Visitor Agreement.
We have a front door that is similar to this, a door with windows along the side s and on top.
Every winter, the door swells, and you have to really tug at it to open or close it.
It gets caught on the bottom.
I have screwed in the hinges and that works for a while, but then it loosens up.
Is there a final cure, or as one person told me, you can't fix the frame, you have to replace the whole thing?
Would you believe it’s a software problem? In a washing machine? Unreal.
Here is the service bulletin describing the problem and the fix. And the software update is available, for $77.50 (plus I’m sure taxes and shipping, might as well round off to $100). Which gives me some doubt about just buying a new washer.
It's more the Braves than the Mets.
If it opens and closes without binding after you tighten the hinge screws there isn’t enough would left in the door jam to hold the screws long enough for a permanent fix. Either stuff some wood slivers into the screw holes (golf tees work too but you have to drill pilot holes in the golf tees. By stuffing wood slivers in the holes, the screws will go into the spaces between the slivers so pilot holes are not necessary) or use longer screws that will go into the framing of the door (usually a 2x4) not just the jam of the door. This usually requires 2 1/2 inch long screws maybe even a 3 inch screw.
I’d try one longer screw in each hinge to see if it reaches the solid wood of the door framing. If that works use longer screws for all the hinge screws. Just make sure the flat head of the screws sit flat in the counter sink of the hinge. I’m pretty sure the screw size is #9 but take a screw to the store to get the right head size.
I’ll bill you later.
Forget what I said about longer screws. I looked at the pic and you can’t use longer screws because there is no framing at the hinge area. Framing is only at the sides where the side lights are. You have to stuff the jam with wood and do it that way.
I’m still going to bill you because stuffing the door jam with wood is a permanent fix, just not my preferred method but you don’t have a choice now.
Spotted on I295 in NJ on Monday. Plate cropped out to protect the owner from public ridicule.
And this is my own rebadge job on the Sprinter.
"Francisco Lindor is 7-for-43 over the last dozen games. Lindor is not alone with an average like that. Pete Alonso’s 10-for-45, and the DH duo of Daniel Vogelbach and Darin Ruf is a combined 3-for-37 in the last 12 games. Nobody on the Mets has a .300 average over that span. New York is averaging three runs per game over its last dozen contests, a span in which it’s batting .227 with a .293 on-base percentage and .652 OPS."
That doesn't begin to touch on the pitching, which in the last 3 games has allowed 23 runs to the Nats and Pirates.
I can't bear to watch.
In town?
In town?
No, but I could have been for suite tickets... lol
Like that doesn’t deserve public ridicule.
I thought jmoroe1 was going to say he would be happy to cut an inch off the bottom of the door so it won't rub anymore.
@ ab348 suggestion sounds good too. We'll give them a try.
I think maybe Bob Vila or Norm Abram said to remove the screws from the offending hinge, stuff some wooden toothpicks in the hole with some wood glue and let it dry. Reinstall the screws and it should be good.
I would have waved.
I did manage to find 15 to go. The other 4 were SRO tickets anyway.
They just sent a picture of the kids that went. They said there is a big buffet set up and Pirate hats for everyone. I guess that's where Bob Nutting is spending his money.
The tickets were for our Miracle League. The Pirates are very good to us.
I would have waved.
I remember being in the Federal Building occasionally and watching the progress on (former) Heinz Field and PNC Park. Long time ago now.
Tooth picks work but you’ll need a box of them for all the hinge holes. I like to use a wood shim and use a chisel to split a few pieces from it and insert much larger pieces of wood compared to puny tooth picks.
The idea is to get some wood in there to hold the screws.
Plan B: Try hitting it with a hammer.
If those don't work, amortize the cost of buying a new one and justify it to yourself that it will end up costing you less money and frustration in the end.
Premier trim has 2.0 turbo and 9 speed automatic. All others are 1.5 turbo and CVT.
It’s worth noting that most recent turbos are low boost at low rpm, which makes a nicer torque curve than the older peaky turbos that had to spool up.
So, you liked it that much.
I bought a couple of 12 volt car tire pumps after @driver100 had mentioned them here long ago.
I gave one to son and DIL. He used it about 3 times over 1.5 years. It failed and that fit the pattern of
reviews for that pump on the amazon descriptions. I went to the purchase link on my amazon. It had a different button there that linked you to the manufacturer for support. Hmmm. I figured the company had been "banned" from amazon over bad merchandise.
