Thanks for all the input. Can always count on this bunch. Now if someone can fix my back I tweaked overdoing it yesterday. Having that out will be a huge issues.
I need to check to plugs on the back of the tv but having Bluetooth would certainly simplify things. I did not get the most expensive (ok, it’s probably near the bottom of the line) TV but it’s only 2 years old so just have the normal stuff. Will probably stick with Samsung just to be safe.
If you are just looking for better sound than your TV speakers, then a cheaper sound bar is perfect. Make sure it has a wireless subwoofer. If you want to play music through it, then that's another story.
Read reviews, and pay a lot of attention to connectivity issues. Avoid those models
I was surprised when you said the 2009 P.T. Cruiser had a rusted out gas tank. There are much older cars around that don't have a rusted gas tank.
That was one of the many reason that I came to hate that car.
Quick search of internet suggests even though the HDMI ARC is in a group labeled as IN, ARC will send sound to a sound bar.
So I'll look for a soundbar that has HDMI ARC and/or optical video digital connection.
I need just a clearer output at a slightly high volume capability. The fact that the TV is in a large wooden box with an open back for the old style cathode ray tube TV makes its sound muddled compared to being flat against a reflective wall. And I don't hear as well as I used to.
Amazon returns are great if I don't like or can't use the one I pick, but I hate trying to decipher the junk indicators in the descriptions. They're like misleading news where they puff up some things and overlook telling about others that might be negatives.
I get the feeling lots of Samsungs are Bluetooth ready. I had to buy a 40 inch tv from 2019 era to fit the cabinet, but two of the 43 inch samsungs on BestBuy's specifications say they're Bluetooth enabled.
This is like picking a new car to purchase.
Except it’s like the new car information was written in Greek.😢
I had some pretty crappy cars in my time. That included a 1960 Austin Sprite that used more oil than gas, and 1973 Comet with 3 on the tree.....slow and boring.
Some reported a leaking gas tank, that isn't the same as rusted out. Chrysler must have used paper thin metal to make Neons and PT Cruisers.
That, plus the fact that they could get a V6 Sonata for the price of a 4-cyl Camry, sealed the deal.
22 years later, my sister is using it as a spare car - I think it has around 60,000 miles on it.
That’s because you don’t have to drive junk like I did. The PT was particularly disappointing since it had less than 50k miles on it at the time. At least with the pickup I knew it was junk when I bought it as a donor vehicle to fix my other F-150.
Back around 1990, my dad bought a 60 Ford Country Sedan that was pretty well preserved, as it had sat idle for some time. Apparently the fuel tank rusted inside - I remember once he got the car on the road, the fuel filter would clog in almost no time. He removed the tank, drained it, and put some kind of treatment in it which I think resulted in a new interior coating. It was fine after that.
That car was solid save for the passenger front floor, which I called the "Flintstone floor" - it had a leaky heater core when parked, and I think that might have contributed to the decay. He patched that too, although not to factory spec - I don't believe replacement floors were available then, so he kind of made his own passenger pan out of what seemed like thin sheet steel.
I’m late to the party on this but here’s my input:
I have a Samsung TV and I’m very pleased with it so I bought a Samsung sound bar maybe 5 or 6 years ago. Got it at Best Buy on sale for about 250 bucks. It’s not wireless except for the sub woofer and it’s connected to the TV with an HDMI cable using the ARC input/output connections. When I bought it I remember the salesman saying he thought it was a pretty good one. I agree, it’s pretty good but the remote is terrible. To turn it on you have to be very deliberate where you aim it. It’s not the batteries. I’ve changed them several times and with several different brands. I’ll put up with that because I like the sound. The remote for the TV works much better. I can point that remote at the ceiling and it will turn on the TV.
Early Sonatas were a bargain because Hyundai had to rebuild their reputation after the Pony disaster.
That car is still a baby at 60K miles.
J - hooked up through ARC you shouldn’t even need the soundbar remote. Mine turns on/off when it detects audio from the TV.
I do agree though .. the Samsung soundbar remote does stink
*While the price point of a Prius battery seems overwhelming, there may be a great deal of solace in the fact that hybrid batteries can last as long as 8 to 15 years or anywhere between 100,000-150,000 miles before having to replace their battery.
I'm no mathematician but that sounds like it could cost more than driving a straight ICER.
I checked because the guy on the radio said he had to replace his hybrid battery in his Ford (I believe he said Escape) that had 90000 miles on it and the battery cost $12000 Cdn...or about $9000 USD.
Most new sound bars have bluetooth, but very few TVs do. The bluetooth on the sound bar is mostly so you can play music through your phone.
In other words, forget bluetooth, unless you are streaming Apple Music or Spotify. It's irrelevant.
Every sound bar I've seen has both ARC HDMI and optical.
Both my Samsungs and Sony have BT built in. Sometimes I’ll connect my Sony to our whole house audio via BT.
