Here's a 29 from my own collection...I know exactly where this was taken too, looks almost identical today (probably the same pavement)
I think this is the first car posted here that I would appraise as "worthless".
in Arizona; today I saw two-
-1960 Chevrolet 4-poster, low end, I think it was a 210, Blue roof over white, dog-dish hub covers. Some dings and not much luster to paint. It's amazing how tall these look in modern traffic.
-1966-ish Ford Fairlane H/T coupe, pale yellow. Didn't get a long enough look to check for engine badges etc. but looked like a decent unmolested original.
The car I saw had four taillights, a contrasting color on a side moulding and just looked low end with the four-poster body and dog dishes.
I don't know if it was a Biscayne or Bel Air
When the Impala became a full range for 1959, I'd always thought that Chevy just bumped the Delray and moved the Biscayne and Bel Air down a notch, but I don't think that was the case. I believe a '59 Biscayne was pretty much the same in status as a '58. And a '59 Bel Air was priced around the same as a '58, with the Impala coming in aorund $150 more, although the convertible and hardtop were priced around the same as their 1958 counterparts.
But, when you factor in inflation, maybe the fact that those prices stayed the same did mean that each model moved downscale a bit. Ford and Plymouth raised their prices that year
It's interesting that Chevy actually kept the Biscayne around through 1971. That year, the pricing was
$3,448 for a Biscayne 4-door sedan, 350 V-8
$3,585 for a Bel Air 4-door sedan, 350 V-8
$3,742 for an Impala 4-door sedan, 350 V-8
the Caprice was only offered as a hardtop coupe or sedan that year, but the hardtop sedan came in at $4134 compared to the Impala's $3813, so figure the Caprice carried a ~$320 premium over the Impala, so if a Caprice 4-door sedan had been offered thatyear, it would've run around $4062.
Now, I can see the difference between a Caprice and an Impala. The Caprice had a standard 400, versus a 350. And a nicer interior. But what, really, did an Impala give you over a Bel Air? I know the Impala had 3 taillights versus the Bel Air/Biscayne's 2. And the Impala had different seat patterns, and the vinyl portion of the door insert was different. but was there really $157 in difference there? I guess the Impala might have had full wheelcovers, and perhaps larger tires as well.
I wonder what they were doing by that time to differentiate the Biscayne from the Bel Air? $137 might not sound like a big difference, but adjusting for inflation, that's like $715-750 today...not exactly a small chunk of change.
My first car was a ragged out '70 Galaxie... no air, vinyl interior.. and a 302 V-8.
Speaking of six-cylinders, I knew of a '77 Pontiac up here that had the inline six under the hood. But that was a much smaller car than the preceding dinosaurs.
My memory slipped on the years for that. I should have associated the red stripe with Firestones Oval Tires.
I had Wide Oval tires. I didn't realize that name meant the roundness of the tire rather than the profile. They also didn't last very long. 1967 Mustang.
Was yours a GT? I had a '67 Cougar GT with the 390 (think it was rated at 335hp) and the rears wore out in about 6-7k as I recall. Course I had a lead foot back then......and I worked for Firestone (30 years) so replacements didn't cost much.
I traded it in on an '83 T'Bird Turbo Coupe.
I always liked how the "427" emblem on the '68 big Chevys had a red background instead of black, like all the other engine sizes had. I clearly remember that on a '68 Biscayne 427 cop car in my hometown.
In '71, the Biscayne and BelAir were virtually indistinguishable from the outside...only by nameplates. The Biscayne only had a woven vinyl interior and I'm pretty sure rubber on the floor. The BelAir had a standard cloth interior that had seat trim that was about on-par with what you got in Pontiac Catalinas up until that time, although with no woodgrain trim inside whatsoever.
The '71 Impala added three taillights on each side, wide rocker moldings the length of the car, roof drip moldings, door frame moldings, IMO much better standard cloth seat trim, soft vinyl upper door panels with woodgrain accents, and woodgrain accent on the instrument panel (right side).
It was a coupe with an option package that inclulded the recessed lights in faux hood scoops. 289 V8 with 3-speed manual. No AC. I also ordered the limited-slip differential which changed the 2.75 rear to a 3.00 ratio. It was quick llittle puppy.
Here's a 1978 Pontiac brochure from Canada. I notice it's showing a 3-tier lineup of full-sized cars: Laurentian, Catalina, and Parisienne. That probably equated to the Canadian Chevy lineup of Bel Air, Impala, Caprice.
The brochure also looks like it's listing Chevy engines...4.1 6-cyl, 5.0 V-8, 5.7 V-8. In the US, that would've been the 3.8 V-6 (Buick), 4.9 V-8 (Pontiac) 5.7 V-8 (Pontiac in most areas, Oldsmobile in California and similar areas), and 6.6L (Pontiac 400 in most areas, Olds 403 in Cali and similar areas)
Pontiac tended to be more of an equivalent to Chevrolet in Canada, rather than a step up, didn't it? I think every once in awhile they'd offer a US-spec Bonneville, but that was back in the 1960's, perhaps?
I wonder if it was really worth it to offer the Laurentian by this time? The car looks just like a Catalina to me, although inside, the seat looks like it's taxi/police car/fleet spec, and the door panel looks like an Impala door panel with the fake woodgrain removed.
