-June 2024 Special Lease Deals-
I had a used '67 Impala with the powerful 283 CID, V8 engine as my second car that got the "fix" before I got it around 1974.
GM's "fix" for the broken engine mounts was not to replace the broken engine mounts but merely mount a bracket on each side of the engine (maybe it was the intake manifold but that is not important) and install a wire rope around a removable pin, held in place by a carter pin on this bracket, and loop it around the top of the upper control arm bolt/rod and back to the pin on the bracket. Wala it was "fixed"
It worked because, if the engine mount broke even if it wasn't broke at the time of the recall, the wire rope prevented the engine from moving too far. I can't remember all the scenarios but depending on which side had the broken engine mount, different problems occurred, like causing throttle linkage binding, gear shift locking in a position that you did not want it to lock in, pulling off the vacuum hose from the boost unit mounted on the firewall, etc.
I think there was well over 5 million cars affected by this recall. My car had a broken engine mount on the driver's side but not on the passenger side and that one never broke.
This "fix" saved GM a bundle compared to replacing both engine mounts and the labor to do it. A Chevy mechanic told me the cost for the "fix" didn't even cost GM $5 for both sides and the labor took less than 45 minutes to do both sides. Compare that to 2 engine mounts at about $20 each and at least 2 hours to install both of them.
Here is a pic of the bracket on the engine. It does not show the connection to the upper control arm so you'll have to trust me that it was done the way I explained it.
If @isellhondas (not the imposter 4 guy) is still around I'll bet he remembers this. Maybe even @Mr_Shiftright and @imidazol97 remember this too.
I was was surprised by this so I tried to recreate the same action and to my surprise, the audio changed to yet another selection. I figured out after owning and driving my car for 2-1/2 months that I have a "touch sensitive screen"!
I wonder why they put in a "mouse" type device on my console to select options and choices and settings and also make the main screen touch sensitive as well. Why have both? Also, most settings and options can be done via voice control. I do not like touch screens in a car because of possibly scratching the screen and putting fingerprints all over it. So I will continue using the mouse controller and avoid touching the screen. Strange engineering and redundancy.
2021 Genesis G90
Nice car. Have fun with it.
It was the work of an evil genius, really. I'm mean....just take this in:
When the engine mount broke, the engine would fall to the side.
This in turn pulled the throttle linkage all the way open
(wait, it gets better)
At the same time, the falling engine yanked the vacuum hose off the power brake booster
(wait, not done yet)
In some cases, if the engine fell down far enough, it would rest on the car's steering arm and jam it.
So there you are---wide open throttle, no brakes and no steering.
Doesn't it sound like some crime story where the wife hires someone to bump off her husband and "make it look like an accident"....
Mike, welcome to the world of up-scale cars.
My '15 Genny has that too. The Ultimate package gives you the wheel too (really you have to pay for it but you know what I mean). Otherwise it's only touch screen.
Like you, I don't like to finger print my display but to show off for passengers I can't resist, I do it both ways. When I'm by myself I only use the wheel.
Man, am I a wannabe guy or what?
Very nice.
Beautiful car and color combo (I have the same), @graphicguy! BTW, do you have beige carpets with black mats or black carpeting? Can't tell.
2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
If I had GG's Cadillac problem I would make their life miserable. I'd pass out flyers to prospective customers, I'd be getting publicity on TV and radio and in newspapers as well as websites. I'd tell my story to 60 Minutes, I think people would love to hear about it. I don't have to lie about it, just the facts would be enough to scare any customers away.
I would be after the AGs office in Ohio and the National Safety Council. If someone makes my life miserable I won't rest until I cause them twice as much trouble as they cause me. But, usually I am just a quiet easy going person.
What's with the "wannabe" stuff? A Genesis is no slouch of a car. I drove a 2017 before making my decision in December. It's a great car with all the goodies one would want in a luxury car. It's not a cheap car, either - the one I drove was about $55,000 - pretty close to the cost of a MB E Class or a BMW 5 series - but in comparison it was much more car with a lot more for the money.
I just was not comfortable in the driver's seat. Since my surgery, it is quite painful getting in and out of most cars and painful sitting in most cars for more than an hour.
Wannabe - phooey - you're already a star - what else can be said about jmonroe?
2021 Genesis G90
2021 Genesis G90
He just wants to be another star around here.
and today, I gave voice commands to the car for the first time in ages. Managed to actually call home successfully!
gorgeous. Same color combo I had on my 09 Genesis.
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
I had my son's bedroom furniture delivered a couple days ago. Bought a very nice set from Macy's. Was about $400 more, but the quality far surpasses that of Ashley furniture.
Ashley was calling about 6 times a day to deliver their furniture that I canceled...or tried to about 4 times. They still have my phone number, and wifes, on block. Used my son's phone to call. Got thru. Again said there is no record of furniture being delivered, but they still havent credited my credit card with the purchase amount. Hopefully they dont try to deliver that furniture when my son is home alone...may end up with 2 sets of furniture.
edited: Well, it looks like the ole Jipster has emerged victoriously. I wont be needing the Jmonroe left hook after all. Just checked my credit card transactions, and Ashley furniture has credited my account in full, NO cancellation fee!
I replaced the motor mount.
2020 Ascent Limited, 2024 Subaru Legacy Sport
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
Way to go getting revenge on Ashleys, you outfoxed them by not accepting the order, manager might have been bluffing about restocking fee and thought he could slip an order through. Who says revenge isn't fun?
2013 LX 570 2016 LS 460
Glad it worked out.
He just wants to be another star around here.jmonroe
There is only one star, and it is all yours good buddy.
2024 Ram 1500 Longhorn, 2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2000 Pontiac Trans Am WS6
Who are they trying to fool?
A retired older couple return to a Mercedes dealership where the salesman has just sold the car they were interested in to a beautiful blonde in a mini skirt and halter top.
The old man was visibly upset. He spoke to the salesman sharply. "Young man, I thought you said you would hold that car till we raised the $55,000 asking price," said the older man. "Yet I just heard you closed the deal for $45,000 to the lovely young lady there."
"And if I remember right, you had insisted there was no way you could discount this model."
The salesman took a deep breath, cleared his throat and reached for a large glass of water. "Well, what can I tell you? She had the cash ready, didn't need any financing help, and, Sir, just look at her, how could I resist?", replied the grinning salesman sheepishly.
Just then the young woman approached the senior couple and gave the car keys to the old man... "There you go," she said. "I told you I could get him to lower
the price... see you later, Dad."
I didn't realize it was a 3-pedal GG. I must have missed that in all the posts and pictures. I like it even more now, if that's possible.
2021 Genesis G90
2021 Genesis G90
Driver....I tried to go the Attorney General route you suggested, but they said to exhaust the BBB avenue and then come back to them.
Now that GM has told the dealership to take the loaner car back (they feel punitive actions are going to make me rethink holding them to the lemon law....wrong), that's a prelude to seeing how far I'll go to hold them to their warranty agreement.
Sad to hear that nothing has changed with GM since the '60s and the story you guys relayed about the engine mounts.
2021 Genesis G90
2021 Genesis G90
2021 Genesis G90
2021 Genesis G90
Thanks for the pics, actually aside from the front not a bad looking vehicle.
2021 Genesis G90
I get the impression it is for people who have lots of dough, but make it want to appear they don't have lots of dough, so people will think they have even more dough since they are keeping their dough low profile.....if you know what I mean.