We've probably spent 200% of the value of the vehicle in the last few years, taking care of various maintenance and service odds and ends. Runs like a top, very comfortable and my sister replaced the head unit with one that includes Apple CarPlay.
The only thing it doesn't do well is get good MPG. The thirsty V6 and the 4 speed automatic means mileage in the teens or low 20's, even on the highway.
It is still a good looking car and it has been a great value. Consider the years of use and the initial price, even with money put into it the car probably costs less than $1500 a year to maintain and own. The gas mileage is a moot point at that rate.
My friend got new hearing aids. He can watch TV and the sound can come directly to his hearing aid.
Is that feature available on all new TVs?
How do you get your hearing aid to pick up the sound.
His new hearing aids are rechargeable.....seems much better than replacing batteries I would think.
Have we ever discussed hearing aids before.
I think dad spent around $17K for the car initially. It's had a few sets of tires (replaced by age, not mileage), and regular maintenance is also time related, since it has so few miles on it.
The MPG does hurt as my sister lives in San Diego, where gas is pushing $4.50/gal.
I have perused hearing aids on Amazon, but didn't pay much attention to the TV connectivity aspect.
Rechargeable aids likely have a limited life due to deterioration of the batteries. 3 years? 5 years? Probably time for new ones.
Doesn't mention turning on and off with HDMI ARC signal or lack thereof. This model seems to hype their theater effects, while I just want to be able to control the spoken range better relative to the background.
https://www.amazon.com/dp/B0CWV8BBK1/?coliid=I1JABGDUEAQSRJ&colid=COCUTT72DO75&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
Without a subwoofer, I wouldn't bother.
Assuming you want a Samsung, to match the TV. As others have mentioned, you don't have to spend a lot, but you have to spend something.. $250 will get you all you need, and then some. No matter which brand.
Thats what we have too.
I’m confused. Isn’t the purpose of hearing aids to pick up sound? There’s nothing new about that. There has to be something you didn’t mention.
I'd guess the TV would have to have bluetooth. Some of the hearing aids I've studied have bluetooth connectivity from a phone app to adjust the levels of different frequency bands and other aspects.
Thanks for the info...I think he does use an app on his phone.
I understand the best place to get hearing aids is Costco, can cost 1/3rd less, and can be returned within 6 months if not satisfactory.
I use the LG TV remote to turn the TV on, volume is at about 60.
I use the cable remote to change channels.
Say the TV remote is at level 5 for sound, the cable remote might be at 60.
If I up the TV remote to 20, then the remote for the cable zapper can be lower, maybe 40.
The TV and soundbar in your case, don't work together, but they work inline with each other.
It's hard to explain, I shouldn't have tried - but that is what happens to me.
@jmonroe The sound goes directly to hearing aids from the TV...it doesn't go through the air in the room like TV sound goes without hearing aids.
It allows the wearer to turn up the volume in the hearing aid, while others can watch and listen to TV at the normal volume level they like to set it at.
1982 Grand Prix, bought used in ‘91, in northwest Indiana. Didn’t have it very long before I found a leak (might have been the first full tank.) My brother was basically an apprentice at a small shop, so it was only so much trouble to get it changed out. Finding a donor vehicle may have been the most difficult part.
What hearing aid model do you have? You seem to have been satisfied with yours.
So many people I know end up not wearing theirs because they don't like them.
I keep putting off getting them for myself--
I am at the point of needing them.
Happy Fourth Everyone!
Here are some fireworks shots from Otten’s Harbor in Wildwood NJ (at my neighbor’s place)
I M trying to find something tomorrow when I go to civilization. Apparently the new house is in. Serious dead zone. Which is odd since I am near some major commercial areas. It has been awful. As in old time dial up slow. Many sites just give up and stop trying. Too bad Verizon is not scheduled until the 12th to come out. I was planning to hot spot my work laptop off the phone but zero chance that will work. Right now I have 1 bar LTE. Sometimes I get 2.
Will look at Samsungs with hdmi a wireless sub and take. Look at that Klipsch.
And you all know food had to be involved. Sometime last year we did a seafood boil for our neighbors. They loved it so much they went all out and bought a metric ton of seafood and my wife led the way cooking it up for all of us and some other guests they had.
Amazing time
Took a full minute plus for that picture to load.
Finally a garage big enough for my workbench. Now have to get a basic one for the basement.
Got them at Costco in early 2020. $1800+tax. That’s about 1/3 the cost at an audiologist. They have a 3 year warranty. $270 for the new batteries, in January. They send them back to the manufacturer, and they also seem to replace any other parts that are worn, as well. And, a new 1-year warranty.
I was 61 when I got them. I didn’t want to wait until I was “too old” to adjust to something different. But, I knew I definitely needed them. My uncle started buying them after he turned 80…. and, could never adjust to them. Five pairs, and they all got returned. I didn’t want that to be me.
It’s made a big difference. Conversation, TV viewing, phone calls..
