Mystery car pix
11981992012032041474
  • kyfdxkyfdx Moderator Posts: 269,399
    '58 FireDome?
    Gee look at that gap in the trunk fit :P
    It's a bird! It's a plane! No, it's virgil on drugs!
  • jbolltjbollt Member Posts: 736
    That's the Euro market Volvo 480 (Turbo?).
    Were available late 80s iirc. Reminds me of that Isuzu Impulse from the 80s.
    Yes, 1988 Volvo 480T, 2dr hatchback actually... it's Canadian. And it DOES look like the Impulse! Or did the Impulse look like the Volvo?
    The site I got it from says it's a 1951 Series 62.
    You've been reading Straightline? :shades:
    Canada never had these Volvos for sale here.
    Do you mean the Impulse being Canadian?
    Opel Speedster, oops, I mean...
    Saturn Sky, oops, I mean...
    Daewoo G2X. :D
  • andys120andys120 Member Posts: 23,676
  • magnettemagnette Member Posts: 4,237
    What's really sad is there isn't a Vauxhall Speedster - ie the Opel will only be LHD....
    Well....I was refering to the Volvo. The web site I found the pix on was Volvo Club of British Columbia. I'm bad. I assumed it was Canadian from that. I was pretty sure they were never imported into the US. 50 lashes with a wet noodle for me! ;) Thanks for the correction, boomcheck!
    No, no problem. I have a feeling it's a grey import as anything 15 years old or older can be imported here from overseas without too much red tape.
    But I know for a fact these Volvos were never sold here as new.
    Now I have to correct you on my name: boomchek (without the c) :P :P
    That's just odd looking.
    The logo looks a bit like Mazda's.
    Nope not a Mazda, it's the new 2008 Kia Activon, coming soon to a dealer to you. I'm guessing it'll be close to the Mazda in size.
    You should be able to come close, look at that color :P
    1971, year of the dog vomit color chart?
    :confuse: It's a Ssangyong Actyon pickup derivative, basically a CUV with a truck bed (think Ridgeline).
    http://www.globalautoindex.com/news.plt?no=1451
    What an ugly looking truck from the front!
    "...(without the c)..."
    Ouch! I stand corrected yet again. :blush: Sorry boomchek
    You are right Bumpy, I stand corrected.
    Oh my, they shouldn't put any front view photos in the brochures. Keep the press from seeing that angle! :D
    wow..lets see, front wheel drive , transverse mounted, V6, throttle body (or carburator), ...looks to me like a GM, perhaps Oldsmobile, due to color or valve cover...
    I'll guess late 80s Olds Ciera probably V6 3.3L? From the snow country.
    maybe mid 80s?
  • texasestexases Member Posts: 11,161
    Did the 3.3 come from the 3.8 Pontiac? Looks like a 90-degree V...
    I don't think so. Didn't the 3.3l start out as a 2.8l, then 3.1l, then 3.3l?
    How about this: they did make a 3.0l version of the 3.8 with a carb early '80s for the Cutlass Ciera, etc. How close is that?
    I have no idea, to be honest.
    All I do know is that the 3.8l had a reputation for being robust, reliable, and torquey.
    The 3.1l and derivates had all sorts of issues with them. :sick:
    First year of the Ciera was 1987, and the available V6s were 2.8L or 3.8L. By 1989, the 3.8 was replaced by the 3.3L
    Per Wikipedia:
    "A small 3.0 L version was produced for GM's 1980s front-wheel drive cars. Introduced in 1982, it was a lower deck version of the 3.8 designed for transverse application in the new GM A platform cars like the Buick Century and Oldsmobile Cutlass Ciera. It shared the same bore size as its larger sibling, but featured a smaller stroke of 2.66 in (67.56 mm). Introduced with a 2-bbl carburetor, it later received multiport fuel injection."
    hmm...the X cars (Citation, Omega, Skylark, Phoenix released in 1979, as 1980 models) were the forerunnners of the A bodies. Now that I think about it, I think you're right. The Chevy Celebrity was around in 1982 or 3, so perhaps the Ciera, 6000, Century etc were also...I now wonder if that engine pictured is from one of the X cars, altho I think they only had the 60 degree V6 rather than the 90 degree engine, which would be the 3.8L and derivatives...and it appears to me that the picture shows a 90 degree engine, of course I could be all wet. I'm thinking the 60 degree was the 2.8L, and 3.1L, the 90 was 3.0L 3.3L and 3.8L.
    I know that the A body's had electronic throttle body injection at some point.
    OH! They also has the 4.3 L diesel!!! I bet that is what it is!
    I guess I still think the car pictured is an Olds with the 4.3L Diesel engine. Perhaps my earlier guess of "late 80's" is too late, perhaps 82 or 83?
    You know, the diesel idea sounds good - there's lots of odd things on that engine that were throwing me.
    I am convinced it is a diesel! 82-85 GM 4.3L diesel! The oil filler cap on the front valve cover proves it. See how tall it is? I believe it has a "breather" and filter in it, that was specific to the GM diesels of the era.
    bumpy, how did we do?
    Took a while, but y'all finally got it. It is the Oldsmobile 4.3L V6 diesel, transversely mounted to fit in the FWD Olds 98 for 1985.
    Sadly that was enough to make a trustworhty engine unreliable.
    My HS girl friend had one in college, I remember how it was "tuned" and ended up sounding like it was gargling. :D
    1969 Mercury Cougar Eliminator: "Mercury raised its performance profile with the introduction of the 1969 Mercury Cougar Eliminator. Taking its cue from such rivals as Z28 and SS Camaros, as well as Ford's own Boss 302 and Mach 1 Mustangs, Ford introduced the Eliminator in April 1969. Eliminator came with a range of engines, from the Trans Am-inspired solid-lifter 302-cid small block to the 428-cid Cobra Jet big block."
    Yep, and that's Mrs. Bond, played by the delectable Diana Rigg
    in On Her Majesty's Secret Service.
  • fintailfintail Member Posts: 58,668
    It's been too long since I've seen that one...but in the film I think they refer to the car as "The Big M" or something corny like that.
    Not much of a mystery, really.
    Skyline RB36 or whatever it is called. Big straight 6 turbo motor.
    That's a french car is called a Venturi. Company was formed in the 80s, it was called MVS at first, before switching the name to Venturi.
    It looks like a Ferrari F-355 without the side scoupes ;)
    Rocky
    RB26DETT. The biggest RB was the Australian RB30E.
    Here's a comparison review to the Lotus Esprit, including some good pics
    Venturi vs. Esprit
    Great stuff, thanks Tex.
  • chikoochikoo Member Posts: 3,008
