2018 Range Rover (Full-Size) Lease Deals and Prices
124678
  • maxwell507maxwell507 Member Posts: 14
    Was doing some prelim shopping and was being pushed to a 42 month term by a couple dealers.  Is that a better time frame then 48 or 36?
    This is in CA on diesel full size HSE.
  • kyfdxkyfdx Moderator Posts: 271,942
    sushisean said:
    sushisean said:
    Are the LWB and SWB rates the same? I'm looking for the best lease term on an '18 Autobiography LWB. Window is $161k, getting $4k off. I'm debating between 84 month finance and a lease.
    Is it an SC or SV Autobiography?
    What term/mileage?
    SC Autobiography. I'm not sure what term or mileage I was seeking help determining what makes the most sense.
    .00221 MF and 53%/52% residual for SWB/LWB
    On a full-size RR, the longer terms will result in a lower payment.
    42 months isn't any better or worse than 48, just shorter, which is an advantage when it comes to leasing, generally.
  • sushiseansushisean Member Posts: 4
    What term/mileage?
    Ouch, that's the lowest residual I've seen you post for any 18 RR. Probably a sign of it being late in the model year so they're dropping it to prep for 19's? What's the rate and residual for 36/12?
    edited May 2018
    On a full-size RR, the longer terms will result in a lower payment. 42 months isn't any better or worse than 48, just shorter, which is an advantage when it comes to leasing, generally.
    Do you have the MF and RV for the longer terms.  42 and 48 at 12k?  In California for a RR full size TD6 HSE.
  • MichaellMichaell Moderator Posts: 268,246
    sushisean said:
    What term/mileage?
    Add 2% to the residual for 36/12
  • lsp1980lsp1980 Member Posts: 7
    Have the June #s come out yet?
    Yes
    lsp1980 said:
    Can you help with a lease payment on 2018 RR HSE - $105,835 - 36/12 & 36/15 - Sales Tax 7.75 - 15k down
    thanks in advance
    .00221 MF and 64%/62% residual for 12K/15K/yr
    $105835 MSRP
    $105835 Selling price
    I'm going to assume $3000 for DMV, acquisition and first payment, leaving $12K for CAP reduction
    $93835 adjusted CAP
    36/12: $1082 +tax
    36/15: $1136 +tax
    Be aware.. the CAP reduction reduces the payment, but it doesn't lower the residual/buyout amount.
    Can i get the lease #s with info above with June's figures?
    thanks!
    lsp1980 said:
    thanks in advance
    $105835 MSRP
    $93835 adjusted CAP
    36/12: $1082 +tax
    36/15: $1136 +tax
    thanks!
    .00221 and 62% / 60%
    sushisean said:
    What term/mileage?
    Thank you very much. What are the June numbers for 36/12 and 42/12 on an SC Autobiography LWB?
    lsp1980 said:
    thanks in advance
    $105835 MSRP
    $93835 adjusted CAP
    36/12: $1082 +tax
    36/15: $1136 +tax
    thanks!
    great and what would the lease look like for 36/12 36/15? Appreciate it
    sushisean said:
    sushisean said:
    What term/mileage?
    .00221 MF and 52%/46% residual for 36/42 months
    lsp1980 said:
    lsp1980 said:
    thanks in advance
    $105835 MSRP
    $93835 adjusted CAP
    36/12: $1082 +tax
    36/15: $1136 +tax
    thanks!
    The 2% lower residual will add $59/mo.+tax to either payment
  • afak0824afak0824 Member Posts: 1
    edited June 2018
    Hi in CA, looking for lease numbers on RR 5.0 SC SWB
    MSRP 115,080
    5k driveoff
    MSRP 115,080
    5k driveoff
    .00221 MF and 61% residual
  • theprezodenttheprezodent Member Posts: 1
    Hi!
    I am in TX and looking for lease numbers on 2018 RRS SVR
    MSRP 135,000 10K down 39 months and 12K miles and also 15K miles. Thx!
    Hi!
    .00178 and 48% for 39/15
    Add 2% for 12K
  • wbktwbktwbktwbkt Member Posts: 37
    edited June 2018
    Looking for residual and MF for 2018 RRS HSE and HSE Dynamic V6 for North Carolina. ANy help will be appreciated. 36 mo 10k
    Please post in the Range Rover Sport discussion, here:
    https://forums.edmunds.com/discussion/49853/land-rover/range-rover-sport/2018-range-rover-sport-lease-deals-and-prices#latest
  • nicole1234567nicole1234567 Member Posts: 4
    hi I'm looking to lease in ca, zip 93012
    these are the options given, any input will help, thanks!
    What is the MSRP?
    The first and third columns have the MF marked up by .00100 - base rate is .00221. We don't have 3rd party numbers, so can't help you with the middle column.