I wrote a comment on page provided for Audew in Hong Kong. Got response of "it's been more than few months. No support. Hope you understand."
So I thought I'd respond that it had been used only a few times. Got response that they would either send product which would take a long time or refund.
Then next day response to my choice of a refund was amazon link "wouldn't let them refund after 3 months." Hmmm. Banned from amazon? And told me to contact amazon and "ask amazon to see how they could do refund.
Amazon of course had nothing to help after getting past language barrier and a third agent -- using chat, no less.
I responded to Audew to just send a product. I'd wait.
Today response was that "product not available. I should try further with amazon." So my response was to just send a similar product--since they still are peddling their wares on Walmart, that should be easy to do--
OR I suggested just send a check in US funds to my address.
What will be their response tomorrow morning? Have I played them along for enough time? Have I gotten my money's worth out of stringing them while they think they're stringing me? I expected to get $0 or no replacement pump. So I'm out nothing.
I take no responsibility for something I suggested on amazon.
Walmart might not be better, you are dealing with independent dealers...W-Mart won't take responsibility unless it is actually from them.
If I buy something on amazon I only buy 4 or 5 star items with decent reviews.....there will always be lemons.
The government did a check on Dollar Stores here, they found a large percentage (25%) of items had things in them that shouldn't be there....like lead etc.
These days....buyer beware, and there will always be lemons.
For example: One in four of the products tested were positive for substances managed under the Canadian Environmental Protection Act. Many of the findings were within the allowable limits, but the report says those limits are not strong enough.
The outer ring on a set of stereo headphones was found to have 24 times the legal limit of lead, and five times the legal limit of cadmium.
https://www.ctvnews.ca/health/toxic-chemicals-commonly-found-in-dollar-store-items-testing-shows-1.6050206
@roadburner , what happened to the “old man car” confession? Did I miss it?
Got my car back last night….before and after pics…..
Apparently, no filler needed. They just heated the bumper cover, it popped in place. They sanded the scratches smooth, painted, cleared and voila….like new. They did a great job. Body shop manager said they have a photo machine that matches paint mixes exactly once it “sees” the paint that’s already on the car. But, it wasn’t an issue on mine since the paint is so new. Plus, clear coats now have UV protection, so fading is less of an issue.
He said they used factory paint, too.
Paint and repair guaranteed for as long as I own the car.
Final total? $585. Do I wish I didn’t have to spend $585? Absolutely. But, it could have been worse. Very pleased.
Where did you learn to photoshop pics like that?
Sometimes you make out. It’s nice when you’re the windshield and not the bug.
Jmonroe
When I went down to get sparkle I remembered that I threw out all the old open stuff when we moved. So had none. So at 9 PM I’m down at lowes restocking my paint supply shelf and buying a gallon of paint. Then home to sparkle them all in. Thankfully it dried nice so when I sanded this morning most were ready to paint. Had a few needing a second hit of sparkle so that’s drying now. Then paint before dinner. Hopefully just 1 coat, since it is a closet!
And man, I hate repairing drywall and doing sparkle. Though I spent a lot extra for the fancy stuff this time, and it really did work good!
I had to repair the wall in the basement bath this morning. Kids got something on the wall. I scrubbed too hard and made a mess. Skim coat of patch then I’ll lightly sand and touch up the paint.
Glad that you got it all in place.
I let it go b/c of the long weekend but when there was still radio silence yesterday I contacted him. His response was "check your spam filter because a lot of my customers say that's where my emails end up." Sure enough, there it was. Why he didn't mention that at the time is a mystery, but whatever.
The repairs are worth $2200 +/-. The good news is that he sent it off the the insurer and the repairs are approved, so he is booking the car to come in next week for an 11-day repair (why so long I do not know but I'm not going to push it). The bad news is that the response from the insurance co. is that I have to pay a $500 deductible. Huh? I asked him about that and he thought it was strange b/c I was the one who got hit. He said that when he saw that response from the company he reached out to the adjuster b/c he thought she made an error, but got no response. I told him to go ahead and book it anyway and that I would go to work on them.
I then sent a polite email to the adjuster on the subject. I have had zero contact or communication with this person since all this started, not one word. As of this moment, still none. Grrr. Things are starting to rumble inside. Add to that similar radio silence from the bridge authorities who probably have video footage of the incident but seem reluctant to even speak to anyone about providing it. Double grrr.
