What is the difference between a 280SE, like the one which sold for $120K, and a 280SL? Is the SL a convertible?
The SE is a coupe or 4 seat convertible. Bigger car, I think on a different chassis
A 280SL roadster, on the other hand, is pretty wound up at freeway speeds and, some say, too feminine in concept for your average male car enthusiast. Dunno about that, but it's not the kind of car that would scare anybody.
I think you can get a nice coupe driver for less than half of that auction result. Must have been a nice car.
Which turbo did your Daytona have? The 146 hp version, or one of the more powerful ones? I had an '88 LeBaron turbo, with the 146 hp 2.2, and that sucker did have a bit of an urge to want to go sideways if you stomped on it from a standstill. Or, if you needed to make a sharp right turn, such as merging out into traffic, it seemed like it wanted to go straight.
My circle of friends at the time has quite the range of early to mid 80's American "muscle":
Dodge Daytona - Red
Ford Mustang GT - Red
Pontiac Sunbird Turbo - White
Ford EXP Turbo - Silver
Chevy Monte Carlo SS - Blue
Chevy Camaro IROC Z - Blue
and then the outliers:
Mazda RX-7 - Red
Cadillac Coupe Deville D'Elegance - Baby Blue
Guess which one was driven by a gold chain wearing, weight lifting guy named Carmine??
Supposedly, Lincoln made something like 2500 each of the blue and gold Diamond Jubilees, but it seems like the blue, which my friend owns, had a much better survival rate. I can't remember the last time I've even seen a gold one, but the blue ones seem relatively common.
It's definitely a cushy car, and comfortable once you're in it, but the seats are really low, and hard to get into and out of. Not much headroom either, although the sunroof might make it worse.
If I was going to drive one of these monsters on a regular basis, I think I'd go for an Eldorado or Toronado. While hardly poster children for space efficiency, they feel like they have a better driving position for me, and are easier to get into and out of. But as a collector car that I only have to drive on an occasional basis, I think the Mark V wins hands-down for style. It just seems sleek, smooth, and luxurious, but manages to avoid some of the pretentiousness and pimp of the Eldo/Toro. Something about the Mark V seems like it's built a bit better, too. Tighter, more even gaps and such. And the hood doesn't jiggle nearly as much. There's a little cowl shake going over bumps, but I've seen Eldorados with hoods that shimmy like a Jello mold in an earthquake while they're just sitting there, idling.
Still, I like both the Mark and the GM cars, in their own way. I wouldn't mind having one of those Toronado XS models, with the wraparound rear window.
car show where I've seen probably 5-10K vehicles during the last several years.
I believe I did see at least one in the wild in the day when they were being produced.
How many were built?
For 1978, it was renamed XSC, and sold 2453 units. My book doesn't list a base price for that year, but the Brougham coupe was $9412, and sold 22,362 units.
In 1977, the 403 used in the Toronado put out 200 hp, compared to 185 in other applications, so maybe that helped a little bit? For 1978, my book just lists the 403 at "185/190", but doesn't specify which hp was for what model. I dated a girl back in the 90's who drove a '78 or '79 Olds Ninety Eight sedan with the 403, and it seemed to be pretty quick, all things considered. Of course, a Toro would outweigh it by probably 400-500 lb.
My folks bought a new bright red '77 Impala coupe with that window in Nov. '76. I loved the wraparound window in profile, along with the notched quarter window. I didn't like it so much from straight-on from the back, as the sides of the car weren't very curved and it looked a bit awkward from that angle. Still, I could still really like a Caprice coupe with 350, F-41 suspension, and the scooped-out plastic fake spoke wheelcovers.
The 403 was a bit of an unfortunate engine. It had a few design compromises that allowed the Olds engineers to get that much displacement out of a small-block, and suffered with emissions controls. I had a 403 in my '79 Park Avenue and it was crippled with a 2.4 rear axle. It felt no quicker - maybe slower - than my '78 Delta 88 with a 350 Rocket, which had less weight and a 2.78 rear axle. I guess the TH400 in the Buick sucked up more power than the TH350 in the Delta as well.
I have an old toy one:
I like those "sport coupes" with the similar rear window too, interesting design.
I drove a 1979 Bonneville with a Buick 350 once, that a local guy was looking to get rid of. I was disappointed when I drove it, as my Grandmother's '85 LeSabre, with its Olds 307, felt quicker. My guess is that it probably was, as the LeSabre was a bit lighter, and had a quicker 2.73 axle, whereas this Bonneville most likely had the 2.41. Plus, by 1985 it seemed like they were getting a better handle on emissions controls, and the rudimentary computer systems worked fairly well, so even if HP numbers weren't all that impressive, I think they were getting better use out of that power...less stalling, sputtering, strangling, etc. I think first gear might have been a bit quicker as well. I think the THM200-R4 had a 2.74:1 first gear, whereas the THM350 was either 2.48 or 2.52?
I ask because one of my roommates once got a ticket for going 126 (mph, not kph) in his 280 SL. Yes, Pagoda 280 SL.
Regency, though it ran nicely, always seemed to be not as perky as the LS.
I didn't say they were slow, only that they were geared very low, to enhance low end performance. But if you wanted to run at redline, that engine could take it.
I've had my fintail up to 100 once. It gets up to 80 quickly enough, but it takes time to gain speed after that. That same day, a transmission cooling line broke - so no more high speed runs for me. The car is happy loafing along at 50-65 or so. As Shifty mentions, the revs climb pretty sharply with speed, especially in my automatic 220SE.
http://hartford.craigslist.org/cto/5298855412.html
The Merc's I think I see the least at old car shows are 57-60 for whatever reason. Too bad, because often they were more differentiated from the Ford in those years.
and I'll see Geo Metro's frequently. Haven't seen one for a while. A car repair shop used to have 3 that it put on a driveup display ramp in front of their shop with Christmas lights on them. I don't know if I can find a picture of they--they were emulating a series of sleighs connected.
Local physics teacher had one that was a 1989 and 1990 models: depended on whether you looked at the front half or the rear half.
I'm not sure about the whitewalls though. I have an old American Standard catalog of Chrysler packed away somewhere, and I want to say that even on my '57 Firedome, with its base price of $3085, whitewalls were still an option.
Whitewalls might have been one of those things where even though they were optional, on some nicer models, the dealers all ordered them with whitewalls, so if you wanted blackwalls you had to special order?
