Visitor Agreement.
$16K trade + $2K coupon would leave maybe $3-4K plus TTL (and tax wouldn't be all that much, what with the trade credit you'd get).
The only thing you'd lose is the stick shift.
Without a manual transmission available, I dunno if Mrs. driver would agree to give that up, unless she's been spoiled by her GLK.
If you don't have a trusted independent garage take it to the dealer. A few extra bucks won't kill you. As they said at 5500 miles there's not much else you'd need. Coolant change might be indicated seeing how long it just sits. Don't let them upsell you.
Do you really want a new car? That's not what I think you were asking but if you were and you can afford it go for it.
Here's WHY (as regards the coolant)
For the Brake Fluid, it should be checked a) for translucency and b) with a moisture test strip. That's how a pro would do it.
I have almost never changed brake fluid, so I looked it up. To make it shortL
Mercedes-Benz, for example, says brake fluid should be replaced every two years or 20,000 miles, and Volkswagen says that should be done on most of its models every two years regardless of mileage. Subaru recommends fresh brake fluid every 30,000 miles.
More Car Maintenance Coverage
On the other hand, most Chevrolets can go 150,000 miles or 10 years, according to Chevy's maintenance schedule, and many Ford, Chrysler and Toyota vehicles don't list brake fluid as a regular maintenance item.
Michaell
@driver100 - as so many others have said, stick with the dealer. I agree that, even though the miles are low, the time element means that you ought to have more than just an oil change. Other fluids, I should think.
I think best to see dealer. Since they recommend brake flush every 2 years for Passat probably best to do it....sensitive equipment involved, and moisture could lead to big problems. I think anti-freeze and clutch might need change....dealer "seems" trustworthy.
Houdini Just play the reluctant buyer until they offer you a deal you can't refuse.
My wife says she doesn't want to replace a 4 year old car with 5500 miles on it. She says one day when we aren't as active we may want to get a better car for Florida, then fly down each year. Seems like a good plan to me!
Michaell - there are pretty good discounts on the 2017 Passats ... can't imagine you'd need more than the "S" trim, which you could likely get for low 20's before TTL
I think I'd have to get an SE or R Line to get a back up camera and blind spot warning. I'd also want a turbo or V6 to make trading worthwhile.
My wife would really miss the stick......and that really makes the little car fun to drive. I would sacrifice the stick for a turbo or V6, but, I don't think Mrs Driver would.
qbrozen $7k delta on a car with only 5500 miles is pretty steep on a per mile basis, though.
Plus $900 DOC fee, taxes etc. Not to mention low Cdn $ so it will be more like $10 to $12k. Probably a bit much if I look at this realistically.
JMONROE Without a manual transmission available, I dunno if Mrs. driver would agree to give that up, unless she's been spoiled by her GLK
I wouldn't go for the SEL model, it has things I would buy for my primary car, but not for a Florida car used for 5 months to go to tennis (state of the art sound system for one thing). The SE has all the things I would need, and costs about $6k less. She has adjusted to the automatic in the GLK, but the Passat needs the stick, unless it had a turbo or V6.
OF Talk about salesmen, go in for an oil change and they have you buying a new Mercedes.
Wouldn't that be something. The dealer sells BMWs and Porsches just next door. Imagine the story the salesman would have for his wife that night....this guy comes in looking for a VW and guess what I sold him........
The car hasn't cost us anything for 4 years. I guess it is worth brake fluid, coolant change, brake fluid once every 2 years to keep it running well, so you can buy it in 5 or 6 years.
I considered it because my wife and I prefer more power. But, she says she is happy with the Passat, so it will be a keeper for now.
Thanks all, you comments really help. I'll go to the dealer, get it done right, probably change the fluids and items they recommend, if it makes logical sense.....it will probably be worth it to keep this little gem of a car running nicely for as long as we need it.
and key to me, if something gets screwed up, they can't blame me for doing it wrong. put that all together, and for the 1 time a year per car, I just go to the dealer.
Turns out, I apparatly can download Apple CarPlay software if I want to. And it is DIY. I click to download to my PC, pull the sim card out of the car, plug that into the PC, download the update, pop it back into the car, and go into settings and hit update. Then wait for the car to load it, and viola. Not sure I will though. I probably would only real use it for Navigation, and I already got that in the car! By the time I learn how to do anything else that I would actually need, probably time to give the car back.
I just found it cool that I could just go online and download/update the car like that.
Oops, it was a SD card, not a sim card. Back to Best Buy for another $40 dongle.
Who knew all those "if Microsoft made cars" jokes would come true, in relatively short order.
Besides the usual crash and reboot snark, this one really came true:
"13. You would press the 'start' button to shut off the engine."
and it is a lot easier to do this sitting here watching TV, then to spend 2 hours at the dealer waiting for them to do it. And paying them for the privilege.
...or in a brass brassier (as in, colder than a witches ...)
Now I have to mark my calendars to remember to cancel in April. Call center person was great. I said I rarely use the XM because I rarely drive that car and it's mostly for Fox News channels or other talk stations rather than the music. I asked if they had a talk package instead of the Select group. LOL. She was restate what I had said about use or prices and then go from there. Very calm, professional interaction.
Actually, anything under $99 out the door with tax, title, licenses, and doc fee would have suited me for a year.
2013 LX 570 2016 LS 460
I know, not every ones cup of tea, but I wouldn't mind having that Jeep today....except the dream is probably better than the reality....they don't hold up that well and it was already getting pretty noisy and dated, I don't think it would have survived. I wanted to keep the E400 as long as possible, I thought that was a car I could live with for a long time. We definitely want to keep the GLK as long as possible, my wife loves it (so do I) and it has a great design.....comfortable, large windows, high seating, lots of power, nice backseat. Sorry to see they replaced it with a round swoopy looking, smaller windows, low roof line GLC
2015 GLK:
I'm not one that likes a boxy looking vehicle. Unless you get more cargo room in it, I don't know what the benefit is. However, I'm not one for either one of them even though I could use the hauling capacity more than most folks. But, that is why I like the idea of both of my Son's having vans. I don't think I'll ever discourage either one of them not to have a hauling vehicle of some type that I can use when I need one.
I guess you can call me a selfish father.
FWIW, when I lived in SC there were more pickups down there than I could count. At one point I thought about getting one just for self defense, but I chickened out. When I needed to haul something everyone in the neighbor hood was more than willing to loan me their pickup so that helped squelch my decision too. Yeah, I'm a pretty selfish guy and could be called a "user" but so far I can live with name calling.
I noticed, a lot of people follow close, but usually the cars that follow the closest are F-150 pick ups. There must be something about driving one that makes the driver want to be as close as possible to the car in front.
There seems to be a sense of entitlement with the higher vehicle and the size. I know that being higher off the ground makes speed seem less because of the appearance of slower passing of the ground beneath your wheels.
Now explain to me why soccer moms in Hondas do the same thing.
The soccer mom's....I dunno. Probably similar concept...power hungry women maybe?
Old Hondas with a kid wearin g a baseball cap backwards and sitting with his seat way back and really low are really bad...they like to cut in front and change lanes constantly
They still like to pull up right to my bumper at lights.
