ordered a little thingie from the Internet to take care of THAT problem on your Corvette!
    re: manual shifts and MPG. It's a matter of degree of control. The human brain can still make better decisions than anything electronic, or at least anything that is affordable enough to put into a car.
    re: have I become a politician? Fortunately for me, forums Hosts are not elected by the members. :P
    Sorry; didn't mean to call you a dirty name. :P
    I have a fuel-saving 5EAT, by that I means it loves to seek higher gears all the time.
    It falls flat when I approach a speed bump, though.
    Here's what happens, it's a 25mph speed limit, so I'm usually in 2nd or 3rd, I let off the gas to brake for the bump, and it inevitably shifts to 4th, the logic (can we call it that?) figuring I must not need any power, so let's save gas and find 4th gear at 25mph. Guess what happens next?
    Then, after the speed bump, hit the gas, and it's stuck in the wrong gear. 4th has to shift to 3rd then 2nd, but it's lose vacuum pressure and it hesitates before shifting. By the time it shifts it gets TOO much throttle and wastes fuel accelerating away from the 1st speed bump on the way to the 2nd speed bump.
    Rinse, repeat.
    Rinse, repeat.
    Rinse, repeat.
    Rinse, repeat.
    Yes, there are 5 speed bumps on my street.
    So by the time I make my very first turn, the transmission has made 5 gas-wasting mistakes and hesitated enough for gas prices to go up. It's bad enough that I take another route out of my neighborhood, one without speed bumps!
    With a stick I usually keep it in 2nd or 3rd, no shifting required. The throttle actually responds (go figure!) and I bet it uses less fuel in the process.