Here's something I've always wondered...what were the full-sized 1982 Canadian Pontiacs like? In the US, the big Pontiac Catalina and Bonneville were dropped after 1981. And in mid-1983, we got the Parisienne, but it was really more like an Impala with slightly different taillights, a Pontiac grille designed to fit into a Chevy header panel, and even a Chevy dashboard, just with four round dials instead of four square ones.
So, were the big Canadian Pontiacs "real" Pontiacs like the 1981, or thinly disguised Chevies, like the 1983-86 Parisienne?
They had a Laurentian, Catalina, Parisienne Brougham, and Bonneville/Bonneville Brougham.
The Laurentian looks like it has the Bel Air door panel, and probably Bel Air-grade seats, but I'd guess still a Pontiac,rather than a Chevy dashboard. And for being the stripper, it's interesting that they offered the Laurentian as a 2-door hardtop. The Catalina looks like about the equivalent of the Catalina we had here in the US.
But then the Parisienne Brougham seems like an odd fit. It's trimmed nicer than a Catalina, yet the Catalina offered a bigger engine. Almost seems like they tried to take a Catalina and give you luxury similar to a bonneville, but then go ahead and offer the Bonneville anyway. If nothing else, the two offered different body styles....4-door sedan and hardtop coupe for the Parisienne, and 4-door hardtop and closed coupe for the Bonneville.
For reasons I do not fully understand, Pontiac was always a more significant part of the Canadian market than it was in the US, even into the recent last days of the brand. GM Canada and its dealers were hurt a lot by the decision to discontinue Pontiac, as it made decent volume for them. Traditionally, most Canadian GM dealers were either Chev/Olds or Pontiac/Buick/GMC pairings, with Cadillac a wild card that could go to either. When Pontiac disappeared those dealers had little left to sell.
GM Canada tended to make Pontiac mirror Chevy almost exactly until the late 60s in terms of engine/chassis -- the real Pontiac engines did not get offered here until the late 60s muscle cars showed up, and a "wide-track" Pontiac of the 60s wasn't wide track in Canada, because it had the Chevy chassis. It made some of the big Pontiacs look pretty crazy, with their front wheels inset into the body quite a bit. But in any event, your hypothesis is correct. In the 60s, Pontiac's full-size line in Canada looked like this from low-end Biscayne equivalent on up:
Strato Chief
Laurentian
Parisienne
Then in the mid-60s they introduced the Custom Sport 2+2, which was an upscale coupe that took some Grand Prix and Bonneville trim pieces but did not have the unique GP roofline.
During this same period we did not get the LeMans A-body, but Pontiac dealers instead sold the Beaumont, which was a Chevelle with a different grille and taillight treatment with Chevy drivetrains.
At some point - I want to say '69 or '70 but I may be wrong, it might have been later than that -- GM Canada began to introduce American Pontiac model names (at least, I dunno if they went with the entire design or just the model name) to the Canadian market. So at one point I'm pretty sure you could buy a Parisienne or a Catalina simultaneously in Canada.
It was all very confusing. I think it originally had something to do with import duties and the fact that it was easy for GM Canada to build a Pontiac body but not so easy to build Pontiac engines and chassis, and so prior to the auto pact of the mid-60s they avoided paying duties on importing those Pontiac components by substituting Chevy items.
I don't understand it either, nor do I understand why GM would go to the trouble of adapting Ponchos to use Chevy hardware. That would seem a big expense to serve a relatively small market (no offense).
Well in those days, Pontiac was usually considered more of an equivalent to Chevy, than a step up. Because the Canadian market was more thinly spread than the US market, they paired Chevy with Olds and Pontiac with Buick (or maybe it was Chevy-Buick and Pontiac-Olds, I can't remember now). Chevies were built in Canada, but Buicks and Oldsmobiles were imported, and slapped with steep tariffs. It would have been too cost-prohibitive to import the US spec Pontiacs, because while people would have been willing to pay a premium for a Buick or Olds, Pontiac just wasn't upscale enough. So most Canadian Pontiacs were built using Chevy frames and drivetrains, but with Pontiac interiors, dashboards, front-end clips, and sheetmetal. A Pontiac front clip and doors will bolt right to a Chevy body, as they're both the same B-body. the only difference is in the rear quarter panel. To use 1967 as an example, Chevy was on a 119" wb, while the Pontiac Catalina was on a 121" and the Executive/Bonneville were on a 124". All that length was added just ahead of the rear axle, which stretched out the rear deck and rear quarter panels, but had no bearing whatsover on the passenger cabin.
Ford did something similar to ensure wider brand coverage in Canada. All Ford dealers sold a Mercury-based model, and all Mercury dealers, I believe, sold a Ford-based model. One of them was called "Meteor", but I can't remember which one that was.
And Chrysler did weird things as well. For instance, I believe there was a call called the Chrysler Valiant, which was a Dodge Dart with a Valiant front-end clip (all the Dart's extra length was in the back seat area, so the clips were interchangable). And even more recently, I've seen Chrysler Intrepids.
but, I believe there were Dodges sold in Canada, as I recall a car called the Dodge Crusader in the late 50's, which was a Plymouth with Dodge trim. In 1957-59, Dodge/Plymouth front clips were interchangeable, as, once again, the extra 4 inches that punched a Dodge wheelbase from 118 to 122" were all in the back
Delray= 150
Biscayne = 210
Bel Air
Technically, the Impala was a "Bel Air Impala."
I believe I saw it or one like it at one of the Carlisle shows.
Looked nice though.