    And, we suggest you limit the out of pocket amount to just the first payment and DMV costs.
    the MSRP is $121,917
    We would be paying msrp, dealership said "there are not enough v8's on the ground to warrant a discount" but they would pay the shipping since the car is 300 miles away
    The money factor increase is adding $200/mo. to the payment.
    I guess it's fine to pay full MSRP for a vehicle, if you want it really bad, but the extra $7200 in finance charges for the money factor markup is just gouging.
    For another $100/mo, you could buy the car with a 60 month payment.
    thank you! Would you suggest emailing back asking for mf to be at base rate?
    Yeah.. if you are stuck on buying this car at MSRP, then that's what I would do. Or, just a simple, "That payment is 10% too high. We'd be happy to sign, if you use the buy rate money factor. Let me know."
    It helps to have alternatives in mind.
    Ok, I will.......thanks again this site has helped tremendously
  • aks0685aks0685 Member Posts: 29
    Can I have MF/Resi for an hse RR, 7500/year 39month. Is this the best term?
    What ZIP code?
    What ZIP code?
    Zip is 30319
    aks0685 said:
    What ZIP code?
    Zip is 30319
    .00221 MF and 64% residual for 36/7.5K
  • rkdiddyrkdiddy Member Posts: 50
    Looking for the 10k/36 Month for Dynamic Supercharged in So Cal for July. Thanks.
    I don't see a Dynamic for the full-sized Range Rover?
    If you want Sport, that discussion is here:
  • medacusmedacus Member Posts: 3
    Can I have the numbers for a TD6 diesel zip code 22102, lease 36/12. Thank you
    .00229 MF and 63% residual
  • mbnj2123mbnj2123 Member Posts: 92
    Hi, can you please post July numbers for the full size RR HSE Td6 as well as the SE td6 for 24 and 36 months at 7,500 and 10,000 a year? Thank you.
    HSE Diesel:
    24/10: .00273 MF and 71% residual
    36/10: .00171 MF and 61% residual
    SE Diesel:
    24/10: .00294 MF and 75% residual
    36/10: .00229 MF and 64% residual
    Add 1% for 7.5K/yr
  • nycrangeguynycrangeguy Member Posts: 1
    Hi I was hoping for some advice. I was quoted on a 36/10 lease for 18 HSE Td6 MF .00196 and 61% residual through Chase Bank. US Bank was substantially higher MF and lower residual. Which bank is offering .00171? Why is my dealer quoting different figures I am working with NJ dealer. Thank You
    Land Rover Financial (aka Chase)
    Dealer is allowed to mark up the MF for extra profit (and, most do)
  • lrrrs18lrrrs18 Member Posts: 2
    I'd like to find out if this is a good deal please.
    2018 Range Rover Sport Supercharged Dynamic
    MSRP $102,662
    Discount $2,000
    Cap Cost $100,662
    39 Month Lease, 10k miles/year
    52% Residual
    0.00196 Money Factor
    Drive off $5,000
    Payment $1612
    Sorry, I'm in California and that payment includes sales tax.
    MSRP $102,662
    Discount $2,000
    Cap Cost $100,662
    52% Residual
    Drive off $5,000
    Payment $1612
    Why put up $5000 on a lease?
    Not a great deal, but given how Land Rover dealers avoid discounting, it may be the best you can do.
  • duanebeduanebe Member Posts: 15
    Can you tell me what the rate and residual for a 2018 Land Rover Standard WP Supercharged 5.0 V8. 39 Months 10k
    .00229 MF and 60%/56% residual for 36/39 mo, 10K/yr
  • archiesheparchieshep Member Posts: 1
    Can you please tell me the MF and RV for 2018 Land Rover Range Rover V6 HSE
    for 39 months 10K
    and 48 months 10K.
    for 39 months 10K
    and 48 months 10K.
    .00189 and 57%
    .00208 and 51%
  • Pank11Pank11 Member Posts: 14
    Hello, I’m interested in a 2018 Range Rover SC MSRP 119,481.  With 2k off sticker what would the numbers and payment be with 5k drive away in 21029.  39 months 12k or 15k.......also is there a sweet spot in regards to term?  Thanks
    .00229 and 55% / 53%
    Why put $5K down on a lease?
    .00229 and 55% / 53% Why put $5K down on a lease?
    I certainly would hold on to my money if possible if I don’t have to I will not.  I just want to get a roundabout number before I go in and even entertain doing this.
    In MD, you pay sales tax on the full selling price of the vehicle.
    That will naturally favor a longer term, as the amount is amortized over more months.
    Your $5000 drive off wouldn't even cover the sales tax.. :p
    Let's assume $7K for tax
    $2000 for acquisition, dealer, DMV fees
    $1970/mo 1st payment.
    That's $11K in upfronts... subtract your $5K, and roll in the other $6K for an adjusted CAP of $123,481.
