Visitor Agreement.
You have to figure you got your use out of the old one.....patch work fixing seldom works. As others pointed out....a new one will help in selling the place.
2013 LX 570 2016 LS 460
Hey, everyone into the pool!
Yeah, this is what I'm thinking too. My guess is that the TLX is good for probably at least 150,000 miles of good driving as long as the maintenance is done. Youtube Acura guy Tyson Hugie already has over 220k on his ILX with just regular maintenance. I think the only thing he's had to replace was the starter motor at c. 190k.
A/C is very efficient, but was pretty finicky for the first couple of years(froze up) until they got the refrigerant right.
Replacing it will help you sell the house, or at least not be something you'll get dinged for.
We used to average 1200 to 1400 KW for Jun/Jul/Aug. Now 850 to 1000.
Ok but do they have singalongs?
In the first one that only happens in the Mediterranean during storm season which you should avoid.
In the second one that young lady jumped in the pool....rather take my chances joining her than getting norovirus.
A newer mid level and up unit should have a much higher efficiency.
I replaced inside fan motor. $500
I replaced outside unit motor $200?
I replaced inside regulator valve $400?
Then later the outside regulator valve was needing replaced.
I was a slow learner. I should have just replaced the whole system when
the inside fan went after 12 or 14 years.
It wouldn't come on. I assumed it has lost freon but it was working nicely last fall when
I had it while he flew somewhere on business. So I thought there may have been some
trauma to the evaporator coil or something causing a leak.
Tech spent time. When I switched on unit the car seemed to know the controls
inside was asking for AC, because the engine speed and tone changed slightly with
the richer mixture. But no radiator cooling fans came on. No compressor came
on with the usual click.
Bad compressor. $1200 for replacement and filter and flushing the lines to remove
detritus from the internal failure. The compressor was likely leaking freon.
Sad day.
Truly appreciating that series again as I watch the episodes with renewed interest.
Could losing control of a car have more to do with the driver's inabilities than the speed itself, or is that a myth?
I didn't claim I had the same stability at 140 MPH as at 4 MPH, but it'll take more than a rear bump to send me out of control. It isn't at the very limits of stability, is my argument. Not on the edge.
No, that can't be it. Rural vs. Urban area? Cell phone availability? Cost of gasoline? What are these vast differences where there are no similarities?
If high speeds were not safe, every race car driver would already be dead 100 times over by now. Sure, a few race car drivers are dead, but if high speeds were not safe, all of them would be dead by now. Every....single....one.
That's their story anyway.
I will probably test drive it tomorrow. I was hoping they would have got one in sooner. The 2021's will be out in 4 months, but I doubt they will change much.
They have 0% interest financing until June 1 if I decide to get it, and if I decide to finance it. I guess for 0% I would be foolish not to finance it. This is the dealer that always wants to steal your trade.
The main thing holding me back is the 3.6 liter, 6 cylinder engine in mine now. I sort of hate to give it up.
Legacy Touring XT.
Two things to make sure don’t bother you:
(1) The infotainment for the first MY is supposedly a bit glitchy sometimes. I didn’t notice it when I drove the new outback, but make sure you’re OK with it.
(2) The auto start-stop. It cannot be permanently disabled from the UI and requires several menu presses to disable every time you startup. This was new for the XT and not something that was on the 3.6 motors.
I've driven other cars with stop/start. I must be one of the few where it doesn't bother me.
Thanks for the heads up.
Only reason not to would be the difference in depreciation if you trade it in in a few years.
The radio control they changed too. there is a wheel the spins, or you can push left or right. on the TLX, L/R changes presets, and you spin the wheel to change volume. Super simple, and 1 place to touch. The RDX has the same exact wheel in the same spot. L/R for presets. But next to it is a toggle for volume. But, the wheel still spins, but I don't think it controls anything. So of course, in that car, I keep spinning the wheel to nowhere trying to change the volume!
Yes, picky little things that you can easily live with. But just seems that one reason to double up on a brand, is to get controls that are the same car to car!
OK I'll ignore the obvious differences such as driver training/licensing and traffic enforcement, both of which wouldn't fly here in the U.S. I'll touch on two other important differences that have a big impact. First is that the U.S. is far more car reliant than Germany, Germans have a lower auto ownership rate and on average drive about half the distance that we do here and are more reliant on public transportation even for long trips. So Americans are far more likely to make long trips by car, this results in the U.S. having more fatigued drivers. Fatigued drivers are more prone to be in accidents.
Another thing to consider is that Germany has a much higher population density than the U.S. (600 people per square mile vs 87). What this means is that the higher the population density the more numerous facilities to support that population including EMS and hospitals. Remember we have vast areas where the population density is in the single digits. Get into a serious accident in the middle of Nebraska and it might be a while till you get medical attention. In Germany you dont have to drive through large sparsely populated areas to get between population centers.
Now if you dont think driving faster is more dangerous tell me why does the unlimited speed sections of the autobahn have almost twice the fatality rate of the sections that have a speed limit.
Due to hurricane season, our Eastern Caribbean cruise became a Western Caribbean cruise; other than the reroute, weather was not a factor. So, instead of tourning Old San Juan and St. Maarten we spent a (long) day touring the Mayan ruins of Tulum (dock in Cozumel, water taxi to Playa del Carmen, bus to Tulum). Followed by a private lunch/beach outing (the lunch food was merely adequate; not really enough time to eat/swim). We did spend one day at Royal Carribbean's island in Haiti, with big BBQ lunch. And, one day at their new private island in the Bahamas (IIRC), that was definately a step up from Haiti. Here's a tip, on their Coco Cay island, the "half day" ticket for the water park starts at 11am and will save you $$$ vs. full day ticket.
For all our good intent, we did not run/walk the track around the deck. We did not go to the gym. We certainly did not say "no" to food. Yet, we each lost a pound or two; likely thanks to the size of the ship (walking) and using stairs vs. elevators.
However, with the new world order, the GF said it will be a long time before she boards a cruise ship again. Que lastima.
Ascent
Legacy
I guess everything will be clearer when I drive it today.
I get antsy every two to three years.
