Visitor Agreement.
You are right on this one - it is from South America. Also with the US connection. I'm sorry it is such a small picture.
Found it.
Willys Aero - Brazil.
if you ever need a good picture of a particular model, Wikipedia is a good source.
RE: "The Cord Look"--- in car design, there's a fine line between "got it" and "missed it", and this Triumph missed it. It is bulbous, high-shouldered and with very awkward headlamp placement----everything the Cord is not.
Originally in December 1903 the county of Stirling was given a code for locally registered cars - it was MS - and they issued plates for cars, motorbikes lorries etc from MS 1 through to MS 9999 which they reached in November 1930 - as they had then used all those codes they were given a further letter code - which was WG - which they used from WG 1 to 9999 and that took them to 1943. (It was two letters and up to four numerals)
Then they went to the next series (there were no spare two letter codes by then as places like London had gone through theirs at such a rate that the two letters were pretty much all allocated by 1933.
Anyway, Stirling ran out of two letter codes in 1943 and issued AMS 1 then but don't reach 999 until September 1946. (with three letters they only went to 999) The next code would have been AWG 1 to 999 which was used up by June 1947. Hence BMS came along.
Stirling never issued huge numbers and only got to XWG 1-999 by 1964 when we started getting seven character codes (i.e. AMS 999 B with the last B showing the year - 1964-) so never reversed their plates (i.e. 1 - 999 AMS etc..) but most councils in busy parts of Britain ran though both series - indeed some even reversed their original two or even one code letter series so in Hertford they had AR1-9999 in 1903 for a few years, went through a whole load of other two letter codes by 1934 and then through their two letter codes with a third letter by 1956, when they reversed it all, so AAR 1 came in 1934, but 1 AAR was in 1956...
They even reissued the two letter codes in 1959-63 (hence 1-9999AR) before moving to year letters (B ) in1964... i.e. AAR 123 B...
People knew which letters were their local ones in more rural parts of Britain and in smaller towns - I grew up in South Wales and our codes were NY, TG and TX for Glamorgan, with Cardiff nearby having BO, KG and UH - you just knew them as local codes...
Probably a bit too much elaboration but there is a system to it - although loads of plates have switched cars of course ( especially when people didn't want to advertise they didn't have a new car any more) so it is less reliable now...
Colorado used to do the same thing. Plates are issues by the county government, and you could tell which county based on the lettering.
For example, the letter "K" at the beginning of the plate code meant the plate was issued in El Paso County (city of Colorado Springs, mainly).
But our plates can be registered on the car forever - once on there unless someone chooses to change for a personalised plate or the car is written off, then the plate stays with it- even if you move from Glasgow to London ...
Interestingly the manufacturer was the Swallow Coachbuilding Co which had originally been part of Swallow Sidecars - the company that was the foundation for SS cars, later Jaguar.
I don't know about the 206 - not sure it had a removable roof option- but if it is the more common 246 then I think the model name was Dino 246S for this version.
Like Magnette I don't think there was a Spider version of the 206.
Jag in front. And I like the Alfa behind it.
The blue car is a late 50s Jaguar XK-150, perhaps the least desirable of the XK series. OTOH the white Alfa is the hugely desirable Giulietta Spider from the same era. Let's hope that plastic comes off soon.
Yes it's a XK-150. It's about neck and neck on value with the XK140, these days. The model with the 3.8 engine adds extra desirability. I'm sure some Jaguar diehards of the era were appalled at the idea of roll up windows!
Here's a tougher one:
The 107s are probably the least valuable cars in that storage area.
